If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 126 to 150 of 161
  1. #126
    Join Date
    Mar 2002
    kannapolis, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Yes I still have them. Email me Fockewulf37@ctc.net
    tysplanes.com
    food for thought:\'\'\'\'If the enemy is in range, so are you..\'\'\'\'\'\'Tracers work both ways.\'\'\'\'
  2. #127
    vik's Avatar
    Join Date
    May 2003
    Czech Republic
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Hi All
    Small update:
    I made ducting for the oil cooler. Underneath there is a hole for hot air to go from the motor and ESC
    I hope to have it up and ready during this week
  3. #128
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Wow, I got my wing together with the servos and retracts installed. I don't have the LG doors or the "belly pan" on yet, but so far the wing weighs a hair over 5 pounds! I have to think that is typical, but it surprised me to feel the weight of the wing! BTW this is with Sierra retracts. Jon
    Carl Goldberg Ultimate 10-300 Brotherhood #01
    Club Saito #707
    P-47 Thunderbolt Brotherhood #97
  4. #129
    Join Date
    Dec 2001
    Litchfield Park, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    ORIGINAL: maukaonyx
    Wow, I got my wing together with the servos and retracts installed. I don't have the LG doors or the ''belly pan'' on yet, but so far the wing weighs a hair over 5 pounds! I have to think that is typical, but it surprised me to feel the weight of the wing! BTW this is with Sierra retracts. Jon
    Five pounds on a wing this size with retracts and flaps is not out of line at all. Pretty light actually!
  5. #130
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Thanks Chad...good to know! Jon
    Club Saito #707
  6. #131
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Would someone who used air retracts post a pic of their internals of the fuselage with the air tank in it? I am doing my first air retracts (Sierra) on this warbird. Thank you! Jon
    Club Saito #707
  7. #132
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    HELP pls...still looking for some help. I think the large tank sent to me by Sierra is too big. I had to saw away part of the bulkhead under the servo tray to slide the tank in there, and then the center servos will hit the that tank. Hmmmm, so I am thinking of getting a smaller tank, however I wonder if they have volume enough for the Sierras? Anybody with any ESM planes having the same prob and what was your solution. I would be grateful for some help. Jon
    Club Saito #707
  8. #133
    Join Date
    Mar 2003
    Springfield, VA,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Can't you put the tank in the belly of the plane? Secure it with velcro and you sould be ok.
    BobH.
  9. #134
    Join Date
    Feb 2011
    Comox, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    I have the ESM72" Spitfire. I use a standard size air tank with my Robart retracts and can get ten cycles on one air charge. I don't own anySierra retract gear, but I don't see why you should need a large air tank. I have large tank for my GS TF Corsair, but it's a 86"WS and will be close to 30LB and uses the Robart gear made for it.
    Try a regular size air tank and see how many cycles you get. If you get five solid cycles, that should be good enough. You can always add air after each flight, and in fact should do that anyway.
    I will try to send a pic of my Spit set up when i get home.
    Tom
  10. #135
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Bob H, I get the sneaking suspicion the plane will turn out tail heavy, so I want to put the tank at or forward of the CG, not behind, thus above (when the plane is upright) the servo tray.
    Me410, thanks for advice on the Robart tank. I will look it up...what size is yours? I only ask because itemss change over time. Would like to see your layout, so thanks for posting a pic, in advance. Jon
    Club Saito #707
  11. #136
    Join Date
    Aug 2002
    Buffalo Grove, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    I haven't done much work on mine...only tried to mount the Zenoah 26. It didn't fit completely in the cowl. I think i have the larger Robart tank. It should fit ok, but that's next.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1763501   Click image for larger version.
ID:	1763502   Click image for larger version.
  12. #137
    Join Date
    Feb 2011
    Comox, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Here's my pics, I will just try 2 at a time due to download size.
    What I call a standard Robart air tank is about 6 1/2" tall and about 1 3/4" across.
    While we all try to keep as much weight forward with a warbird, I think one of the things you can cheat on is the air tank. It's very light, but also bulky. Most of my planes have the tank behind the COG, so I have more room to get the heavy stuff forward.
    Tom
    Can't get the pics to work, will try again
  13. #138
    Join Date
    Feb 2011
    Comox, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Pic 1
  14. #139
    Join Date
    Feb 2011
    Comox, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    I used " Resizeit utillity " Lets see if that downloads better.
