MOKI RADIAL Care and Maintenence
Reply
Old 08-29-2019, 10:00 AM
  #4301
vickyz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very much appreciate on the advice.thank you so much to spend time to teach newbie like me
vickyz is offline
Old 08-29-2019, 02:08 PM
  #4302
Howie-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by RichardGee View Post
No you do not and should not.
I'm curious Richard why?
The pump instructions say to disconnect it and we have always done that with no issue. The whole point of the electric pump is to provide the carb with fuel at a constant pressure.
Just wondering if you have had a different experience.
Howie-RCU is offline
Old 08-29-2019, 05:31 PM
  #4303
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I left my pump tube intact as a pseudo insurance policy, should the electric pump fail to work properly,
After many flights, I have experienced zero issues leaving the pump tube in place. I also figure it isolates the engine internals from contamination.
I don't claim to be an authority and could be dead wrong on this, but thus far it has worked fine this way.
RichardGee is online now
Old 08-29-2019, 05:55 PM
  #4304
Howie-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK I see where you are coming from but unless you are going to the trouble of maintaining the tube and making sure it is not blocked, then it's not really insurance. If you are going to that trouble then get rid of the electric pump because the carb pump works a treat if the line is not blocked. Just my $0.02
Old 08-29-2019, 06:28 PM
  #4305
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Interestingly, after many flights, my fuel pump pulse tube is absolutely clear of any grease.
Old 08-29-2019, 06:34 PM
  #4306
tmac48
tmac48's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Howie, I might just jump in with my experience if that's ok. I installed my pump because I was having trouble with the first start of the day, however in the process of installing the pump I realized I had the tank below the level of the carby, I installed the pump after repositioning the tank simply because I did not want to go to the trouble of opening up my fuselage again!!!. I really do think that if the tank was higher than the carb in the first place then the pump would not have been necessary. I have left the original pump installed and keep an eye on the line for any grease that may block it but as yet have not seen any sign of obstruction at all!
tmac48
tmac48 is offline
Old 08-29-2019, 06:35 PM
  #4307
Howie-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep not surprised. I have seen 10 year old Moki's that have plenty of flights and no issue with grease in the tube and some that are 3 month old and the tube is blocked after 20 flights.
Old 08-29-2019, 06:40 PM
  #4308
Howie-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
tmac48
Hi Macka
Tank height "shouldn't" make any difference.
You started out with a brand new engine that would of got easier to start and better running after it had some time on it maybe??
Old 08-29-2019, 08:50 PM
  #4309
tmac48
tmac48's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Howie, I agree that the height of the tank with a walbro type carby is not as critical as our old rc motors (methanol) We have been spoilt with our DA engines, but they are two stroke and seem to have better suck( if that is the correct terminology,) than the 4 strokes. I never ran into difficulties in getting the fuel to the carby ( stopping in the line short of the carby) like I have witnessed with the Moki! ( ie 4 stroke)
tmac48.
tmac48 is offline
Old 09-05-2019, 05:07 PM
  #4310
IFLYBVM2
My Feedback: (359)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JB Weld ?
Was wondering if anyone knows whether or not JB Weld would stand up to the heat in a typical Moki exhaust extension ?
I would be using the original JB Weld epoxy, as their newer "high temp formula" gets pretty negative reviews.
Thanks-Mike O
IFLYBVM2 is offline
Old 09-05-2019, 05:20 PM
  #4311
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks-Mike O
I made an exhaust extension using hobby grade Silver Solder and it melted straight away. I doubt JB Weld would stand up to the heat.
Old 09-06-2019, 12:35 AM
  #4312
Blancr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks-Mike O
Mike,
I extended mine with jubilee clips. Put a saw cut down the extension tube short of the end of the overlaping area so the tube can contract onto the exhaust and tighten up the clip. I've had no problems with this approach.
Bob
Page 92 of the Carf P47 manual shows how it's done - with thanks to Richard Gee.
Blancr is offline
Old 09-17-2019, 08:12 AM
  #4313
IFLYBVM2
My Feedback: (359)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Exhaust temps ?
Has anyone ever taken their temp gun and took a reading at the end of the exhaust extension pipe ?
Working on an exhaust idea and just wondering what kind of temps to expect at the end of a typical
( 8 inch or so) extension. (Moki 250)
Thanks-Mike O.
