Knowledge Quiz for Warbird wiz
Joe; it was really more clues (3) and (4). That was a better question than it might appear. I just had a hunch early on that led me in the right direction. Then it was simply a matter of narrowing down a pretty small group of men. As I said; a better, and more difficult, question than it might at first appear. I'll post something in the morning. Thanks; Ernie P.
As promised. Thanks; Ernie P.
Question: What warbird do I describe?
Clues:
(1) This aircraft was originally intended as an attempt to redesign, and correct the design flaws in, an earlier and failed aircraft.
Clues:
Hydro Junkie; you certainly have the concept down correctly, but you have the wrong aircraft. Please try again. Also, was having trouble with WORD this morning and had to correct the wording of the first clue. My apologies. Thanks; Ernie P.
Clues:
1. This aircraft was originally an attempt to redesign and correct the design flaws in an earlier, failed aircraft.
2. It essentially married together the design features of the failed aircraft, with the design features of a remarkably successful aircraft.
Morning clue. Thanks; Ernie P.
Clues:
3. It also, in turn, influenced the design of a very famous aircraft, although that program was never completed.
Clues:
Afternoon clue. Thanks; Ernie P.
Clues:
4. One of the interesting things is that the aircraft was designed in one country, but built in another.
Clues:
A-5M
I only say this due to the fact that there are claims made that it was designed by Howard Hughes and was a total failure until the designers at Mitsubishi got their hands on it
Clues:
5. And eventually completed and flown by the second country.
Morning clue. Happy Easter! Thanks; Ernie P.
Clues:
6. It was to have been a high speed, high altitude bomber.
Clues:
Clues:
7. But the plane wasn’t completed in time to participate in the war; and was abandoned by the designer country.
Clues:
Evening clue. Thanks; Ernie P.
Clues:
8. But there is no question that, had it been completed in time, it would have been almost invulnerable to interception.
Clues:
No guesses? I'd have thought you guys would be swarming all around this one at this point. Ah, well; a morning clue may help. Thanks; Ernie P.
Clues:
9. It was completed and used by the builder country for some years.
Clues:
And an afternoon clue to continue the merriment. Thanks; Ernie P.
Clues:
10. It was used for high altitude research initially.
Clues:
And an evening clue to keep things rolling. Thanks; Ernie P.
Clues:
11. Then it was used for research into air launched experimental aircraft.
Clues:
Clues:
12. This project actually began as a proposal to build a high altitude version of the failed bomber project which served as the “parent” of what later became this aircraft.
Clues:
Afternoon clue. Sorry to be tardy, but I'm having some issues with RCU right now. Thanks; Ernie P.Question: What warbird do I describe?
Clues:
1.This aircraft was originally an attempt to redesign and correct the design flaws in an earlier, failed aircraft.
2.It essentially married together the design features of the failed aircraft, with the design features of a remarkably successful aircraft.
3.It also, in turn, influenced the design of a very famous aircraft, although that program was never completed.
4.One of the interesting things is that the aircraft was designed in one country, but built in another.
5.And eventually completed and flown by the second country.
6.It was to have been a high speed, high altitude bomber.
7.But the plane wasn’t completed in time to participate in the war; and was abandoned by the designer country.
8.But there is no question that, had it been completed in time, it would have been almost invulnerable to interception.
9.It was completed and used by the builder country for some years.
10.It was used for high altitude research initially.
11.Then it was used for research into air launched experimental aircraft.
12.This project actually began as a proposal to build a high altitude version of the failed bomber project which served as the “parent” of what later became this aircraft.
13.The idea was to create a high altitude version of a twin engined bomber by adding pressurized crew compartments, reducing the number of crew members and defensive armament and extending and redesigning the wings.
Clues:
Well, some of our guys are certainly giving this a serious look. No correct guesses so far, but here's a bonus clue to reward participation. Thanks; Ernie P.Question: What warbird do I describe?
