If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 101 to 125 of 161
  1. #101
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Just wondering how the Frank's have been doing lately! I finally began assembly of mine a couple weeks ago, and I just putter at it a little at a time. Have been working on the wings first per the plans, and have the flaps and ailerons hinged, and the 4 servos installed in the wings. Was going to install the control horns and linkages but found some 15mm washers are missing, so will go to ACE for that tomorrow. I decided on a Saito 180 for this plane after seeing a ESM Frank with this engine on You Tube, flying in Denver. Nice combo, so I went with it...found a good used 180 here on RCU. Need to get her done for our club warbird weekend during the Memorial Day weekend. Someone post up some pics or vids of their Frank to get my juices flowing more! Jon
    Carl Goldberg Ultimate 10-300 Brotherhood #01
    Club Saito #707
    P-47 Thunderbolt Brotherhood #97
  2. #102
    Join Date
    Aug 2002
    Buffalo Grove, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Even though I've had mine for a year, I'm afraid I also just started putting my Frank together. I have the wing together...used robart horns and mocked up the Sierra retracts. I just started the stabalizer. I think I'm going to use the pull-pull for the elevator even though I've heard some against them. I think I had pull-pull on my Dave Patrick Ultimate without problems. I'll be careful to keep them tight.
    I'm thinking of using a new JC-28 that's been sitting since I got it around a year ago. I've heard about the bad press on these engines, but I'll test run it before I decide whether to use it or not.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1731714   Click image for larger version.
ID:	1731715   Click image for larger version.
  3. #103
    Join Date
    Jul 2006
    Santa Fe, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Where can I get this cockpit kit?
  4. #104
    Join Date
    Aug 2002
    Buffalo Grove, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    VQ Warbirds has them.
  5. #105
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    ed42d, at least you got your wing halves joined. I am behind you. I used the stock horns for the ailerons, but don't like them all that much, so will use something else for the flaps and other surfaces. Maybe I can find some Robarts like yours. Doesn't attaching the Sierras to the blocks in the wings look like a little challenge? I think the laminated ply and phenolic board look like they were cut a little large for the Sierras, such that the mounting screws will be close to the edges of the wood. Jon
    Club Saito #707
  6. #106
    Join Date
    Aug 2002
    Buffalo Grove, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    For the Sierra's, I had to dremel the formers toward the top of the wing to get the retracts to sit square. Also the pin in the retract moves and I needed a little grove to get the pin by the former. I hope I didn't weaken the former too much.
    I've mounted the JC-28 and will probably have to add cowl blocks to the cowl ring similar what I saw someone do earlier in this thread.
  7. #107
    vik's Avatar
    Join Date
    May 2003
    Czech Republic
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    ORIGINAL: ed42d-RCU
    Hi
    Just a small info - the retracts as they come from Darell have the legs turned around.
    But than the gear doors are not flush.
  8. #108
    Join Date
    Aug 2002
    Buffalo Grove, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    ORIGINAL: vik
    thanks Vik...I didn't notice that. After looking at the other pics of the landing gear in this thread, I see what you mean. I'll have to turn them around later.
    I also tried to put the cowl on to see how the engine fits. Unfortunately, the front of the engine is hitting the bottom of the front cowl. I'd have to do some chopping which I would hate to do. I may have to look at other engines like the Zenoah that other guy's have used.
ID:	1735427   Click image for larger version.
  9. #109
    vik's Avatar
    Join Date
    May 2003
    Czech Republic
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    No problem
    I'm actually building second one as the first one was lost last year.
  10. #110
    Join Date
    Jul 2006
    Santa Fe, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Thanks ed42d. Ordered and on the way.
  11. #111
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Mine came turned the right way, but I am finding that with the gear in, the tires will hit the top sheeting (I don't have the well in yet), and so I am going to need to either dremel away the tip side of the mount in order to raise the tire in the well, or use shims/washers on the fuse side of the mount to accomplish the same thing. The mounts don't sit flat. ed42d is this the same problem yours had?
