MOKI RADIAL Care and Maintenence
#1401
HI
RE: MOKI RADIAL Care and Maintenence
ORIGINAL: wxman2
Can someone show me where these crushed washers go; I don't remember seeing them when I took the feed tubes off?
John
ORIGINAL: goodinmw
Thanks for the lead on the crush washers- 52 cents a piece at aircraft spruce.
John
Haven't actually taken mine apart yet- but there should be a seat inside the crankcase bore for the intake tubes, the crush washer goes in first against the seat and then the intake tube. As the intake tube is tightened at the cylinder head, the tube is drawn in against it and crushes the (crush washer) sealing the end of the intake tube to the crankcase. That's the concept anyway.
If you did not recall seeing them on dissassembly, my bet is they are still inside the crankcase bore and need to be removed.
Mark
#1402
My Feedback: (47)
Got the first two runs on the motor today and things went well. Temp was 96F with a humidity of 54%. I am running 91 octane ethanol free gasoline mixed 45:1, Castrol RS TTS T2 oil and Metalon C2 friction additive. A 32 x 18 Biela prop is installed and I was getting 4,400 PRM at full throttle and 850-900 PRM at idle. Transition was great after coming up to temperature and no really problems were noted. temperature for the #1 cylinder was getting up to 260F and all others were in the 190 to 230F range checked with a Raytek temperature gun aimed at the exhaust outlet in the cylinder head. I checked the #1 plug at it did not look lean, actually looked slightly rich. I am going to buy the Eagle Tree Telemetry system in the near future, so I can get more accurate data. Were are you guys measuring the temps during runs? I hope you guys don't mind a video, but here is my son doing his best to record the run. Please pay no attention to the fat man in the black shirt and getting interrupted by the neighbor half way through the run. Any advise or inputs are welcome. Thanks and take care.
[youtube]http://www.youtube.com/watch?v=c-0szwqLnBU[/youtube]
#1403
HI
Aloha All,
Got a line on Moki 150 Intake tubes-
www.teamaerscale.com Gotz Vogelsang [email protected]
Has my 150 tubes in stock.
A bit pricey, $65 per tube and they only come in sets of 5 (5 x $65)
Guess I'll be able to do lots of experimenting!
Or if I figure this out on the first tube, I'll have several to share.
Will keep you posted.
Aloha,
Mark
Aloha,
Mark
#1404
HI
#1406
BC, CANADA
A little "Moki Music". Just finished the maiden on the plane, 40% Waco, Moki 400, 76lbs.....comin' to Monster Planes
http://www.youtube.com/watch?v=wFl7F1NE5io
#1412
My Feedback: (47)
I have three flights on the airframe and the motor is a great performer. Total time on the motor since I got it from Vogelsang Aeroscale is 1.2 hours. Pulled the plugs today to inspect the condition and this is what I have. #3 and #4 are running the coolest as indicated on the temp gauge and the spark plugs. #1,2, & 5 are within 10 degrees F of each other (190-180F) after landing and #3 & #4 are 50-80 degrees (110-120F) cooler. I posted earlier with no reply and hope that you guys might find some interest and input to the condition of the spark plugs and the previous video. I do have all three flight videos to post if you guys would like to see them. As before, any inputs are appreciated. Thanks.
Jason
Jason
#1415
My Feedback: (47)
ORIGINAL: WARBIRDRCER
You bet, please post the videos, and thanks for the info.
Jason
[youtube]http://www.youtube.com/watch?v=v4BzwM76Qq8[/youtube]
[youtube]http://www.youtube.com/watch?v=MJa7dhSyYqA&feature=related[/youtube]
#1417
My Feedback: (47)
ORIGINAL: germrb
Nice data! I have one question: What are you needle valve settings?
Right now my needle setting are 1.7 H and 1.2 L. I have leaned them out about a blade width each. I am going to get the Eagle Tree System or another that will allow me to monitor all five cylinder, but at a minimum, like you, I want to monitor the hottest and coldest. It has been really interesting to see all the data you collect with the Eagle Tree. It seems over the last two flights that #5 is turning out to be my hottest cylinder. Thanks and take care.
Jason
#1419
Hi Scott, long time no see, how are you?
Just a little update on what I've been up to...enjoy.
regards Mick.
http://youtu.be/xvRDltmAERA
regards Mick.
#1420
Hi Mick,
Wow love your new LA she sure looks the bizzz,she rips through the air!!!!
Do you fancy bringing her along to the Victory show!!! http://www.thevictoryshow.co.uk/Airc...S/Default.aspx
Mick, Scott is out on tour with the Cat,he has been picking up a few trophy's in between doing interviews on the TV!!!!
http://www.fox11online.com/dpp/good_...21&status=true
Cheers Graham B
Cheers Graham B
#1422
My Feedback: (47)
I thought I remember reading in the thread that some of the guys ignition connection had come loose so....I have been thinking about a way to positively lock the ignition connection in place and during my morning run this is what I came up with. I wanted to use the existing ignition structure and be simple. Its main function is to keep the locking tabs engaged and not come loose due to vibration. A secondary benefit is that is puts "finger pressure", best way i can describe it, on the top of the ignition connection. Couple of pictures. Take it easy.
Jason
Jason
#1423
BC, CANADA
Jason, it's the large screw together connector(the big one on the left side of your second photo) that has loosened up for some people. Just wrap some tape around it to secure it. I also use some servo grommets on the 3 screws on the ignition box to help isolate the vibrations.
Cheers,
Dave.
Cheers,
Dave.
#1424
My Feedback: (47)
ORIGINAL: mogman
Cheers,
Dave.
Cheers,
Dave.
Thanks Dave, guess I got that wrong.[sm=red_smile.gif] I should have confirmed before I posted it. Well it was fun to think up and design so no loss I guess. I used a 1" rubber lined clamp for the screw together ignition junction and that has seemed to hold the connection tight. I used cork on the bottom of ignition mount to help isolate the vibration. but some rubber grommets would help also. Here are some pictures of the ignition mount before it was glued and painted. Sorry about that. See ya guys.
Jason
