MOKI RADIAL Care and Maintenence
Reply
Old 01-18-2013, 05:19 PM
  #2301
slskn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: MOKI RADIAL Care and Maintenence
Quote:
ORIGINAL: Jim Cattanach
If anyone is looking for a Moki 150 radial, mine is for sale on RCU classifieds £1,600. Includes exhaust extensions & recommended electric fuel pump.
Bought new March this year from Heilemann Sternmotor Germany. Only 2 to 3 hours running time.
is this Moki still for sale? how much in USD? thanks for the info-Steve
slskn is offline
Old 01-18-2013, 09:15 PM
  #2302
WARBIRDRCER
WARBIRDRCER's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: docgboy
I have a question about crashed engines. I have a Moki 250 that was in a crash were the plane went straight in on the nose at high speed. The two lower cylinders cracked and collector ring broke and many rods bent or gone
Is it worth fixing or is it trash. Has this happened to anyone,I'm sure it has, that went ahead and had it repaired. What was the cost.
Scott
I bought a crashed 250 once to see how these engines were designed. I am looking at selling for $250.00; the cost I have in it. This may save you some repair cost. I can say, when I looked into it, parts can add up quick.
WARBIRDRCER is offline
Old 01-24-2013, 10:49 AM
  #2303
heinzulrich
heinzulrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Smoke pumps? I'm getting my AMR 40% Waco ready, engine is Moki 400. What do you fellas recommend for a smoke pump. Perhaps I should ask, who has a smoke pump on their 400 ??? and how's it working for you???
Heinz
heinzulrich is offline
Old 01-28-2013, 09:04 PM
  #2304
brazan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any one have any feed back on the Rainbow-tronic ignition ?
Doing the annual on my 150 and thought it might be a good time to do the swap if it seem to help keep the #3 cylinder lit .
Josh
brazan is offline
Old 01-29-2013, 02:16 AM
  #2305
kipuetz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi brazan,have had rainbow-tronics ignition module for my moki 150 since early December now. It was a straight forward order ,a fairly long wait ,but "Uwe" was in the middle of working on the the latest software versionfor it.First impression: very well made, excellent quality at a very reasonable price.Installing took about one hour or so. It involved removing the original ignition ,working out the placement of the new one.The only drawback for my stallation,1/4 FW190,was the weight!The rainbow-tr.is a whole 4 ounces {100gr.}heavier then the original one, a problem for some but not for others.Starting it was a surprise!Priming plus" one more flip" started things rolling.To me it was immediately apparent that the engine ran with a lot more authority ,the same carb settings produced 100 RPM more.Checking a spark visually confirmed to be much "firmer " firing .Suggestion: If you thinking about getting one , DO SO ,You WILL NOT REGRET IT!About nr. 3 not lighting properly. The latest thinking is, play around with mixture settings.Perhaps 35/1 oil mix is worth a try.Let us Know how you go!Regards, Karl-Heinz..
kipuetz is offline
Old 01-29-2013, 06:36 AM
  #2306
docgboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have some used parts from a crashed moki 250 that are for sale.
4 upper cylinder case with valves and rockers- $80 per
1- carburator $50
1 rear housing with coil pack- needs one spark plug cap replaced- $400
1- ignition $350
I also have crankcase and crank with pistons. Some rods and pistons damaged and need replacement. $400
Send me an e-mail sjbonomo@aol.com if interested. I know there is a risk, but these prices minimize it. Maybe someone out there can benefit
docgboy is offline
Old 01-29-2013, 06:50 AM
  #2307
wphilb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also have one f the new ignitions and first impression is that it is keeping number 3 lit. I've not gotten the hang of the one flip starting but once started once repeat startings are easy. If someone has a recommended starting procedure I'm all ears. I'm probably not priming enough?
I sold off my older ignition module (to 9 o 9) but have the coil pack and spark plug leads for sale here on RCU.
Whit
wphilb is offline
Old 01-29-2013, 07:08 AM
  #2308
slskn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you use electric starters on these engines ? Or no?
slskn is offline
Old 01-29-2013, 07:53 AM
  #2309
docgboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have seen it done many times. It usually takes a 24 volt starter to turn it over.
docgboy is offline
Old 01-29-2013, 09:02 AM
  #2310
brazan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Karl-Heinz
Is the rainbow- tronic  4 oz heavier than the original counting the coil packs from the original?
Josh
brazan is offline
Old 01-29-2013, 11:11 PM
  #2311
kipuetz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Josh,yes, the weight includes the coils, but not switches or other devices .One more thing, for me one of the more important aspects is, the Rainbow-tronic runs from 10 volts down to6 volts. a fully loaded 2 cell li-po with 8.4 volt is just the ticket!No more voltage regulators!!!!Regards, Karl-Heinz.
kipuetz is offline
Old 01-29-2013, 11:18 PM
  #2312
kipuetz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
kipuetz is offline
Old 01-30-2013, 05:54 AM
  #2313
wphilb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I spoke to Vogelsang about that (using 2 cell A123, and they were concerned that at the lower voltage you are not really getting anything from the new ignition. They recommeded a 3 cell A123 which is what I am running. I am only in the testing stage on the ground but so far it's dealing with the Moki 150's tendancy to drop out #3 cylinder.
NoBS batteries has 3 cell A123 packs as a stock item for the Jet community so I just got one of those. I am not using a regulator and I'm charging using a balance coonector on the pack. If you want to use a fuel pump from the same source you would need a regulator. I run separate packs for the radio so no regulator needed there.
