ESM LA-7 From VQ Warbirds
Reply
Old 10-26-2012, 01:15 PM
  #576
pilotorc4
pilotorc4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ESM LA-7 From VQ Warbirds
Glad to be of help,
I also think they should come out with pilots for other nations also, I'm working on a modern day pilot for a big scale Mig 29 and it has been hard to duplicate.
this is what I have come up with so far.
keep up the good work on your LA-7
ID:	1815031   Click image for larger version
ID:	1815032   Click image for larger version
pilotorc4 is offline
Old 10-27-2012, 11:33 AM
  #577
Prekin
Prekin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anybody know, where can I find the colour pictures of the La-7 instrument panel? I want to use it as a base desk for the intrument panel.
Prekin is offline
Old 10-30-2012, 09:40 AM
  #578
AZThud
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might be able to find something at this site
Good Luck
http://scalemodels.ru/modules/photo/...show=12&min=24
Cheers
AZThud is offline
Old 10-30-2012, 09:45 AM
  #579
rcfan450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah man! I painted some stuff wrong! Thanks for that link AZThud, there are some good pics there.
rcfan450 is offline
Old 10-30-2012, 09:47 AM
  #580
Prekin
Prekin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the link.
Prekin is offline
Old 10-30-2012, 06:06 PM
  #581
rcfan450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you guys just line up the paint markings (half white and half blue) and drill away on the horizontal stab alignment? It seems really close but almost appears like it would make the plane nose dive, hard to tell.
rcfan450 is offline
Old 10-30-2012, 07:16 PM
  #582
rcfan450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: aminklein
Be sure to use incidence meters on the wing, horizontal stab and thrust lines. I am flying my third EsM LA7 (I do like them) but all of them come out of the jig with a tendency to climb.....putting about 1 degree of positive incidence on the horizontal stab ( while keeping the wing at zero) levels this one out nicely
I don't have a incidence meter unfortunately so I'll just have to "wing" it. I'm not sure if ESM figured out this issue on their own and changed things cause it does appear that the stab is already pointed in a direction to force the plane down just a tad. I'm gonna go for it and hope for the best.
My only question now is: What happened to your other two ESM's aminklein?
rcfan450 is offline
Old 10-31-2012, 08:12 AM
  #583
stuka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What are you guys doing for a pilot?
stuka is offline
Old 11-01-2012, 08:45 AM
  #584
AZThud
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got my Pilot from Scale AirCrew Supplies. Boris (Inamed him :-)) is a work of art, and is very authentic, Mr. Morely did a very nice job. That is the good news, the other side of the equation is that he was pretty expensive at 109 pounds plus shipping etc.
URL: http://www.scaleaircrewsupplies.co.uk/
Cheers
AZThud is offline
Old 11-12-2012, 06:29 PM
  #585
rcfan450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey fockewulf37, Thaba Raptor, and jmohn (or anyone else who has done this) - can you guys post a final pick of how your tail wheel setup went together? I found pics of your initial installs in this thread (pages 3, 5, 8) but no final pic of how the bay doors actually work or if the rudder cables ever got in the way of the hinges for the doors. Are you actuating those doors on the same servo that is retracting the wheel somehow?
I also see that you have a servo (or air retract) working the retract portion of the setup but what about the turning part?
I'm contemplating having the doors glued solid and leaving a hole for the wheel to retract in/out of, but it would be much funner have doors that worked.
...cockpit done, main wing done, engine installed, elevators done, mufflers tapped for smoke... much left to do...
PS - 1" DLE 30 standoffs worked absolutely perfect for fitting the XYZ 53 to the right location for prop clearance on the cowl. Gives about 1/4" clearance.
rcfan450 is offline
Old 11-12-2012, 09:08 PM
  #586
rcfan450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Figured out how I'm gonna do the steering and retract - any help on the the functionality of the doors would be much appreciated....
rcfan450 is offline
Old 11-20-2012, 07:22 AM
  #587
rcfan450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok some of you say 168mm is too tail heavy for cg. Some are going 155-160ish. After having flown the plane a bit, have any of you gone back and changed to 168 again or are you leaving your planes cg around 160?
rcfan450 is offline
Old 11-20-2012, 02:01 PM
  #588
AZThud
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have flown mine well over 50 flights could be close to 100, I have mine up around 155 and have no intentions of moving it. Yes when inverted Ineed to lean hard on the stick to maintain level flight, but Ifly it scale and I prefer it nose heavy, I have the Seirra gear on it with no mods to the wing/mount point and the plane has never once come close to coming up on the nose. I know that is a long winded reply to no I have no intention of moving it. :-)
Cheers
AZThud is offline
Old 11-20-2012, 02:11 PM
  #589
rcfan450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your reply. The reason i asked is because mine is looking like it's gonna be right at stock, 168. I was hoping that isn't too tail heavy. The reason i bought this plane over other warbirds was for it's tendency to NOT nose over, so your comment about that makes me happy.
rcfan450 is offline
Old 11-28-2012, 07:47 PM
  #590
rcfan450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well my plane is done, CG is at 165mm or so. I'd like it to be 160 but I'll fly it as is and see how it does.
