Gauging interest, Hellcat group build
#76
My Feedback: (60)
AZ
RE: Gauging interest, Hellcat group build
My pleasure John, no problem.
A bit more progress to report. The fuse now has it's first coat of primer, what I like to call the "reveal" coat. And this one has revealed that though we are coming along well there is still work to do before it can be deemed ready for surface detail. I shot a couple of pics on the kitchen table while the wife was out, shhh!
#78
My Feedback: (60)
AZ
Jump on board Jerry! We are trying to get some of the 1/8th Air Force guys interested so we can have a local group of guys building Hellcats. We will see what happens.
PS - I got your email about the Zero and I'll keep you informed.
#79
My Feedback: (15)
Chad, looks wonderful! I really think that you are going to have hit a home run on this plane.
You mean that you would let Jerry hang out with you? Well there goes the neighborhood, LOL .... (just ribbing you Jerry) Jerry is a top notch kind of fellow in my book!
Now Chad, about you putting planes on the kitchen table without the "boss" knowing... I will not tell her for a small fee! ROFL !
Nite guys, Im to bed,
John
John
#80
AZ
Chad,
I should make it official and say I'm joining in and ready to go. We'll see how many of the other One Eighth Air Force guys we can get in on it too!
Val
Val
#82
Chad,
what are you using for a high fill primer these days? Last time I painted super poxy primer on polyester resin over 3/4 oz cloth .
#83
Chad,
Subscribed.
The Hellcat looks great!
I want to give raised panel lines and rivets (raised & flush) a go, so I'd be interested in joining the group build. Count me in.
EJWash
Subscribed.
EJWash
#85
My Feedback: (60)
AZ
ORIGINAL: JohnMcGowan
ORIGINAL: valr
Chad,
Chad,
ORIGINAL: aerowoof
Chad,
Chad,
ORIGINAL: EJWash1
Chad,
Subscribed.
Chad,
Subscribed.
I should have more progress pics tomorrow. I was hoping to have the Hellcat on its' gear but ran into some issues and have to order some new parts for my Robart retracts. Oh well, still plenty to do. Thanks for all the support gentlemen!
#86
Chad,
Just ordered a copy of "[link=http://www.hobbylinc.com/cgi-bin/s7.cgi?cat_s=SAW&str=hellcat%20f6f]F6F Hellcat Walk Around[/link], by Squadron/Signal Publications from Hobbylinc.
Keeping my eyes open for retracts. The Robart 615s for the mains? Which tailwheel?
EJWash
EJWash
#87
My Feedback: (60)
AZ
EJ,
I'm going to give the Robart 615's a shot although I know a lot of guys have had issues with the side arms bending on a rough landing or when you get too much side load on them. I think many of these guys are flying airplane that are heavier than the rated 10 pounds and are flying off of grass which is probably not helping either. That's not an issue around here! The airplane will also be set up to take the Sierra Precision rotaters which are light years ahead of the Robarts but are also about 2 1/2 times the price. If you like the peace of mind and can afford them I would recommend the Sierra gear. If you decide to go with the Robarts I will be able to provide both the mains and the tailwheel (#121), as well as most other items, at a pretty good discount through Ray & Robin's Hobby Center which is sponsoring the group build. A list of items with part numbers can be found at the link below.
http://www.hellcat.cwvmodels.com/order.html#components
#88
Chad,
Tower lists the Robart #615s at $129.99. If one wants to go scale in appearance (and functionality) they can go with the #650 3/8†RoboStruts AT $39.99 X2 ($79.98). That brings the Robart main gear set-up to $209.97. Funny thing is that Robart lists the limit of the #615s at 10lbs., but the #650 RoboStruts at 14lbs.. I guess that the 3/16†wire struts holds the limitation. If one went with the plastic strut covers, there’s another $12.99, so you’ve got $142.98 in the main gear right up against the 10lbs. limit.
Sierra lists their 60-size 100-degree rotating retracts (model 60 F6F Mains) at 14lbs. model weight, and man does this gear look more stout over the RoboStruts. The Sierras list for $270.00. So, if the builder wants scale gear (and functionality) the difference between these two is $60.03. Personally, I want the scale appearance, functionality, and the BEEF, so I’ll be opting for the Sierras for the mains.
