T-28 Dave Platt
Reply
Old 11-30-2010, 06:22 PM
  #151
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: T-28 Dave Platt
Dean RCU,
How do you build your langing gear doors?
Boyd
maser is offline
Old 12-01-2010, 04:06 PM
  #152
Dean rcu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: maser
Dean RCU,
Boyd
Hi Boyd, After the bottom wing sheeting is done trace the doors onto the sheeting with a fine black marker. As I remember the outline for the doors was on Daves plans which makes it easy to cut them out and lay them on the wing to trace. flip them over for the other wing. Once you have them traced get some monocoat that you can see through( I use the clear) iron it on the area where the doors are adding about two inches around the edges. Then I cut 4 pieces of 5 oz. glass and a piece of 1 oz large enough to cover the door area with about an inch extra all around. Brush some epoxie reson on the monocoat and add your first piece on 5 oz. glass. Soake each piece as you add them on finishing with the 1 oz. piece.You will be able to see the outline of the traceing you did. After it has cured trace the doors on the glass lift the glass from the wing and get rid of the monocoat. Cut the doors out carefully and lay them on your wing tracings using some double face tape so they don;t move. Cut around them with a sharp exacto. Now you have a door which will fit snugly and with the shape of the wing, I did the dive brakes in the same manner.
Dean rcu is offline
Old 12-01-2010, 04:39 PM
  #153
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dean RCU,
Thanks. I have some boat fibergalss cloth. It's thick, do you think this is OK?
Boyd
maser is offline
Old 12-01-2010, 06:14 PM
  #154
Dean rcu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: maser
Dean RCU,
Boyd
I'm not sure of the weight on boat glass. Check with your local hobbyshop to see how thick the 5oz glass is to compair.
Dean rcu is offline
Old 12-01-2010, 07:13 PM
  #155
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dean RCU
The product Igot was from a auto paint store. It's called Sea-Glass by Evercoat. I looked it up on the internet and found out it's a 6oz cloth. 5 layers ought to do it. Plus the 1 oz at the end. Thanks so much.
Boyd.
maser is offline
Old 12-06-2010, 05:15 PM
  #156
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This next sequence will show how I built the belly pan and middle trailing part of the wing.
ID:	1531126   Click image for larger version
ID:	1531127   Click image for larger version
ID:	1531128   Click image for larger version
ID:	1531129   Click image for larger version
ID:	1531131   Click image for larger version
maser is offline
Old 12-06-2010, 05:35 PM
  #157
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More of belly pan etc.
ID:	1531148   Click image for larger version
ID:	1531149   Click image for larger version
ID:	1531150   Click image for larger version
ID:	1531151   Click image for larger version
maser is offline
Old 12-06-2010, 05:40 PM
  #158
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now for the main gear doors.
ID:	1531160   Click image for larger version
ID:	1531161   Click image for larger version
ID:	1531162   Click image for larger version
ID:	1531163   Click image for larger version
ID:	1531165   Click image for larger version
maser is offline
Old 12-13-2010, 05:05 PM
  #159
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are the completed cut and sanded doors. I made 3 sets just in case. By the way, I made mine a 2 piece set rather than the 3 piece set. For me it would have been to complicated to do the 3 piece set.
ID:	1533874   Click image for larger version
maser is offline
Old 12-13-2010, 05:37 PM
  #160
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I made a gross miscalculation regarding my decision tobuy the Robart 85 degree main retracts. I found a sight that recomended the 90 degree (635RSLP)Robart gear. The following pictures show how I corrected this mistake. I was not going to do a major rebuild to correct this problem, so will live with my mistake.
Sierra Giant Scale now puts out a 1/6th scale retract set for the Dave Platt T-28. This set also has the correct angles for the gear. When I build a 2nd T-28, I'll purchase this set. I had already bought the Robart gear prior to Sierra comming out with theirs.
Another thought might be the construction of the belly pan. Maybe it's not deep enough. I will be anxious to hear from anyone else who may have an idea as to what went wrong.
ID:	1533882   Click image for larger version
ID:	1533883   Click image for larger version
ID:	1533884   Click image for larger version
ID:	1533885   Click image for larger version
maser is offline
Old 12-17-2010, 04:07 PM
  #161
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok guy's
I think I figured this out. I based my gear on the dihedral of the wing relative to a horizontal plain In other words, the dihedral is at 85 degrees to the horizontal plain.
I measured the degrees ofthe gear in the retracted position from the frontal position of the wing according to theplansand found that it was at 90 degrees. The difference of 5 dgrees makes the gear set lower into the wheel well.
redtail, are you a geometry teacher? This is a geometry problem.
Any thoughts?
maser is offline
Old 12-27-2010, 06:17 PM
  #162
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following is how I made the dive brake.
ID:	1538824   Click image for larger version
ID:	1538825   Click image for larger version
ID:	1538826   Click image for larger version
ID:	1538827   Click image for larger version
maser is offline
Old 12-27-2010, 06:31 PM
  #163
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More of dive brake.
ID:	1538835   Click image for larger version
ID:	1538836   Click image for larger version
ID:	1538837   Click image for larger version
ID:	1538838   Click image for larger version
maser is offline
Old 12-30-2010, 06:24 PM
  #164
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following is a continuation of the dive brake installation.
ID:	1540071   Click image for larger version
ID:	1540072   Click image for larger version
maser is offline
Old 12-30-2010, 06:39 PM
  #165
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Continuation of dive brake installation.
ID:	1540087   Click image for larger version
ID:	1540088   Click image for larger version
ID:	1540089   Click image for larger version
ID:	1540090   Click image for larger version
maser is offline
Old 12-31-2010, 02:04 AM
  #166
lkahn4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Boyd,
Let me say you are doing an awesome job, can't wait to see the finished product.
Have a Happy New Year and my wishes for an early spring ith temps higher than 60
Larry
lkahn4 is offline
Old 12-31-2010, 05:16 AM
  #167
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Larry,
And Happy New Year to you also.
Boyd.
maser is offline
Old 12-31-2010, 08:21 AM
  #168
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great work of art there....keep it going!
tailskid is offline
Old 01-07-2011, 06:52 PM
  #169
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More of dive brake.
ID:	1543857   Click image for larger version
maser is offline
Old 01-09-2011, 02:52 PM
  #170
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following will show how I made the engine mount and mounting plate for the cowl.
PRIOR TO DRILLING THE HOLES ON THE FIREWALL TO MOUNT THE ENGINE MOUNTING BACK PLATE, MAKE SURE THE COWL AND CENTER LINE OF ENGINE THRUST ARE ALIGNED. I PUT THE ENGINE IN PLACE AND THE COWL IN PLACE AND MOVE THE ENGINE MOUNT ACCORDINGLY.
ID:	1544860   Click image for larger version
ID:	1544861   Click image for larger version
ID:	1544862   Click image for larger version
ID:	1544863   Click image for larger version
maser is offline
Old 01-09-2011, 03:18 PM
  #171
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More of engine mount.
ID:	1544872   Click image for larger version
ID:	1544873   Click image for larger version
ID:	1544874   Click image for larger version
ID:	1544875   Click image for larger version
ID:	1544877   Click image for larger version
maser is offline
Old 01-09-2011, 05:26 PM
  #172
lkahn4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Boyd,
Very nice, but I do have a question. How are you going to mount the cowl to the fuse? The ring you made for the back of the cowl doesn't look deep enough to screw into the blocks. But excellent work non the less
BTW, order is going out for the kit by end of week and should have the gear by April
Talk soon
Larry
lkahn4 is offline
Old 01-09-2011, 06:16 PM
  #173
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Larry,
I used a 1/4" ply back. It fits, and don't anticipate any problems. By the way, did you get my e-mail regarding sending you the disk. I was asking for your home address to send it to.
Boyd.
maser is offline
Old 01-09-2011, 06:17 PM
  #174
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since the screws to attach the cowl are internal, I had to make a special tool to be able to screw the cowl to the firewall.
ID:	1545004   Click image for larger version
ID:	1545005   Click image for larger version
ID:	1545006   Click image for larger version
ID:	1545007   Click image for larger version
maser is offline
Old 01-09-2011, 06:36 PM
  #175
maser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
By the time most of you recieve my build with pictures, I have already completed certain portions of the project.
If you have any comments or suggestions, please feel free to let me know of another way or a better way to do things.  This is how I can learn for further projects, or, I may be able to change something prior to final completion.
maser is offline
Reply
Display Modes
