Knowledge Quiz for Warbird wiz
Old 02-27-2012, 05:16 AM
  #6576
MajorTomski
MajorTomski's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Knowledge Quiz for Warbird wiz
Sounds like you're describing the WACO assault glider. And the one-off with twin engines.
MajorTomski is online now
Old 02-27-2012, 07:07 AM
  #6577
JohnnyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Interstate TDR?
JohnnyS is offline
Old 02-27-2012, 03:28 PM
  #6578
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JohnnyS
Interstate TDR?
That's the answer I wanted, JohnnyS; and you are up, Sir. Great job!! The Interstate TDR was one of, if not the, first really practical RPV's. For it's day, quite a feat. Take it away, JohnnyS. Thanks; Ernie P.
This was one of the strangest aircraft built during WWII
What warbird do I describe?
Clues:
(1) The idea behing the design was born in the mid thirties, but the technology of the day simply wouldn’t support the idea.
(2) When the idea was resurrected early in WWII, technology now allowed the idea to be pursued.
(3) Although the aircraft were deployed, and used successfully in combat with a high rate of success, it was eventually decided conventional aircraft could do the job adequately; and the program was cancelled late in WWII.
(4) The airframe was built by a bicycle manufacturer.
(5) It was a twin engined aircraft.
(6) It used a steel tubed frame.
(7) The design was remarkably simple.
(8) Although several thousand were ordered, only a few hundred were actually produced.
(9) After the war, some of the surviving aircraft were converted to civilian use.
(10) The engines were relatively low powered.
(11).The total weight was quite low.
Answer: The Interstate TDR
The Interstate TDR was an early unmanned combat aerial vehicle — referred to at the time as an "assault drone" — developed by the Interstate Aircraft and Engineering Corporation during the Second World War for use by the United States Navy. Capable of being armed with bombs or torpedoes, 2000 aircraft were ordered, but only around 200 were built. The type saw some service in the Pacific Theater against the Japanese, but continuing developmental issues affecting the aircraft, along with the success of operations using more conventional weapons, led to the decision being made to cancel the assault drone program in October 1944.
In 1936, Lieutenant Commander Delmar S. Fahrney proposed that unpiloted, remotely controlled aircraft had potential for use by the United States Navy in combat operations. Due to the limitations of the technology of the time, development of the "assault drone" project was given a low priority, but by the early 1940s the development of the radar altimeter and television made the project more feasible, and following trials using converted manned aircraft, the first operational test of a drone against a naval target was conducted in April 1942. That same month, following trials of the Naval Aircraft Factory TDN assault drone, Interstate Aircraft received a contract from the Navy for two prototype and 100 production aircraft to a simplified and improved design, to be designated TDR-1.
Control of the TDR-1 would be conducted from either a control aircraft, usually a TBF Avenger, with the operator viewing a tv screen showing the view from a camera mounted aboard the drone, and with the radar altimeter's readout also displayed. Powered by two Lycoming O-435 engines of 220 horsepower (160 kW) each, the TDR-1 used a remarkably simple design, with a steel-tube frame constructed by the Schwinn bicycle company covered with a molded wood skin, thus making little use of strategic materials so as not to impede production of higher priority aircraft. Capable of being optionally piloted for test flights, an aerodynamic fairing was used to cover the cockpit area during operational missions. The TDR-1 was equipped with a fixed tricycle landing gear, that on operations would be jettisoned following takeoff for improved performance.
Under the code-name Operation Option, the Navy projected that up to 18 squadrons of assault drones would be formed, with 162 TBF Avenger control aircraft and 1000 assault drones being ordered. However technical difficulties in the development of the TDR-1, combined with a continued low priority given to the project, saw the contract modified with the order reduced to only around 300 aircraft. A single TDR-1 was tested by the U.S. Army Air Forces as the XBQ-4, however no production contract resulted from this testing.
In 1944, under the control of the Special Air Task Force (SATFOR), the TDR-1 was deployed operationally to the South Pacific for operations against the Japanese.[4] TDR-1 aircraft equipped a single mixed squadron (Special Air Task Group 1) along with TBM Avenger control aircraft, and the first operational mission took place on September 27, conducting bombing operations against Japanese ships. Despite this success, the assault drone program had already been canceled after the production of 189 TDR-1 aircraft, due to a combination of continued technical problems, the aircraft failing to live up to expectations, and the fact that more conventional weaponry was proving adequate for the defeat of Japan. The final mission was flown on October 27, with 50 drones having been expended on operations, 31 aircraft successfully striking their targets, without loss to the pilots of STAG-1.
Following the war, some TDR-1s were converted for operation as private sportsplanes.
Ernie P. is offline
Old 02-27-2012, 03:34 PM
  #6579
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: MajorTomski
MajorTomski, that isn't the answer I wanted; but you are correct. Thus far, all the clues would fit both aircraft. A good, but not correct, guess. Thanks; Ernie P.
Ernie P. is offline
Old 02-27-2012, 08:36 PM
  #6580
mobyal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok Please name for me a warbird which:
1. Flew during and after WW-II
2. After the war it was ''the'' way to fly from/to Europe
3. There were impressed versions and purpose built military versions.
Was gone for a few days so missed this one. I see that the Super Connie was the sought-after answer. Don't want to cause a distraction, but isn't there at least one more? Or maybe even two? I would have guessed the Boeing Stratocruiser, developed from the B29, though the modifications used may have been a stretch from the question's intent. And/or the Douglas DC 4, a varient of the C-54? (I think it was the C-54) But maybe I misunderstood the question, as I'm not sure what #3 means.....
Just curious as to whether these could also have been correct answers.
mobyal is offline
Old 02-28-2012, 04:31 AM
  #6581
a65l
a65l's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Impressed" into service means that an aircraft built for the civillian market, to civillian specifications, was taken over for military use. It may have been bought or leased from the owner, but it wasn't originally built to military specifications.
a65l is offline
Old 02-28-2012, 10:11 AM
  #6582
JohnnyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks! That one was interesting!
Here's a new one:
1. It was operated by the US army, air force and navy.
2. It had a single engine.
3. It was referred to as a "1 ton" truck by the manufacturer during development.
JohnnyS is offline
Old 02-28-2012, 01:26 PM
  #6583
Mein Duff
Mein Duff's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Boeing F4B?
Mein Duff is offline
Old 02-28-2012, 05:08 PM
  #6584
JohnnyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, that's not it.
4. A subsequent development of this aircraft was recently put back in production.
JohnnyS is offline
Old 02-29-2012, 10:26 AM
  #6585
JohnnyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, so far I have two correct answers in personal messages. The person with the first correct answer wants to encourage other participants to make guesses and ask questions and the person with the second correct answer doesn't want to ask the next question.
The answer is: The De Havilland Canada DHC-3 Otter.
From Wikipedia:
"When de Havilland Canada began design work on the "King Beaver" (the Otter's original name) in January 1951, it was trying to extend the company's line of rugged STOL utility transports that had begun with the Beaver. The single-engined, high-wing, propeller-driven DHC-3 Otter was conceived to be capable of performing the same roles as the Beaver, but was considerably larger, the veritable "one-ton truck" (in company parlance, the Beaver was the "half-ton truck").[1]
Using the same overall configuration of the earlier and highly successful DHC2 Beaver, the new design incorporated a longer fuselage, greater-span wings, and was much heavier. Seating in the main cabin is for 10 or 11, whereas the Beaver could seat six. Power is supplied by a 450-kW (600 hp) Pratt & Whitney Wasp radial. Like the Beaver, the Otter can be fitted with skis or floats. The Otter served as the basis for the very successful Twin Otter, which featured two wing-mounted Pratt & Whitney Canada PT6 turboprops.
The Otter received Canadian certification in November 1952 and entered production shortly thereafter."
Also note that the "Twin Otter" recently went back into production by Viking Air in BC, Canada. See: http://www.vikingair.com
At this point, I invite anyone who wants to ask the next warplane quiz question: I've asked a few lately and I don't want to hog the limelight here!
JohnnyS is offline
Old 02-29-2012, 06:21 PM
  #6586
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JohnnyS
From Wikipedia:
''When de Havilland Canada began design work on the ''King Beaver'' (the Otter's original name) in January 1951, it was trying to extend the company's line of rugged STOL utility transports that had begun with the Beaver. The single-engined, high-wing, propeller-driven DHC-3 Otter was conceived to be capable of performing the same roles as the Beaver, but was considerably larger, the veritable ''one-ton truck'' (in company parlance, the Beaver was the ''half-ton truck'').[1]
The Otter received Canadian certification in November 1952 and entered production shortly thereafter.''
Also note that the ''Twin Otter'' recently went back into production by Viking Air in BC, Canada. See: http://www.vikingair.com
Like JohnnyS, I would encourage those of you who haven't asked a question, or haven't asked one lately, to jump in. It really isn't hard; and we will all profit from the enhanced participation. Thanks; Ernie P.
Ernie P. is offline
Old 03-01-2012, 10:12 AM
  #6587
perttime
perttime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Let's see what happens... I just picked an aircraft and found that it has not been mentioned here [8D]
Not that it always has to be something that nobody has ever heard of.
What aircraft?
1) It was derived from a type that first flew about two years before the idea for this one came up.
2) First the idea was refused by a manufacturer. After another couple of years, it was canceled from the government's side.
perttime is offline
Old 03-01-2012, 12:53 PM
  #6588
perttime
perttime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What aircraft?
3) After yet another two years, it was entering service.
4) It stayed in service for about 10 years and more than 2,000 were built.
(I'll be away from the computer for close to 20 hours from now)
perttime is offline
Old 03-02-2012, 08:04 AM
  #6589
perttime
perttime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What aircraft?
5) Especially the early models had a reputation for fragility, for carrier operations.
perttime is offline
Old 03-02-2012, 10:28 AM
  #6590
JohnnyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Supermarine Seafire?
JohnnyS is offline
Old 03-02-2012, 10:53 AM
  #6591
perttime
perttime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JohnnyS
Seafire is correct!
http://en.wikipedia.org/wiki/Supermarine_Seafire
http://www.historyofwar.org/articles...e_seafire.html
I particularly like the post-war Mk XVII and Mk 47.
Your turn, JohnnyS.
perttime is offline
Old 03-02-2012, 01:54 PM
  #6592
JohnnyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New one:
1. First flew in 1915.
2. Almost a thousand were built, by ten different companies.
3. It was used as a torpedo bomber in the first world war.
JohnnyS is offline
Old 03-02-2012, 03:32 PM
  #6593
tunakuts3d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Short 184
tunakuts3d is offline
Old 03-03-2012, 06:41 AM
  #6594
JohnnyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes!
http://en.wikipedia.org/wiki/Short_Type_184
You're up next!
JohnnyS is offline
Old 03-03-2012, 01:52 PM
  #6595
tunakuts3d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
name the plane
1 Twin engine
2 counter rotating props
3 crew of two plus 12 passengers
4 once landed on the white house lawn
Old 03-03-2012, 02:44 PM
  #6596
The Raven
The Raven's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chinook?
The Raven is offline
Old 03-03-2012, 03:07 PM
  #6597
tunakuts3d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nope. Not the Chinook
Old 03-03-2012, 03:59 PM
  #6598
tunakuts3d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1 Twin engine
5 span 33'4" Length 47' 3 1/2"
Old 03-03-2012, 04:38 PM
  #6599
uncljoe
uncljoe's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Piasecki "Flying Banana" H21
Semper Fi
uncljoe is offline
Old 03-03-2012, 04:53 PM
  #6600
tunakuts3d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, not the one.
1 Twin engine
6 Despite rave reviews from over 40 pilots no production contracts were made
Display Modes