Clues:1.This aircraft was originally an attempt to redesign and correct the design flaws in an earlier, failed aircraft.2.It essentially married together the design features of the failed aircraft, with the design features of a remarkably successful aircraft.3.It also, in turn, influenced the design of a very famous aircraft, although that program was never completed.4.One of the interesting things is that the aircraft was designed in one country, but built in another.5.And eventually completed and flown by the second country.6.It was to have been a high speed, high altitude bomber.7.But the plane wasn’t completed in time to participate in the war; and was abandoned by the designer country.8.But there is no question that, had it been completed in time, it would have been almost invulnerable to interception.9.It was completed and used by the builder country for some years.10.It was used for high altitude research initially.11.Then it was used for research into air launched experimental aircraft.12.This project actually began as a proposal to build a high altitude version of the failed bomber project which served as the “parent” of what later became this aircraft.13.The idea was to create a high altitude version of a twin engined bomber by adding pressurized crew compartments, reducing the number of crew members and defensive armament and extending and redesigning the wings.14.This eventually led to a complete redesign, which added two engines.
And a morning clue. Thanks; Ernie P.Question: What warbird do I describe?
2.It essentially married together the design features of the failed aircraft, with the design features of a remarkably successful aircraft.3.It also, in turn, influenced the design of a very famous aircraft, although that program was never completed.4.One of the interesting things is that the aircraft was designed in one country, but built in another.5.And eventually completed and flown by the second country.6.It was to have been a high speed, high altitude bomber.7.But the plane wasn’t completed in time to participate in the war; and was abandoned by the designer country.8.But there is no question that, had it been completed in time, it would have been almost invulnerable to interception.9.It was completed and used by the builder country for some years.10.It was used for high altitude research initially.11.Then it was used for research into air launched experimental aircraft.12.This project actually began as a proposal to build a high altitude version of the failed bomber project which served as the “parent” of what later became this aircraft.13.The idea was to create a high altitude version of a twin engined bomber by adding pressurized crew compartments, reducing the number of crew members and defensive armament and extending and redesigning the wings.14.This eventually led to a complete redesign, which added two engines.15.The result was an aircraft which was considerably faster; and which could fly at more than twice the altitude of the parent aircraft.
Afternoon clue. Sorry for the way things look, but I'm really struggling with the new RCU formatting tools. Thanks; Ernie P.Question: What warbird do I describe?
Clues:1.This aircraft was originally an attempt to redesign and correct the design flaws in an earlier, failed aircraft. 2.It essentially married together the design features of the failed aircraft, with the design features of a remarkably successful aircraft. 3.It also, in turn, influenced the design of a very famous aircraft, although that program was never completed. 4.One of the interesting things is that the aircraft was designed in one country, but built in another. 5.And eventually completed and flown by the second country. 6.It was to have been a high speed, high altitude bomber. 7.But the plane wasn’t completed in time to participate in the war; and was abandoned by the designer country. 8.But there is no question that, had it been completed in time, it would have been almost invulnerable to interception. 9.It was completed and used by the builder country for some years. 10.It was used for high altitude research initially. 11.Then it was used for research into air launched experimental aircraft. 12.This project actually began as a proposal to build a high altitude version of the failed bomber project which served as the “parent” of what later became this aircraft.
13.The idea was to create a high altitude version of a twin engined bomber by adding pressurized crew compartments, reducing the number of crew members and defensive armament and extending and redesigning the wings. 14.This eventually led to a complete redesign, which added two engines.
15.The result was an aircraft which was considerably faster; and which could fly at more than twice the altitude of the parent aircraft. 16.The combination of altitude and speed was such that it was felt the opposing fighter aircraft would be unable to intercept the aircraft.
Evening clue. Thanks; Ernie P.Question: What warbird do I describe?
17.At the same time, a very long range version of the new design was being prepared.
When I paste the clues onto the sreen, they look fine. Then when I click
post reply" they change. They don't all change, or even all in the same way. Maybe the editor doesn't like WORD? Thanks; Ernie P.
