Knowledge Quiz for Warbird wiz
#9326
XB-42 Mixmaster is correct!
Strange name for an aircraft, sounds like it would be more at home in the kitchen than on a runway!
Nevertheless an unusual and promising aircraft which, like so many, came to an end with the end of the war and the advent of jets.
Ernie, you are up!
Terry
Ernie, you are up!
Terry
#9327
RCU Forum Manager/Admin
My Feedback: (9)
I'll tell you what, I have never seen the XB-42 Mixmaster before (that's why I'm loving this thread. I'm learning something new all the time.). But after I saw Ernie's answer I was mesmerized. What an interesting plane. Man that would make a really cool RC subject if the engineering could be worked out!!!! It's had me thinking all morning long, and i've been sketching on paper all morning to see if maybe it would be possible to build one!!! I know that Evin Quiros had a Dornier 335 that had a internal engine that ran a pusher prop (unfortunately I filmed the demise of the plane) so the engineering is possible. really have to think this one over!!!!
Ken
Ken
#9328
i tripped over this one researching for another question. Didn't fit the clues so I stored it away for future use.
Looks like a 4 point landing would be all too easy to achieve!
Terry
Terry
#9330
Ernie, you are up!
Terry
Ernie, you are up!
Terry
Question: What famed aviator designer do I describe?
Clues:
(1) He began as a world famous pilot; and won or placed highly in several international competitions.
#9331
Ken
Ken
#9332
Late night clue. Thanks; Ernie P.
Clues:
(2) Then he became an aircraft designer. He began work with a couple of noted aircraft companies, then switched to a newly reconstituted, and famous, company; which already had the services of another pre-eminent designer.
Clues:
#9333
Early morning clue. Thanks; Ernie P.
Clues:
(3) He assisted in the design of a famed commercial airplane; one which was the basis for an iconic aircraft known to all warbird enthusiasts.
Clues:
#9334
And a mid-morning clue. Thanks; Ernie P.
Clues:
(4) Then he became the chief designer for the company, and headed the team of designers working on a new project. This aircraft was not particularly successful in its original role, but was far more successful in follow on uses. It remained in every day use and production for a long time, for the period.
Clues:
#9335
Afternoon clue (A bit early). Thanks; Ernie P.
Clues:
(5) He then moved to another, competitor, company. There he worked on a seminal aircraft which was not to see production; but one which was ground breaking in its design.
Clues:
#9336
Late afternoon clue. Thanks; Ernie P.
Clues:
(6) He then designed another aircraft. This one, which was initially considered to be too complicated and too filled with innovative ideas, was not put into production. This lead to his being fired by the man “whose name is on the door”; although a simplified version of his design was later put into limited production and considered to be a great aircraft.
Clues:
#9337
And an evening clue before I go try to find the snow shovel. Thanks; Ernie P.
Clues:
(7) After being abruptly fired, he moved to yet another aircraft manufacturer, where he worked on a collaborative effort between the aircraft manufacturer and an engine company. This work lead him into a famous rivalry with a very well known aerospace designer; a rivalry which would last for many years.
Clues:
#9339
No; not Dryden. But here's another clue to aid your search. Thanks; Ernie P.
Clues:
(8) Although the ground breaking research and design effort in which he was involved (7) was at first troublesome, he eventually discovered a flaw in the wing design. After correcting that, the design worked; as any modern History book will attest.
#9340
Clues:
(9) After the end of the war in which he gained such exposure, he moved to the United States to work with his main rival. He developed a method of predicting system reliability which today is considered a law in the field.
Clues:
#9341
A late morning clue. Thanks; Ernie P.
Clues:
(10) He then returned to his home country; working for one of the companies for which he had previously served as a designer. There, he predicted problems with that country’s modifications to a famous fighter aircraft; which was borne out in subsequent years.
Clues:
#9342
Afternoon clue. Not a lot of suitable clues left. Thanks; Ernie P.
Clues:
(11) Strangely enough, one of his more famous inventions came about because of his interest in a sport; and an injury he suffered while practicing the sport. He designed new equipment, which is in common use even today; and started a sports equipment company which was a major manufacturer within its field.
Clues:
#9343
Clues:
(12) Oddly (To my mind), I can find no record of his having served in WWI; although he was definitely old enough to have done so.
Clues:
#9344
Evening clue. Thanks; Ernie P.
Clues:
(13) His life and career literally stretched from the dawn of flight and aerial fighting to the genesis of the space age and its greatest accomplishments.
Clues:
#9345
Things I leaned chasing this question:
Kurt Tank and Willi Messerschmidt were born the same year (1898)
Lancaster designer Roy Chadwick was killed in a crash caused by reversed ailerons
Still don't have the answer though.
Terry
Terry
#9346
Redback; you are probably closer to the answer than you think. Keep trying; and here's a late night clue to aid your search. Thanks; Ernie P.
Clues:
(14) He did a reliability study of adaptations being made to license-built F-104 fighters. The study was initially considered to be alarming; and later prophetic.
#9347
OK Ernie, now I have it (or at least Google and I have it!!!)
Might take a leaf out of your book and let it stew for a bit longer, especially as I don't have a question handy!
Terry
Terry
#9348
Well, I predict some one will post a correct answer today. From here on out the clues will, as they must, become increasingly transparent. Thanks; Ernie P.
Clues:
(15) After his stint as a competitive aviator, he worked with the Klemm Light Aircraft Company. Then he moved to Heinkel.
#9349
I suspect more than one of you already know the answer; but here is an afternoon clue. Thanks; Ernie P.
Clues:
(16) From there, he moved to the Bavarian Aircraft Works before returning to Heinkel.
Clues:
#9350
Evening clue. After this, the clues will become more and more obvious. I'm leaving for a week's travel tomorrow morning, so some one will have to take over. But then again, I can't keep you guys outfoxed for much longer. Thanks; Ernie P.
Clues:
(17) From there, he moved to Fieseler.
Clues:
