help for build an naca
Hi guys i want try at build an naca for an f-15r someone please tell me how to build the NACA. After two weeks of work in the end I came to this point but now I can not go .... You SUGGESTIONS?
RE: help for build an naca
YES MY FRIENDS! the your response is correct.i want build bonnet for an F-15 reporter 1-5 scala.... but for the moment nothing is sure!
i want try only if everything is feasible.
The problem is that I do not know what is the procedure to do with the foam depron. "I opted for this because it seemed" the most hasty" and easy. The problem is that now I can not find the right position for the sheet balsa.[:@]
