If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 23 of 41 FirstFirst ... 13212223242533 ... LastLast
Results 551 to 575 of 1013
  1. #551
    Join Date
    Jun 2010
    Leduc, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ESM LA-7 From VQ Warbirds
    Also, I see a few who installed thefalse radial engine inserts in their La-7, but has anyone attemptedthe engine coolingl fan as found in the real La-7?
    Cheers,
    Peter
  2. #552
    Join Date
    Dec 2007
    Davison, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Peter,
    The LA-5/7 did not have a cooling fan.... I' thought it did and you can find lots of statements about the "fan" from people mentioning it but when you really look at it and dig you'll find it what looks like a fan is actually a sliding vent that opens when needed.
    This video is the best example I can find of the bit you're talking about. Look at 5:30 - 6:00 in this video.
    [youtube]http://www.youtube.com/watch?v=nHfEnNPp6Ds[/youtube]
    That Gene Barton Spinner fills the nose up pretty good. I don't think I'll need a fan/vent/dummy motor as much as I like the look of those things. The look will be correct and not leave a huge hole like you might think.
    Hope that helps.
    Joe
  3. #553
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Correct Joe,
    They were more of a shutter, that could be opened or closed as needed. Looks like a fan when it's in it's open position though I guess.
    Casey
    Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft, BestPilots.com
  4. #554
    Join Date
    Jun 2010
    Leduc, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Huh, imagine that. I always thought it was a fan like the FW-190; even the "blades" looked like they have pitch on them.
    Thanks for the correction guys.
    Now that you all have stated so, I see in a couple of Googlepictures where the vents are fully closed. I should have clued in because it was only in August when I was a local airshow andthere were 2 Nangchang CJ-6s on display which have the same cowl vents.
    Good to know that Gene's spinner will cover in most of the cowl.
    Cheers,
    Peter
  5. #555
    Join Date
    Mar 2010
    Shrewsbury, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Regarding installation of the engine on the LA-7, the instructions state to install the engine right on the center of the firewall (i.e. with the propeller/crank shaft directly over the center hole in the firewall).  I plan on using a DLE 35RA engine.  Should I install this engine slightly above the center of the firewall to counteract the tendancy to climb?  Or should I just follow the instructions and put it right on center?  If anyone has had any experience, please let me know.  Thanks   Art M
  6. #556
    Join Date
    Jun 2010
    Leduc, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Folks,
    I am thinking of purchasing the electric retracts for the LA-7 from LikesLine Retracts. does anyone have experience with these? Qaulity and reliabiliy?
    http://www.thelikesline.com/
    Cheers,
    Peter
  7. #557
    Join Date
    Jan 2002
    Hollywood, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So whats the consensus on motor choice. Should I go with a DLE 35 or a 55? I am thinking about getting one and would like to see what you guys think. Thanks
  8. #558
    Join Date
    Dec 2006
    Heber, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I went with the XYZ 53cc twin mostly for smoothness. If I wasn't worried about smoothness, I'd go with the 55. It says right in the instructions and on TBM's website that the model is inherently tail heavy and needs a little weight up front. Might as well be weight that gives you something vs dead weight in my opinion.
    BUT... I'm just unpackaging mine and starting the build - so what do I know....
    Mine will be heavy. Air retracts, 53cc, smoke system, cockpit. We'll see how it goes I guess.
  9. #559
    Join Date
    Nov 2005
    Auckland , , NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RCFAN450 is correct. If you have to add weight - make it do something. No model that I know of has ever crashed due to TOO MUCH POWER javascript:void(AddText('','_image/s4.gif'))
    I have the Saito 325 radial in mine which is quite heavy. I did not require any additional weight to get the c.o.g. correct. I was able to use my flight power packs to fine tune the balance over a few flights to get the bird flying with the feel I preferred. my A.U.W is close to 24pounds. It`s no lite weight but it flies nice and with plenty of speed.
  10. #560
    Prekin's Avatar
    Join Date
    Jan 2008
    Brno, CZECH REPUBLIC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My La-7 flew with the ROTO 35V and now I flying with ROTO 35Vi. I saw it with the XYZ 26, but it hasnยดt power reserve. In my opinion if you want to have realistic fly, you should use engine between 30-45ccm. With bigger engine it will be acrobatic special.
    God created aircraft mechanics, so pilots can have heroes too.
    Scale accessories at: www.jpwarbirds.wbs.cz
  11. #561
    Join Date
    Jan 2002
    Hollywood, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I hear the spinners are no longer available. What are you guys doing about that. Thanks
  12. #562
    Join Date
    Sep 2005
    monterey, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    stuka, I just bought a MPI 5" 3 Blade spinner. Perfect fit. I then painted the spinner flat red with Testors spray enamel. Part#1250 also a perfect match for the plane. S Mullis
  13. #563
    Join Date
    Jan 2002
    Hollywood, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    smullis
    Excellent Thanks for the idea.
