Reload this Page >
CMP 80" Zero Bash*****
Old 07-12-2015, 06:56 PM
  #376
77chickenhawk
77chickenhawk's Avatar
Thank you I appreciate that. I haven't had very much luck so far and searching for museums and such for selling to zero or P40
what kind of business do you have any Southern Cal?
Old 07-13-2015, 01:21 AM
  #377
LDM
My Feedback: (15)
I am in the consumer products industry, VP in Candy segement so we have a ton retailers and distributors in the market place
Old 07-13-2015, 11:57 AM
  #378
77chickenhawk
Sweet
Old 04-21-2016, 09:21 AM
  #379
cswann821
Hi everyone! After having this bird in a box for YEARS now I am FINALLY building her. I got my Retracts installed , went with Century Jet, and I have a DLE55 rear exhaust.
So I ended up cutting down the stock Motor box so I could keep my engine carb. fully exposed and not have to deal with cutting standoffs. Now I am trying to line up my motor box onto the front of the zero's fuse BUT the fuse has no hash marks like I've seen in other build pics and I believe the build diagram says that there should be. !!! I do have hash marks on my motor box..just not the fuse?
So I found this program /tool http://www.gsal.org/
to figure out engine offset or ...how much to the left I should move the center of my engine/motor box, to compensate for the 2 degrees of thrust angle build into the box mount. I am wondering about what to measure for my engine length input?? The DLE55RA engine itself is 171mm with standoffs...and I cut the motor box down to be about 32mm.,give or take a mm or 3. So my actual measurements are very close to the diagrams given 203mm for the distance from the firewall to the front of the cowl . Going with 203mm (8inches) engine length, with 2 deg thrust angle, I get an output number of about 7mm (0.28inch) in which to shift the vertical center line. Does this sound about right? Am I doing this right? This is the first time I've had to worry about thrust angels....
Oh and can someone confirm as far as 2 degrees right thrust... in respect to the fuse, I want to mount the motor box so the built in angle is to the right (the motor is angled to the right when sitting in the cockpit)....and I want to shift the vertical center point for the box itself to the LEFT. (looking out of the cockpit) CORRECT??
Thanks, Chris
Old 11-13-2016, 08:57 AM
  #380
77chickenhawk
Hello all. Been a long time sence be been here. Still have the zero. Even been tinkering with it adding more scale components. Make the carb intank ducting that is atop cowling. Had to make a plug then glass the two halfs and mate the two together. Turned out nice
ID:	2189834   Click image for larger version
ID:	2189835   Click image for larger version
ID:	2189836   Click image for larger version
ID:	2189837   Click image for larger version
ID:	2189838   Click image for larger version
ID:	2189839   Click image for larger version
Old 11-13-2016, 12:43 PM
  #381
jornmarius
Oh man ! that's awsome.
Had an accident 'bout a year ago.
I was ready for another flight, groundchecks and preflight done and I pushed the throttle all the way.
Unfortunately my head wasn't with me and as it picked up speed I guess I took off prematurely and to make the story short the plane hit one of the poles on our safetynet. I would like to mention the prop took a considerably chunk out of the pole!
Unfortunately the wing got a hit form the pole in return. Just infront of the wheel well. Rest is history.
Anyway.. picked up all pieces of the wreckage and meditated for a couple of days..The speed at impact was really low, ( tip stall speed ) so the fuse was mostly ok, the cowl was just knocked off, but the canopy got some cracks..
I decided to rebuild the wing and all.. with panel lines and rivets..
It was good help ( at least i thinks so,) to glue most parts together to get panels other parts for supporting the ones that had to be remade.. I remade almost all. even the main spar. After the buidling was done I used the glued toghether wing-skins for samles for the panel-line and paint-job.. they served me good. It was a lot easier doning this in small scale, as this is my first riveting job. I think I came out not so bad..
Havent flown yet..
Guess this sums up much of the process ;-)
ID:	2189869   Click image for larger version
ID:	2189874   Click image for larger version
ID:	2189875   Click image for larger version
ID:	2189876   Click image for larger version
ID:	2189877   Click image for larger version
ID:	2189878   Click image for larger version
ID:	2189879   Click image for larger version
ID:	2189881   Click image for larger version
ID:	2189882   Click image for larger version
ID:	2189883   Click image for larger version
ID:	2189884   Click image for larger version
ID:	2189885   Click image for larger version
ID:	2189886   Click image for larger version
ID:	2189887   Click image for larger version
ID:	2189889   Click image for larger version
ID:	2189890   Click image for larger version
ID:	2189891   Click image for larger version
ID:	2189892   Click image for larger version
ID:	2189893   Click image for larger version
ID:	2189894   Click image for larger version
ID:	2189895   Click image for larger version
ID:	2189897   Click image for larger version
ID:	2189898   Click image for larger version
ID:	2189899   Click image for larger version
ID:	2189900   Click image for larger version
ID:	2189901   Click image for larger version
ID:	2189902   Click image for larger version
ID:	2189903   Click image for larger version
ID:	2189905   Click image for larger version
ID:	2189906   Click image for larger version
Old 11-13-2016, 12:55 PM
  #382
jornmarius
And just to make it a tiny bit more scale I've started with scale exhaust..
Starting with two exis.. I have a plan of making a whole ring.. and this is a proof of consept before I take it further..
The first silicone tube tore apart.. I guess it could not take the not continous pressure and heat. Have made another attempt. not so much angles on this tmie .. and also aluminum tape to stop it form sucing togheter every other stroke..
But there's still the challenge of the canopy..
So if any of you guys have a good tip for making a new one or where to buy ( or if anyone got a spare) I'd be happy.
Cheers !
ID:	2189908   Click image for larger version
Old 12-10-2016, 03:32 PM
  #383
77chickenhawk
Good job
Old 12-10-2016, 07:55 PM
  #384
Duplicator41
Duplicator41's Avatar
https://vqwarbirds.com/product-categ...t-kits/page/5/
Try here.
Cheers,
Old 10-25-2018, 12:16 PM
  #385
77chickenhawk
Originally Posted by Bluffman
Your rivets are awsome, look better than mine, but i never ran out of glue, are you, painting it grey with the black blue cowl. Ian
hi everybody thought I would chime in and say something to everybody on the warbird thread. Hoping to find some inspiration to finish these projects
Old 10-26-2018, 12:13 AM
  #386
jornmarius
Hi guys ! My activity kinda stopped where I left you off..
I did a re-maiden on the new wing early in September. The wing flew flawlessly :-D
Due to no cowling ( the exhaust mentioned i the posts above did not work exactly to plan - so I have to take it off and re-do it at some point ) I did only a few rounds and passes, but had to land before the front got light.
I also got a new canopy which I considered crusial to get this bird fully operative again.
New canopy is purchased from Parkflyer Plastics : https://parkflyerplastics.com/cart/i...roducts_id=765
They also got canopy for 91" Zero.
Havent fitted it yet, but will do in due time for next season. :-)
