Which retract for BRIAN TAYLOR P-51 69"
Dear All,
I'm building a Brian Taylor P-51D 69".
I'd like to equip it with a scale retract; what would be a good scale retract for this plane? I already found the centuryjet one and the Unitracts one, which one of these would be the best?
Do you know other manufacturers that would likely propose good retracts for this plane?
Thanks a lot in advance.
Nicolas
Nicolas
My Feedback: (60)
AZ
RE: Which retract for BRIAN TAYLOR P-51 69
You might send an email to Sean McHale at strictlyscale.com. He has built two of the 69" Taylor Mustangs and I'm sure would be happy to answer your questions. Good luck with it!
http://www.strictlyscale.com/Strictl.../P51Build.html
My Feedback: (13)
Hi All
I have this top quality scale rendition of the P-51D.. I have the Unitracts .
The Unitracts are one of the best choices for this model for the following reasons. The Unitracts were made for this specific model. The unitracts are ultra low profile to fit in the scale laminar wing (thin LE section) and to place the strut way forward, as in scale. The only thing I would suggest if you go with the Unitracts is to support the end of the retract rotating shaft with the leading edge. If you get the Unitracts , you'll see what I mean.
Of course with some additional work/modification, one can make any almost any retract work as well.
Steve
Steve
Hi Everyone,
Thanks for your answers!
Scalecraft, I was in contact with Unitracts and they don't have photos of their retracts for this plane. Do you think you could take a photo or two of your retracts and post them?
Are the struts realistics? I mean, is there the damping system at the bottom end of the strut, and so on?
They explain that the struts have individual speed control, could you tell me how it works? I would like to re-create the scale landing gear sequence, it means that I would like one leg to get down before the other, you know... is it possible with their system?
What did you buy from Unitracts, the two legs with the pneumatic retracts, a valve and so on? Or did you only buy the 2 legs and pneumatic retracts and buy the valve and so on somewhere else?
Did you also buy the tail wheel from Unitracts? Is it scale? Because they say it is a standard tail wheel...
How do you activate it? Because as far as I understood it is not a pneumatic tail wheel...
Thanks guys,
Nicolas
Thanks guys,
Nicolas
My Feedback: (13)
Hi
Ok I will post pics once I find them. (Tmrro night) We have a house expansion going on right now that has shut my shop down. My hardware is in boxes.
The struts are nice shock absorbing type with dampening via a nylon friction set up. The "yolk' is the only part that looks odd. It is square and not rounded as in scale. The shape is right, just not a tube look to it.
The speed of the retracts can be controlled by a valve that has a needle valve type of regulator on it. I do not have this valve.
I do have a system to make my BF 109 LG retract one after the other, but that has a different retract lay out.
Steve
Steve
MI
I to am building the BT Mustang here is the landing gear picture I think your looking for. The unitrac landing comes with a metal support plate that gets glues into the leading edge material. This plate provides support for front of the retracts pivot shaft. Mine air air operated and Bob Holman got them for me. They are not cheap by any means but they do put the strut where it needs to be.
Hope this helps. Good luck on your build.
