Knowledge Quiz for Warbird wiz
#1026
My Feedback: (101)
RE: Knowledge Quiz for Warbird wiz
it has to be wars..... and or a world war and a good old fashion war.
the list of planes I come up with are
P51, corsair, c47, A26, B29, Bearcat, P60/T33,Skyraider, A4 Skyhawk, T6, Beech staggerwing,phantom,Mig 15, polykarpov bi plane, pt-17 or 16 .....oh I give up, I am obviously over thinking this but not all of these fit the criteria
#1027
B-29 wasn't at all a failure at high altitude bombing, in fact very much immune to flak and japs had very few fighters to counter it. The reason they went to low level incendary bombing is that the Japaneese cities were made of wood. Wood burns, and incendaries dispurse too much if dropped at high altitude. Also without having to burn fuel to climb and fight the jet stream they could carry a bigger load. Reducing armament also increased payload. Full armament wasn't necessary for night raids.
Still a good guess. It does meet all the clues, except wasn't an initial failure; don't think it's the right answer.
I was thinking Lancaster.
Original Version Manchester was a bust due to engines.
Believe they had some passenger carying versions but not for sure.
But wasn't to my knowledge used by both sides, or saw service in more than 1 war.
Its like I should know the answer, but just hasn't come to me yet.
#1029
ORIGINAL: Evil_Merlin
This is why I hate google and bing. Type in the question and boom... there is the answer. No real knowledge required. I liked it when we actually had to do research!
The MiG-3 is quite a nice bird. Had it actually been used for what it was designed...
Thank you for providing *two* incentives for my current question. Thanks; Ernie P.
#1030
ORIGINAL: tailskid
Fifth hint: It served through two wars.
'Wars' or World Wars?
#1032
ORIGINAL: jharkin
This is reallllly stretching and I doubt its right but here goes a guess...
How about the B-29 Superfortress?
Hint 1: The Soviets made the Tu-4 copy of the Superfortress
Hint 2: B-29s had high losses when first used in high altitude daylight bombing. They were a lot more sucessfull when we stripped all the defensive guns and used them for low level night incendiary raids.
Hint 3: The civilian ''version'' of the B-29 was the Boeing 377 Stratocruiser airliner. I know the Brits operated the B-29 and Stratocruisers were sold to many countries. The soviets sold Tu-4s to China.
Hint 4: WWII and Korea
Hint 5: The last B-50 Superfortresses were retired in 1960
-Jeremy
-Jeremy
#1033
What warbird am I describing?
First hint: It was flown by both opposing sides, in wartime, as well as serving in several neutral air forces.
Second hint: It was initially considered to be pretty much a failure; as its early models were clearly inferior to other designs produced by its host country. After use in combat, it was withdrawn as being unsatisfactory in performance. Only when redesigned, and assigned to a new role, did it prove successful.
Third hint: Both civilian and military versions were produced; and both versions were sold to, and produced by, other nations.
Fourth hint: Once the plane was redesigned, it was considered to be almost invulnerable.
Sixth hint: It was in service for more than 20 years.
Seventh hint: Original version: Four crewman. Redesigned version: Two crewman.
Thanks; Ernie P.
Thanks; Ernie P.
#1040
ORIGINAL: Ram-bro
canberra B57
canberra B57
Eighth hint: This plane was almost invulnerable in its redesigned form; because no enemy plane could reach it.
Thanks; Ernie P.
#1048
Ninth hint: Twin engine; twin tailed; very tapered (actually, pointed) wings.
Thanks; Ernie P.
Read more: http://www.rcuniverse.com/forum/m_94...#ixzz0lVQzCb8i
Thanks; Ernie P.