Speaking of flying, just tonight I was tidying up some last things, hoping to fly it this weekend. I turned everything on to check controls and the ignition for my XYZ 53cc started making the plugs spark every half second or so. So I took it outside and tried to fire it and it won't go. uuuggghhh!! I bench tested the motor about a month ago and it ran great. Super smooth. I think my ignition is a dud. Now I'm just hoping Octopus RC can help me out so I can get this thing in the air. It is ready to go.
rcfan450 is offline
Old 11-28-2012, 09:03 PM
  #591
rcfan450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just wanted to post a follow up. Octopus RC is AWESOME! They are going to send me a new ignition. I don't know about you guys but of all the other companies I have dealt with in the rc world, some American, some Chinese - none of them are as quick to reply and as helpful with customer service. To me, customer service is everything. I am going to use Octopus RC for all my future rc needs.
rcfan450 is offline
Old 12-08-2012, 01:53 AM
  #592
Prekin
Prekin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I decided to remake my La-7 into the La-5FN, so I started with the new air intake for the compressor.
I want to have opening canopy, so this is the reason, why I prepared form for the fibreglass canopy frame.
The next step will be oil cooler and retractable tail wheel, because, I´ve hadn´t it yet.
ID:	1827680   Click image for larger version
ID:	1827681   Click image for larger version
ID:	1827682   Click image for larger version
Prekin is offline
Old 12-16-2012, 02:30 AM
  #593
Prekin
Prekin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pictures of my progress. I made a forms for the oil cooler and air intake from the depron (building foam).
Now I´m waiting for the fibreglass result.
I´ve also starded with the changes of the thail wheel. It will be pneumatic as the main landing gear.
ID:	1830617   Click image for larger version
ID:	1830618   Click image for larger version
ID:	1830619   Click image for larger version
ID:	1830620   Click image for larger version
ID:	1830622   Click image for larger version
ID:	1830623   Click image for larger version
Prekin is offline
Old 12-16-2012, 08:10 AM
  #594
Laurent45
Hello , i m very interesting in your project to pass your la 7 to la 5fn What is your documentation for the modifications??? Because central section of thé wing is completly different
Laurent45 is offline
Old 12-16-2012, 08:25 AM
  #595
Prekin
Prekin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Laurent,
I am pleasured of your interest.
I have Squadron Signal Lavochkin in action and MBI Lavočkin La-5, All Russian fighters.
As base of the documentation I have russian book and pictures of the Lavočkin La-5FN. The next is manual for the pilots and aircraft engineer from the August 1944.
Prekin is offline
Old 12-16-2012, 08:33 AM
  #596
Laurent45
Okey great i will follow your work with big attention!!    Is it possible to have à copy file of the manuel   I found it in the past but i lost it (((
Old 12-17-2012, 04:58 AM
  #597
Prekin
Prekin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The manual which you want I have only in the paper form. In PDF I have manual for the La-7 and EKSMO La-5 both of them are in azbuka and they are too large for the upload.[]
Here are some new pictures.
ID:	1831062   Click image for larger version
Prekin is offline
Old 12-19-2012, 10:36 AM
  #598
Laurent45
what a pity)) okey hope u will continue this project with pictures i will copy u in the futur
Old 12-20-2012, 10:00 AM
  #599
Prekin
Prekin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, I tried to make it smaller, but it is still too huge. I think about the upload on some server.
I made some small progress, but It is small, because I have to study.
Here is the final look of the tail wheel.
ID:	1832256   Click image for larger version
ID:	1832257   Click image for larger version
ID:	1832258   Click image for larger version
ID:	1832259   Click image for larger version
Prekin is offline
Old 12-23-2012, 02:08 PM
  #600
Laurent45
hi prekin take a look to this http://aircraftdrawingsdownload.com/...5_drawings.php it's a good draw of la 5F but many parts are same as la 5 fn
Reply
Display Modes
