MOKI RADIAL Care and Maintenence
#1901
RE: MOKI RADIAL Care and Maintenence
Yes, and there is a small piston that stays with the engine that has a ring that seals in the cylinder.
I just make sure that the piston is lubricated around the outer circumference and remove the grease that is on top of the piston or in the top of the cylinder.
you need to seal the threads when you reinstall the outer casing making sure you don't get any of the sealant in the cylinder.
Ron
Ron
#1903
Steve, Thanks for the pictures, it looks like a front end disassembly to remove the pump. There is a lot of grease in that section.
It probably wouldn't hurt just to leave it there and let it do nothing.
Any comments or Ideas on this one, anybody..........
#1904
My Feedback: (22)
You are correct; there is no removing the pulse pump assembly without splitting the nose case. The pins the planetary gears align on, one planetary gear of which drives the connecting rod for the pulse pump piston also acts as the alignment pins for the nose and forward case halves. You can screw the pulse pump cylinder barrel off, but that is about it.
The only caution I would give if you choose to plug the pulse tube and use the electric fuel pump is to keep the pulse pump air intake hole clean. If the air hole was ever able to become clogged and the grease were to build above the piston then a hydraulic lock may occur. This would create a side load on the planetary gear which drives the piston closing the gap between the planetary gear and the crankshaft splines. This would lead to a catastrophic engine failure in my estimation.
The gear in the bottom of this photo shows the concentric lobe on the top side of the planetary gear in which the pulse pump connecting rod drives on. This is how MOKI develops the stroking action of the piston. You can also see in the photo there is no room for any side load to occur without damaging the gear train.
Just my thoughts,
Just my thoughts,
#1905
Thanks again Steve, I don't mind the maintenance, it's the fact that little thing could cause such a big problem, that is what was bugging me.
I appreciate the trouble you went through to send that picture, now I feel a little better knowing what is in there.
I still need to do maintenance on my pulse pump, also because of your concern about hydraulic locking, I think I will run the tube from the pulse pump to the atmosphere, that way there would unlikely be a hydraulic lock, it would pump the grease down the tube, and if the tube was at least four inches long there would not be any dirt injested back through it.
Thank you again Steve, with these experiences from so many guys it won't be long before we figure these babies out.
#1908
Dear Goetz,firstly I congratuate you and you wife on the birth of you baby daughter, I hope mum and baby a doing well!
I also wish you yourself the best of health.
Thank's for you intrest in my "Case" , 150.
I will ring in shortly to order the gaskets and other spares.
Thank you also for all the great work you have done in this forum!
Karl-Heinz.
p/S,I hope I don't foul up the time conversion when I ring,+10 hrs here.
Karl-Heinz.
#1910
My Feedback: (52)
ORIGINAL: kipuetz
Yes,a3 mm dome nut and fiber washer on the tube side, a very short 3mm bolt with a fiber washer on the pump side.
Karl.
Karl.
I can understand closing (blocking) off the carburetor, but wouldn't you only block off the Moki pump side off if you have removed the pump mechanism from the motor?
#1911
Like Warbirdrcer stated, if you block off the pulse pump you could possibly have a hydraulic lock if grease got on top of the piston of the pulse pump.
I think it would be better to vent the pulse pump to the atmosphere leaving about four inches of tube so dirt would not be sucked into the engine.
HELP! We need an expert on this one
Question, When using an electric pump should you block off the pulse pump, or vent it to the atmosphere.
#1912
BC, CANADA
When I put the electric pump on my 400, the instructions said to cut the pulse tube and leave about 1/2 in. at the carb end and plug it with a piece of wire. Leave the tube from the pulse pump open and let it sit between the cylinders. I have 35 flights on mine with NO issues.
Cheers,
Dave.
Waco Brotherhood # 180.
PS.......I meant NO issues other than the dreaded #3 cyl dropping out. Hopefully, Goetz' new ignition will help that.
Cheers,
Dave.
#1913
My Feedback: (9)
ORIGINAL: shaked israel
i have the moki 150 radial, and after couple of a few howers runing the engine Pulled out grease as show at the Picture, after the runing.
can sombody know what it is.
the engine run normaly
Dear Shaked,
You would want to install the engine with the airpump being as close to the 12 o'clock position as possible, that will minimize, almost completely eliminate the loss of your bearing grease.
#1914
My Feedback: (9)
ORIGINAL: wingstrut
I usually cut it (the airline), install an inch long piece of 2-56 rod to re-connect the tube visually and the cut/drill a small breather hole into the tube, right after the pump. That way I have no pressure buildup, maintained the scale look and keep grime from entering the carb.
-Götz
#1915
While on the subject of the pulse air pump, the clear festo tube is cut and blocked on the carb side only. The pump side is left open. I run an APS fuel pump with good results.
After about 1-1/2 gallons of running, I have not noticed any grease leaking from the air pump or tube.
Question: Is it acceptable to see no grease at all leaking from the pump ??????
Thanks - Jaketab
Thanks - Jaketab
#1916
I haven't purchased my electric pump yet, I guess I should have realized that the instructions with the pump would explain all this.
Thank you again Gotz for straightening out this issue. I like your idea of reconnecting the tube and drill a hole to vent the pump.
Ron
Ron
#1919
My Feedback: (9)
Let me give an update on our new ignition:
It will run on 7.4 to 11.1Volts, meaning you can run 3S LiFe, 2S and 3S LiPo and your "older generation" batteries at the correct voltages, as well.
Consumption is actually DOWN from the Moki ignition. I should have numbers when it comes to engine performance in a few weeks, the Moki S250 tests are finished, we are working on the S150 right now.
Adjusting the engine has never been easier as this ignition ignites "scenarios" the stock ignition was not able to handle.
-Götz
-Götz
#1920
My Feedback: (73)
ORIGINAL: Der Goetz
It will run on 7.4 to 11.1Volts, meaning you can run 3S LiFe, 2S and 3S LiPo and your ''older generation'' batteries at the correct voltages, as well.
Adjusting the engine has never been easier as this ignition ignites ''scenarios'' the stock ignition was not able to handle.
-Götz
-Götz
what is the anticipated $$$price$$$ ballpark on the new ignition ??
thanks
~V~
#1921
My Feedback: (9)
I have no numbers yet but should be right around the cost of the stock ignition system, not much more.
But again, I have no pricing yet, no shipping, no hard information regarding that matter.
-Götz
-Götz
#1922
Altzheimers setting in again????? re 215 carb settings, can't remember what the original settings were for the low & hight .. Any help?
#1925
ORIGINAL: Hinckley Bill
Picked up this ''unique'' Gee Bee fantasy airplane and will install a Moki 250 in it ....... what do you think?
