MOKI RADIAL Care and Maintenence
#1976
RE: MOKI RADIAL Care and Maintenence
Recently my 215 dies at over 1/2 throttle. It seems to be starving for fuel at a high setting. I've checked for a clogged screen (even replaced the carb) but no joy. The only anomoly I can find is the o ring around the intake tube in the rear crankcase was deformed and possibly allowing air to get by. The idle and transition seems fine except when going past the 1/2 open position. Haven't had a chance replace the o ring but am wondering if that sounds like the problem. Mitch
#1977
MA
Mitch,
Could it be fuel line or a tank problem? Or are you setting it up on a new airframe with new tank, etc. Ignition able to keep up with the higher RPM? I'm sure it is baffling as you probably have moved over a working configuration to a new airframe.
#1979
Are you using an electric fuel pump? If not, then perhaps the pulse generator that aids fuel delivery to the carb is not working properly. I had many problems with mine, so I fitted the electric fuel pump & the engine now runs perfectly.
Millsra (04-02-2022)
#1982
ORIGINAL: [email protected]
Have my First Moki 250 Going in a Comp ARF Corsair and have to say the fuel pump is a Big Question as to if it is a must do or can the motor be run without the Electric fuel pump, ????
#1983
Fellas , I was just sreading all your questions and replies and most certainly found them very interesting and certainly very helpfull in many cases. And then I had this brain fart, Has any one ever thought about putting on a self starter on these radials????
Heinz
Heinz
#1984
Heinz
Heinz
#1987
My Feedback: (221)
Also, I mount the pump UNDER the front of the tank. It primes in a split second, and always works flawlessly.
I'd like to show you pictures, but alas, RCU is not cooperating again.
#1988
ORIGINAL: ram3500-RCU
The pump is very inexpensive insurance compared to your investment. Plus, it will start easier, and average about 300 more RPM, with a more reliable and lower idle with the pump. I see no good reason not to use it, other than to save money, and again, I would not risk my CARF Corsair to that factory, rather small, pump.
Moreover, when I start the engine cold for the forst time it takes some 5 flips it pops and then about the same for it to start. For me the engine works just perfect as it was designed. So I would never byu something so expensive that, to my experience, does nothing but increase propability of malfunction.
#1989
My Feedback: (221)
Opinions vary. The factory Moki pump is marginal at best.
To say the pump can cause problems makes no sense to me. The needle settings are cut back a bit with it. The engine has a constant and steady flow of fuel that does not waver or vary. This regardless of where the tank is.
I don't believe the Turbulator is necessary, but the electric pump is another story. I base this on personal experience, and the experience of almost every Moki owner I have met at events like Monster Planes and Top Gun.
#1990
My Feedback: (62)
I have had the 150 and 215. Both where dramatically improved with the turbulator. Have you tried it? All aspects of operation where improved including even running of all cylinders, vibration, far lower temp and throttle transition. So many people say "do not run the engine on the ground for long periods or it will overheat" ....not true with the turbulator. I could run it all day long at high throttle and cylinder temps would all be around 180 F on an 80 degree day. The exhaust collector ring stayed looking brand new. Yes I agree the fuel pump is a requirement. -Tom
#1991
My Feedback: (221)
ORIGINAL: Maxam
I have had the 150 and 215. Both where dramatically improved with the turbulator. Have you tried it? All aspects of operation where improved including even running of all cylinders, vibration, far lower temp and throttle transition. So many people say ''do not run the engine on the ground for long periods or it will overheat'' ....not true with the turbulator. I could run it all day long at high throttle and cylinder temps would all be around 180 F on an 80 degree day. The exhaust collector ring stayed looking brand new. Yes I agree the fuel pump is a requirement. -Tom
#1992
Heinz, I believe most of the old Sikorsky units used radials like the H-19 and UH-34D's , I just thought someone out there might be thinking of a radial for a heli, that would be a neat helicopter............Ron
#1999
ORIGINAL: nine o nine
So I'd bet my money on too much air. I suppose it could also be possible that there could be a stuck intake valve so it would press the air from the cylinder back to the crack case causing the airflow from the carb to stop for a short time.
Hope you'll get it fixed.
#2000
Help please guys.
I bought a used Moki 215 and have been busy bench mounting it for testing.
It came with the APS electric pump, 34x18 prop and SM Services kill switch so I have rigged it up to suit.
Started it up today - 1st flick and she was away !!
Sounds like it isnt firing on one of the cylinders and No3 runs very cool.
Disconnected the No3 HT lead whist running and it didnt seem to change the engine note at all - so I am GUESSING No3 may be out.
I am sure that this will have been covered somewhere in this thread, but what is the process of elimination ?
I am guessing it will be check plug for spark first - if no spark check HT lead/plug cap then coil ??
Could there be other common issues with No3 ignition problems ?
Thanks, Steve
Thanks, Steve