I see from the link that your website is coming together. Things are getting interesting...
EJWash
EJWash
#89
My Feedback: (60)
AZ
EJ,
I had not factored the cost of the struts into the equation. The 650 struts you mention are not long enough for the Hellcat so you have to go with the 7/16" diameter which are $53.50 each, $107 for the pair. I may have a source for the struts for substantially less than the cost of the Robarts. If all goes as planned I should be able to offer the Robart 615's and a pair of 7/16" diameter struts for around $180 or so. That's a substantial savings versus the Sierra gear. Having said that, I just picked up a set of the Sierra gear myself and they are VERY nice and will be going in my next Hellcat. I am definitely interested in testing the Robart gear for myself to see if they are up to the job. I will be more than happy to share my "real world" results with the group. This is one of many reasons I do not want to start the group build until the airplane has been tested to my satisfaction.
#90
MN
Neat Hellcat project, Chad. For the extreme budget conscious builder, Hanger 9 Hellcat or Corsair gear should work. I have these gear on my H9 Corsair. I also added some 3/8" struts that I bought at VQ Models. They seem to be very close copies of Robostruts and are/were about half the price of Robostruts. They don't appear to be available right now. I don't know if they will be available again.
http://www.horizonhobby.com/Products...ProdID=HAN4084
http://www.vqwarbirds.com/access.html
From the pictures of your unsheeted Hellcat wing on the first page of this thread, it looks like gear mount rails could be moved to the top of the wing fairly easily to accommodate the H9 gear. The H9 gear (1-3/8" wide) is about 3/8" narrower than the Robart 615s (1-3/4" wide), so wider gear rails would be needed along with moving them to the top of the wing. The H9 gear with a $30 HS-75 retract servo and bell-cranks would be about $60 dollars all together, plus $7 for H9 Hellcat/Corsair wheels.
#91
ORIGINAL: Chad Veich
If all goes as planned I should be able to offer the Robart 615's and a pair of 7/16'' diameter struts for around $180 or so. That's a substantial savings versus the Sierra gear. Having said that, I just picked up a set of the Sierra gear myself and they are VERY nice and will be going in my next Hellcat.
EJWash
#94
My Feedback: (60)
AZ
ORIGINAL: Craig-RCU
Neat Hellcat project, Chad. For the extreme budget conscious builder, Hanger 9 Hellcat or Corsair gear should work. I have these gear on my H9 Corsair. I also added some 3/8'' struts that I bought at VQ Models. They seem to be very close copies of Robostruts and are/were about half the price of Robostruts. They don't appear to be available right now. I don't know if they will be available again.
From the pictures of your unsheeted Hellcat wing on the first page of this thread, it looks like gear mount rails could be moved to the top of the wing fairly easily to accommodate the H9 gear. The H9 gear (1-3/8'' wide) is about 3/8'' narrower than the Robart 615s (1-3/4'' wide), so wider gear rails would be needed along with moving them to the top of the wing. The H9 gear with a $30 HS-75 retract servo and bell-cranks would be about $60 dollars all together, plus $7 for H9 Hellcat/Corsair wheels.
ORIGINAL: EJWash1
That is a killer price! Have you laid the two (Robart/Sierra) side-by-side?
EJWash
EJWash
ORIGINAL: tailskid
Chad, do you need any assistance? If so, give me a call...
Jerry
Jerry
ORIGINAL: fw190d9
Awesome work as usual Chad! The cat is a little small for me, but Im subscribing anyway just to watch. Keep up the great work.
Evan Q.
Evan Q.
A few updated pics. Not much looks different although a substantial amount of progress has been made. I now have my belly pan completed and fitted. My belly pan is removeable because I plan to put my air system in there. Plus, this allows for the wing bolts to be hidden. It does create a lot more work for the builder though and is not entirely necessary. This will be one of those options that each builder will have to decide on. I am also working on the enginer/muffler installation and you can see how the 61FX fits in the cowl. My Dad will be fabricating a custom muffler to get the exhaust out of the scale locations on the bottom of the cowl. This should be a relatively simple thing to build and I will cover its' construction in the build thread for those that would like to fabricate one of their own.