IFLYBVM2 is offline
Old 09-20-2019, 06:53 AM
  #4314
jimboq8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Moki 400 ignition.
I am wondering if you can use the moki 250 ignition on the moki 400, Ive misplaced the 400 ignition and the plugs and sockets seem to be the same, And secondly does anyone have a spare one they wanna sell ?
Cheers
jimboq8 is offline
Old 09-21-2019, 08:22 AM
  #4315
frankyy54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, the Hardware is the same, but the ignition curves are different...
frankyy54 is offline
Old 09-21-2019, 08:58 AM
  #4316
jimboq8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pants. Will have to get a new one then. Thankyou for the reply.
jimboq8 is offline
Old 11-04-2019, 05:54 AM
  #4317
pmosf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi folks,
new owner of a s180, this is my first radial engine
I went through the whole thread and according to what I read, I already replaced the original ignition with a ch-ignition one.
I'll also use a rcxel pump. The carb is modified with a fuel return line.
I have a question regarding the lubrication of the front case: is it still advised to inject transmission oil in it in addition to the original grease ? If yes, I understood that I have to remove one the #1 cylinder stem, but not sure about the maximum level I have to reach. Should I remove the higher #3's stem or lower #2's ?.
pmosf is offline
Old 11-04-2019, 06:10 AM
  #4318
IFLYBVM2
My Feedback: (359)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am not sure of the answer to your question, and will leave it for one of the other guys.
Just a comment though-I have always wondered why the 150/180 seems to need and or benefit from the CH or Rainbow Ignition aftermarket units, but the 250 seems to be happy with the stock ignition. I had a 150 with the stock ignition that never did run right, but looking back now I think the CH Ignition would most likely have fixed my 150's issues.
-Mike O.
IFLYBVM2 is offline
Old 11-04-2019, 06:29 AM
  #4319
fatfreddy17
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
pmosf, a reminder to keep the rpm's down. as the motor breaks in it will gain power, and rpm's. Tach it often, you may need to turn down the throttle end point. too many rpm's and you'll loose a rod in flight.
One more item is to slow down your throttle servo speed. I received this advice from the Dr, and a slower throttle servo made a big difference in the motor transition from idle to high speed, then I was able to really dial in my 150.
fatfreddy17 is offline
Old 11-04-2019, 06:39 AM
  #4320
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
-Mike O.
My theory? The smaller crankcase of the 150/180 does not dissipate the heat and chaos of ignition quite as well as the larger crankcase of the 215/250. This creates extra stress on ignition components inside the crankcase and causes them to fail more readily.
All else being equal, I can think of NO other reason for reduced ignition reliability with the smaller engines.
Old 11-04-2019, 07:09 AM
  #4321
IFLYBVM2
My Feedback: (359)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 150 Ignition
Hmmm-makes sense, as it seems the coil pack is what fails often on that motor.
IFLYBVM2 is offline
Old 11-04-2019, 10:16 AM
  #4322
Jaketab
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can testify to having a #4 coil go bad on my older 250. It happened just after the one year mark and before I could fly it in the plane. I de-soldered the bad one and installed a new coil and everything has been great for the 9+ years and hundreds for flights. As for adding grease in the cam lifter housing, I periodically (once per flying season) inject a heavy weight gear oil through the lifters.
Jaketab is offline
Old 11-04-2019, 11:07 PM
  #4323
pmosf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RichardGee, I agree with your explanation, the coils are exposed to heat and vibrations, that's quite a harsh operating environment. The only advantage I see is the electromagnetic shielding given by the case.
Jaketab, do you have a rough idea of the volume you inject ? should I fill up to the crankshaft level?
pmosf is offline
Old 11-05-2019, 05:42 AM
  #4324
Jaketab
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
About 1 ounce or less in the #1 intake and exhaust lifter guides. Disclaimer - my Moki is older and well run in. This is what works for me.
If the engine is new and under warranty, I would not due this without first seeking the advice of the manufacturer or dealer for fear of voiding the warranty.
There are also those that send the Moki in for service to have the front case repacked with factory grease.
The USA Moki dealer- Gotz Vogelsang has always be very forthcoming and responsive in answering my questions about the engine.
Jaketab is offline
Old 11-06-2019, 07:38 AM
  #4325
GeorgiaFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What grease/oil are you using?
GeorgiaFlyer is offline