    Club Saito #707
  12. #112
    Join Date
    Aug 2002
    Buffalo Grove, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Haven't done much with the retracts except to mount them. I had to dremel some of the formers to get the retract to sit. I haven't tried to use the well. I may just paint the inside of the wing and not use the well.
    I'm about finished with the tail surfaces and mounted the cockpit. I only added a pilot to keep it simple.
ID:	1737288   Click image for larger version.
ID:	1737289   Click image for larger version.
ID:	1737290   Click image for larger version.
  13. #113
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Your landing gear plate might not lay flat on the wood mounts when you turn your struts around. That is what I mean by mine not laying flat. I think I will go to ACE tomorrow for washers (for shims) and wood screws to mount the LG. Where'd you get the pilot...is he the right scale? I need to get one. Jon
    Club Saito #707
  14. #114
    Join Date
    Aug 2002
    Buffalo Grove, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    My son gave me that pilot. He did the paint work. It seems to fit ok.
    ESM has a 1/6 scale pilot which I also have. It's a little larger and would need to be cut down at the base.
    I got that here:
    TBM
  15. #115
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    ed42d, thanks for the tip on the pilot at TBM! I am going to get one. Jon
    OOPS, the shipping is more than the cost of the pilot! Trapped again.
    Club Saito #707
  16. #116
    vik's Avatar
    Join Date
    May 2003
    Czech Republic
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Hi Guys
    Can you help me with this:
    what is the dimensions TY is mentioning in the build video (part 2) for the cockpit cut?
    Is it 1/4Β¨rear and 1/16Β¨ up front?
    Thank you
    http://www.youtube.com/watch?v=CLPJYlpb0NM
  17. #117
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Vic,
    Yak se mash!
    He says 1/4" at the rear, and 9/16 at the front.
    Casey
    Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft, BestPilots.com
  18. #118
    vik's Avatar
    Join Date
    May 2003
    Czech Republic
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Thank you Casey
    Jak se mam? dobre
  19. #119
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Neruzamin? lol its been too long since I've tried to speak your language. But I still remember the beautiful girl who taught me... Lol
    glad I could help
    Casey
  20. #120
    vik's Avatar
    Join Date
    May 2003
    Czech Republic
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Hi All,
    This is from my Mk.II
    New hatch for batteries and ESC placement
    I'm considering respraying it as well. But I might do it later in the year if it will survive the season
  21. #121
    captainron's Avatar
    Join Date
    Jun 2006
    PUEBLO WEST, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Hey guys,
    I have one of these RTF......I want to sell..........6 flights on it.
    email me, I'll give ya all the info.
    19th member of the ...."Not so scale, Almost ready to fly, soon to be scrap, Warbird Brotherhood '
    #51 P-47 Thunderbolt Brotherhood
  22. #122
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    My progress is still slow, but I have the Sierra retracts temporarily mounted in the wings now. I can tell this will give lots of toe-in. I think I see just one bolt that holds the strut to the casing...it is in the center of this pic. Is that what I use to rotate the strut to remove some of the toe-in? Thanks. Jon
    Club Saito #707
  23. #123
    vik's Avatar
    Join Date
    May 2003
    Czech Republic
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    yes that is correct
    You have to only permit it slightly. Than you will be able to rotate the leg or take it out.
  24. #124
    vik's Avatar
    Join Date
    May 2003
    Czech Republic
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Hi All,
    This is the pilot I got from Ty. I thing it is some sort of universal, but fits nicely.
  25. #125
    Join Date
    Jul 2002
    Stone Ridge, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    ORIGINAL: fockewulf37
    Hey guys here is an early mock up of the cockpit kit.......
    I don't have any more of these pilots ....
    Ty
    Ty, what pilot figure is that you are using? Are they still available?
    J F Sohm - AMA# 192350 - IMAA# 15145
    If you're not catching any flak, you're not over the target.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