Whit
Quote:
ORIGINAL: kipuetz
wphilb is offline
  #2314
wingstrut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hope they lower the price of that new ignition, $568.00 is a bit much for $60.00 worth of materials. I know, testing, research costs a lot.
I still blame the Moki factory for not taking care of these problems for their customers, they obviously are selling an engine that has major problems for a premium price and customers and other people have to come up with a way to correct the flaws in the design at a greatly added expense..............Fuel pump, electronic ignition, turbulator etc.
Guys, don't get me wrong, I love my Moki Radial, but factory support sucks, it's like, you bought the engine now it's your problem.
If you bought an OS or DLE or any other engine you would not have these problems and if you did, the company would take care of it.
I just get tired of pumping money in this thing to get it to operate like it is supposed to in the first place.
Is there anyone out there not having to use these add on's to have successful engine runs and not worry if the engine is going to run through the whole flight.?
wingstrut is offline
Old 01-30-2013, 07:12 AM
  #2315
AFK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just recieved my Tronics igbition from Vogelsang. What voltage and mah are you guys using? Looks like about 11.1 volts is o.k.
Tony K.
AFK is offline
Old 01-30-2013, 10:15 AM
  #2316
oy4310
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I totally agree. an engine in the price range to work perfectly from start.it is strange that there is only one dealer in the world (Vogelsang) who tries to get in touch with clients to inform and contribute to solutions to problems associated with the product = engine
Quote:
ORIGINAL: wingstrut
oy4310 is offline
Old 01-30-2013, 11:51 AM
  #2317
wphilb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
First, Amen on the having to spend like $800 to get a $3500 engine to run right, shame on Moki! On the other hand, right now they are selling every one they can make so no pressure on them to fix problems. My hope is that the other radial engines coming in from Horizon will put pressure on Moki to wake up and evolve into a company that understands customer service.
Second, I run a 3 cell A123 on the new ignition and it's working fine, was advised on to use a 2 cell as not enough voltage.
Lastly, +1 on Vogelsang, Dr Gotz has the right attitude and intelligence. He is well versed with these engines and is trying hard to help novices like myself.
Whit
Quote:
ORIGINAL: AFK
Tony K.
wphilb is offline
Old 01-30-2013, 01:00 PM
  #2318
wingstrut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree, Dr Gotz has gone the extra mile to help, which I commend him for, I am in no way referring to him, he is a great guy.
My engine cost $4200.00 my kit cost $2000.00, now add another $1500.00 to finish it................HEY! I could have bought a jet ...............Ha!Ha!
I used my early retirement bonus to purchase my dream, A radial in a Waco YMF-5.
Now I am having a difficult time with having to spend the funds for the extra engine stuff.
I know that this site is used for helping others, and I do that as much as I can, and I am not trying to degrade Moki, I think mechanically they have the best radial out there.
I just wish the factory would help us out a little on the defects.
I feel better now..................Ron ..........Round engines forever,,,,,,,,,and I don't mean turbines.
Old 01-30-2013, 03:17 PM
  #2319
heinzulrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm in total agreement with you, I love these engines but they could certainly improve their costomer service. I got three of these engines and I'm certain some of you fellas have more, It is time that the manufacturer starts resolving some of these issues. And for those that have these engines give them a deal on replacing some of these defective parst (ignition problems mainly).
As for Dr. Goetz, thanks for all your help I'm sure we all apprecaite it.
Heinz Pantel
Old 01-30-2013, 10:20 PM
  #2320
kipuetz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AFK,I have received information about operating voltage from Uwe Semmler ,the maker of rainbow-tronics,he says, up to10 volts is what the unit is designed for. I'm sure it will handel more,but how long for is the big question!Myself, I do as he suggested and run a 2 cell LI Po of 2700 Ma. capacity , the draw at full revs is about 750ma.So far so good!Karl-Heinz.
kipuetz is offline
Old 01-30-2013, 10:21 PM
  #2321
kipuetz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
kipuetz is offline
Old 01-31-2013, 08:25 AM
  #2322
wphilb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To each their own and what works for you, works for you! I'm not a EE by any means.
All I can say is that the unit is clearly marked with "designed for 3LiFePo cells (9,9v)" and that the instruction manual (translated into english by Dr Gotz) states "that you can connect a 3 cell LiFE (9.9V nominal) or 3 cell Lipo (11.1 v nominal )" and "should the voltage drop below 9.9 volts in flight it will produce a misfire on purpose" and " the igniton will cease to function below 8 volts."
That would seem to me to rule out a 2 cell A123?
Whit
wphilb is offline
Old 01-31-2013, 11:02 AM
  #2323
wingstrut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good point Whitt, and good to know
Old 02-02-2013, 04:26 AM
  #2324
slskn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have 2 Beila props for the moki 150 would sell if anyone is interested, one is 23x14 4 blade, and the other is 24x10 4 blade, both props have not been in the air or drilled out, only tested for RPM on my 9 cyl. Evolution radial engine, found out it is too much prop for that engine, will sell for $75.00 ea. or $140.00 for both, they sell for $110.00 or so ea. else where, just am not going to use these props, just email me slskn@charter.net or call 810 247 0676 for any questions thanks-Steve
slskn is offline
Old 02-02-2013, 09:32 AM
  #2325
smackay
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Would you sell the moki and ship to danbury CT? I need some spares!
smackay is offline
Reply
Display Modes
