Reload this Page >
ESM LA-7 From VQ Warbirds
Old 03-10-2013, 06:45 AM
  #701
Prekin
My Feedback: (19)
Prekin's Avatar
Default RE: ESM LA-7 From VQ Warbirds
Work is done! Today IĀ“ve done wear out and balanced it. Dry weight is 8305g. It is approximately 500g than before the remake. Here are the pictures.
Now I must find some good scale pilot.
ID:	1860253   Click image for larger version
ID:	1860254   Click image for larger version
ID:	1860255   Click image for larger version
ID:	1860256   Click image for larger version
ID:	1860257   Click image for larger version
ID:	1860258   Click image for larger version
ID:	1860259   Click image for larger version
Old 03-10-2013, 07:16 AM
  #702
glazier808
glazier808's Avatar
You've done a great job with the makeover!
Casey
Old 03-11-2013, 01:55 AM
  #703
nicandre94
Hi
I am from France and i show you some pictures of my LA7 ESM with JC Evo 30 engine and ESM retracts.
ID:	1860634   Click image for larger version
ID:	1860635   Click image for larger version
ID:	1860636   Click image for larger version
ID:	1860637   Click image for larger version
ID:	1860638   Click image for larger version
Old 03-11-2013, 03:14 PM
  #704
SU-31 flyer
SU-31 flyer's Avatar
Very nice!!
Old 03-12-2013, 04:35 AM
  #705
Prekin
My Feedback: (19)
Prekin's Avatar
It looks good. I chose very good propeller. Mr. Fiala makes the best propeller in the Czech Republic!
Old 03-12-2013, 11:29 AM
  #706
nicandre94
yes Fiala are very good propellers and cheap.
I forgot to say that I put a ZDS canister on my plane, and now it is not too much noisy. I made a 45 mm hole behing the engine.
Old 04-08-2013, 04:36 AM
  #707
dgiatr
dgiatr's Avatar
i have an rcg 50 cc on it with fiala 22x8 3 blade and i am very happy with that setup!
Old 04-14-2013, 08:21 AM
  #708
dgiatr
dgiatr's Avatar
[youtube]http://www.youtube.com/watch?v=G5gUjqVL7io[/youtube]
Old 04-15-2013, 03:32 AM
  #709
Prekin
My Feedback: (19)
Prekin's Avatar
What happened, did you lost air from the air system? Could you show some pictures of the plane after the belly landing?
Old 04-15-2013, 06:00 PM
  #710
n8622t
My Feedback: (8)
Prekin yer my hero....awesome job!!! When I start my LA7 I would like to get your help on some of my ideas
Old 04-15-2013, 06:14 PM
  #711
n8622t
My Feedback: (8)
Nice save dgiatr
Old 04-15-2013, 09:07 PM
  #712
Prekin
My Feedback: (19)
Prekin's Avatar
Thank you n8622t, IĀ“m very pleasured. You can write here in this thread or PM, I will answer you, but IĀ“m sure, you wouldnĀ“t need my help.
Old 04-15-2013, 09:14 PM
  #713
n8622t
My Feedback: (8)
Thanks Prekin I will look forward to your help
Old 04-16-2013, 08:00 AM
  #714
dgiatr
dgiatr's Avatar
ORIGINAL: n8622t
Nice save dgiatr
thank you n8622t, air valve didnt work because it was removed from its position due to engine vibrations......and insufficient support!
plane damage was minornly propeller and receiver antennas were damaged (i always put receiver antennas outside and underneath plane body)
Old 04-16-2013, 09:29 AM
  #715
Prekin
My Feedback: (19)
Prekin's Avatar
This time IĀ“m very close to finish all works on my La-5FN. The fuel tank I made from the plastic bottle from some juice, the shape is very good for the instalation. The air tank is up to the fuel tank. It was the biggest problem, because I had it on the wing, but now I have scale cockpit and between the wing and the cockpit isnĀ“t enough space. []
The last problem which I dealing now is the scale spinner. I canĀ“t found anyone which fits perfectly.
ID:	1872679   Click image for larger version
ID:	1872680   Click image for larger version
Old 04-16-2013, 10:31 AM
  #716
LA7flier
...why not build your own? You can get correct shape...
http://www.rcscalebuilder.com/forum/...21&PN=1&TPN=93
beautiful job
Old 04-16-2013, 11:08 AM
  #717
Prekin
My Feedback: (19)
Prekin's Avatar
I still think about it, but the easier way is to buy one. And if I made it by myself, it could be unbalanced it will be difficult to balance it. IĀ“ve just did on my CMP Zero.
Old 04-16-2013, 11:17 AM
  #718
AZThud
What I did for my spinner is use the one from the Hanger 9 60 size Bluenose mustang. The shape is a little off but the diameter is pretty close, mine was something like 20 dolllars and for that price I could live the shape being a little off. I painted it with some colour match paint from the local hardware store.
Just a Thought,
Cheers
ORIGINAL: Prekin
I still think about it, but the easier way is to buy one. And if I made it by myself, it could be unbalanced it will be difficult to balance it. I´ve just did on my CMP Zero.
Old 04-17-2013, 08:45 AM
  #719
Prekin
My Feedback: (19)
Prekin's Avatar
Thank you for your advice, IĀ“ve just found MBL spinner. http://shop.lindinger.at/product_inf...ducts_id=69651
The shape looks, it could be good, maybe it could be the solution of my problem.
Old 04-17-2013, 05:44 PM
  #720
sgrady
sgrady's Avatar
Finally finished this one
50 CC Twin
ID:	1873122   Click image for larger version
ID:	1873123   Click image for larger version
Old 04-18-2013, 08:52 AM
  #721
JeffH
My Feedback: (43)
Does anyone know if a Saito 5 Cylinder will fit in one of these?
Old 04-21-2013, 03:07 AM
  #722
Prekin
My Feedback: (19)
Prekin's Avatar
Today I did the first roll out with my La-5FN. During the taxiing I found out that the tail wheel doesnĀ“t work well, sometimes it unexpectedly close, but IĀ“ve just found out the trouble.
I took some picture, here they are.
ID:	1874732   Click image for larger version
ID:	1874733   Click image for larger version
ID:	1874734   Click image for larger version
ID:	1874735   Click image for larger version
Old 04-21-2013, 05:31 AM
  #723
OldScaleGuy
OldScaleGuy's Avatar
Very nice plane Prekin. Did you fly it today?
Old 04-21-2013, 05:42 AM
  #724
Prekin
My Feedback: (19)
Prekin's Avatar
Thanks Steve!
No, I didnĀ“t fly it today. I must set a mixture on the engine, because I get only 4500 rpm and the other thing is too windy weather today. I hope I will fly it next weekend.
Old 04-21-2013, 05:47 AM
  #725
OldScaleGuy
That's good, if it is not ready or the weather is not right is it best to wait. Many guys at our airfield always push others that have new planes to get them in the air. Not a good way, take your time.