ID:	1763571   Click image for larger version.
  15. #140
    Join Date
    Feb 2011
    Comox, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    That worked well. just going to try the next size up at 450x600 pix
    BTY, that "stick" taped to the tank is to help secure the tank, the stick slides into a slot at the rearward bulkhead and then the velcro strap wrapsthrough the attachment glued to the fuse and keeps the tank from going anywhere.
    Tom
ID:	1763573   Click image for larger version.
  16. #141
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    The pics are helpful Me410, so thanks. That really illustrates how huge my tank is compared to yours. Mine looks more the size that ed42d shows in his plane. So I measured mine...it is 9 1/2" long by 2 1/2" diameter. I think I will be ordering a smaller tank from somewhere. Your pics also show me your valve installation, which is helpful. Thanks again. Jon
    Club Saito #707
  17. #142
    vik's Avatar
    Join Date
    May 2003
    Czech Republic
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Hi All
    I tried to add some weathering
    Just I'm not sure about the outcome
  18. #143
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Hello guys,
    Can I get a report on how you all like or dislike your KI84? I'm getting ready to move back to Oahu, so I need alittle something from the Pacific theater of operations I think. I would love an 80" Zero, but it's not been released as of yet(rumored to be in development though)
    So the Ki84 it will be, unless you all tell me it flys like a turd. I'm an electric guy, so I would be going that direction as well. What is the average weights on your builds? Sierras still available I assume?
    Pros and cons of this kit?
    Casey
    Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft, BestPilots.com
  19. #144
    Join Date
    May 2006
    Pta, SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Hi Casey,
    Had mine for a year or so, flies like a beaut. Powered by eflite power160 on 10s 5000mAh ( 2x5s ) 18x12 turnigy cherry wood prop, could go larger but is adequate at 1440 Metres asl where I fly here in sunny south africa. Just a tad over 7kg flying weight. Using esm retracts, so far so good even tho flying off grass field. Be aware that the pull-pull wires supplied are not the best you could use. I think this has been mentioned earlier in this thread.
    Fitted Ty's cockpit kit too. Looks good.
    Good machine, I think you will like it.
    The attached pic if it attaches, is just after the maiden.
  20. #145
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    jrtal,
    thank you sir! Thats exactly what I hoped to hear. I too will use the same setup as you have, (Eflite 160, CC HV120, TP 5000mAh 5 cell x2) Its a great setup ,I have it in 3 other planes as well.
    Now to get Ian Radshaw to show me how he weathered his(on VQ's site)
    Thanks again,
    Casey
  21. #146
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    https://www.youtube.com/watch?v=JSa6...e_gdata_player
    here is a link to Ians plane
    Casey
  22. #147
    rifraff's Avatar
    Join Date
    Jan 2005
    escondido, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    hey VIK that oil cooler is a great idea im going to do that to mine, she`s already for her maiden this weekend.
ID:	1824377   Click image for larger version.
ID:	1824378   Click image for larger version.
  23. #148
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    Nice looking plane Rifraff, how did you do the weathering? Silver pen and some 0000 steel wool?
    Casey
    Mine will probably stay in the box until I get moved back to Hawaii. I already have to build crates for 6 other giant scale warbirds...
    Btw...I'm not sure the cat approves lol. Looks like he's trying to smell it's tail to figure out what kind of beast it is LOL
  24. #149
    rifraff's Avatar
    Join Date
    Jan 2005
    escondido, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    thanks glazier808. the weathering I did with testors aluminum paint a small brush and several hours lol, I also pulled out my old airbrush kit and just went nuts adding the rest of the weathering.
    today was her maiden and she did great with the CG set at 105mm however I did need allot of down trim, not because she was tail heavy but because I installed the motor right side up so the
    motor sits below the center line so im gonna add more down thrust, but once she was trimmed she flue flawlessly.
    heres the pics from the field
    oops looks like I clicked twice on a pic
ID:	1825844   Click image for larger version.
ID:	1825845   Click image for larger version.
ID:	1825846   Click image for larger version.
ID:	1825847   Click image for larger version.
ID:	1825849   Click image for larger version.
  25. #150
    Join Date
    Aug 2004
    hendersonville, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KI-84 FRANK ESM
    g26i will fit fully enclosed
ID:	1826657   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