#95
Here they are side-by-side. Both are advertised as 100 degree retracts but the Robarts actually appear to be more like 95 degrees. Obviously the Sierra strut is a bit too short. I need to speak with Darrell and see if he has, or can make, the right length strut. I would recommend holding off on purchasing the Sierra gear until I can figure out just exactly which ones are the best option.
I see you're contemplating a 75" version. Wouldn't this mean back to the drawing board on the vacuum formed parts and canopy? How much more work would this be, and how much more do you think it would weigh, and will this knock it out of the .60 range?
Question, I like the idea of the engine being totally concealed and mounted upright. If one were to toy with the idea of mounting an inverted 4-stroke, what is the measurement from the center of the thrust line to the bottom of the firewall?
Thanks Chad!
#96
My Feedback: (60)
AZ
ORIGINAL: EJWash1
I see you're contemplating a 75'' version. Wouldn't this mean back to the drawing board on the vacuum formed parts and canopy? How much more work would this be, and how much more do you think it would weigh, and will this knock it out of the .60 range?
ORIGINAL: EJWash1
#97
MN
Thanks for the info Craig. That may be an option for someone willing to make the necessary changes. How have your gear held up in the H9 Corsair? I flew a H9 P-40 some years back and the gear seemed to work alright though they were definitely a bit ''wobbly''. I would probably only recommend the use of the H9 gear for folks who plan to keep their Hellcats very light.
Additionally my gear had a bit of slop in the hole in the mechanism for the wire. That was easily fixed by drilling out the hole to accept a bushing made out of brass tubing. I maidened a friend's H9 Corsair that was an updated version with the one loop wire gear, and I found the gear to be much improved. So, maybe the brass bushing wouldn't be needed on the updated gear. Another thing I did to improve my gear was to carve out the heel of the ball-cup. The angle between the two ball-posts is too extreme for the cups when the gear is in the retracted position. Carving out the heel alleviated binding that occurred. Bending the cup's threaded rod a bit can help with that too. I don't know if the updated gear require this mod either. My estimate is that the updated gear can handle a plane of up to 10 lbs, maybe a bit more if struts are used.
What will your dad be fabricating your muffler out of? I'll be interested to see his techniques.
#98
MN
FWIW, the single HS-75 retract servo that I use on my H9 Corsair offers 92 oz of torque for the pair of gear, or 46 oz for each gear at a cost of $30. Standard servos can be had for under $8 a piece and offer 42-47oz torque http://www3.towerhobbies.com/cgi-bin...?&I=LXTJJ7&P=7 So, that would be a cost savings of $14 over the single retract servo with a weight penalty of about 1.5 oz. Additionally, with two standard servos, no bell-cranks would be needed (reducing the overall mechanical resistance in the system, thus needing less torque to operate) and the servos can be slowed for scale retract speeds. I have been using two standard servos for the retracts on my World Models Zero 60 with no problems.
#99
It would definitely be out of the .60 size range and would probably end up somewhere around 14-18 pounds depending on the level of detail and finish. Just right for a 1.08-1.60 size two stroke, 1.50-2.20 four stroke, or 26-38cc gasser.
The cowling would conceal an inverted .91 4-stroke...
EJWash
#100
My Feedback: (60)
AZ
Thanks for the gear information Craig. I'm pretty sure I'll end up under 10 pounds so the H9 gear may be an option for those willing to make the necessary changes. With less detail and an iron on finish the airplane could probably be built to 8 1/2 or 9 pounds. I did a preliminary check of the CG today and I'm pretty certain the airplane will balance without adding any dead weight. Hope I'm not sticking my foot in my mouth here!
EJ, the step up to 1/7 scale would definitely result in an increase in cost. If I were to build the larger version I would strive to give it the potential to be a contest level airplane as the increased size would allow for a bit more weight / wing loading. I'm sure it would have a somewhat different target audience than the smaller version but I think there is a definite gap in currently available kits/plans for the 70-75 inch fighter types. The moderate increase in size also results in a substantially better flying airplane in my opinion.