  14. #564
    Join Date
    Dec 2006
    Heber, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey guys, I'm finally building my La-7.
    I don't want to use control horns that protrude through the other side of the aileron and have simply screwed the horns into the aileron and flaps on one side (hardened the holes with CA, CA'd the screws in even after that). What have you guys done?
    For electric I wouldn't worry at all, but mine is gas and I'm kinda wondering if I shouldn't just stick the dumb rod all the way through the wing and go that route instead. It just doesn't look scale. Thoughts?
  15. #565
    Join Date
    Dec 2006
    Heber, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here's what I'm talking about. Nevermind, the picture thing wouldn't work, getting some sort of error.
    I've pulled really hard (harder than I should have probably) on the horns and they all seem really strong so I'm going to fly it this way. Mostly just curious if anyone else here has done the same. I would be less comfortable if the ailerons were bigger but I have 40 sized planes with bigger ailerons than this thing secured the same way.
  16. #566
    Join Date
    May 2011
    Litchfield Park, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That is what I did with mine, I used the 3 point Hanger 9 control horns and drilled and hardened the holes, then cut away the covering and glued and screwed them in. I have done this on other planes and the only problem I have had is removing them :-) Who knew that the glue actually works!
    Cheers
    Rick,
    Spitfire Brotherhood #188
    P-39 Brotherhood #25
  17. #567
    Join Date
    Dec 2006
    Heber, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I didn't remove the covering and glue it, but I could easily. Just one more step to make sure I'll never get it off ... or it won't vibrate off. Thanks for the reply AZThud.
  18. #568
    Join Date
    Dec 2006
    Heber, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I got the cockpit done. I probably could have built the plane with the same amount of time I spent on the cockpit, it was fun though.
    I'll be surprised if half these parts still exist after the first few flights with a gas motor.
    I'll also be surprised if the gunner sight survives past me building building the plane. I'm pretty sure I'm going to forget it's there and set the plane on it while working on something else.
    Now I need a russian to pilot this thing!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1814911   Click image for larger version.
ID:	1814912   Click image for larger version.
ID:	1814913   Click image for larger version.
ID:	1814914   Click image for larger version.
ID:	1814916   Click image for larger version.
ID:	1814917   Click image for larger version.
ID:	1814918   Click image for larger version.
ID:	1814919   Click image for larger version.
  19. #569
    Join Date
    Oct 2002
    Sedona, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rcfan450
    I wouldn't worry too much how they look on the ground. You can't see them in the air. The wing is "stretched" for lighter wing loading and easier flying so it is not truly scale anyway.
    The plane is a great flier but check both wing and stab incidence and get them as close to zero as possible. Out of the mold, the plane will climb.
  20. #570
    Join Date
    Oct 2002
    Sedona, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: smullis
    stuka, I just bought a MPI 5'' 3 Blade spinner. Perfect fit. I then painted the spinner flat red with Testors spray enamel. Part#1250 also a perfect match for the plane. S Mullis
    Hopefully, your spinner was more true than the MPI 5" spinner I bought.
  21. #571
    Join Date
    Dec 2006
    Heber, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: LA7flier
    ORIGINAL: smullis
    Hopefully, your spinner was more true than the MPI 5'' spinner I bought.
    Speaking of spinners, TBM has some. Just ordered a red one.
  22. #572
    pilotorc4's Avatar
    Join Date
    Nov 2006
    norcross, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you want a full body pilot you will have to do what I did.
    check out my posts on pg. 11
    all the parts I used were found on e-bay and I have a list of the accesories I purchased on one of those posts, there are also pictures of WWII Rusian pilots I used to try to duplicate the pilot.
    I failed to take pictures of the finished pilot once I had found the right accesories for it but these pictures show what it looked like before I changed the parachute and the head gear.
    also on e-bay there is a guy that sells the RUsian pilot uniform insignias in 1/6 scale.
    your cockpit looks great by the way.
ID:	1815000   Click image for larger version.
ID:	1815001   Click image for larger version.
  23. #573
    Join Date
    Dec 2006
    Heber, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks pilot, I'll keep my eyes out on ebay. I went there once and saw one I really like, but it was $120. So... still looking. I don't mind piecing it together if I have to, would be nice if there was a good authentic russian out there but they don't seem to be too popular.
  24. #574
    pilotorc4's Avatar
    Join Date
    Nov 2006
    norcross, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    check this items out on e-bay.
    item # 290789385654 chinese pilot, this has most everything you will need and even the flight helmet could be used.
    item# 251162012656 gogles
    item# 170656607072 insignias
    I cant find the parachute right now nor the leather flight cap
    you will need the parachute form one of the U.S.navy 1/6 scale and the flight cap from either the 1/6 IJN pilot or the Crazy Dummies 1/6 german pilot, they come up for sale every now and then. you'll have to keep an eye out for them.
  25. #575
    Join Date
    Dec 2006
    Heber, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the tips!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
