Knowledge Quiz for Warbird wiz
Perhaps, although the army used Cessna O-1's until we got out of Vietnam. By "combat" I meant to include any use of an aircraft in a combat zone other than training or transporting people (e.g. hacks), so air-to-air, bombing, ground attack, artillery spotting, photo-recon, all count. In any event, that war lasted into the 70's, so it's too recent a use in combat to fit the plane I have in mind.
Upon further reflection and looking at sources, I think it was misleading to say (clue 1) that this particular aircraft was originally designed to have four engines. The company that built it designed a four-engine plane, the plane I'm looking for was officially labeled a variation of that design and had the same official numerical designation as that design, but its actual design was a parallel process rather than an adaptation of the four-engine aircraft. In short, on the books it was officially a single-engine version of what had started out as a design for a plane with four engines, but in fact it was a single-engine airplane from the start, which was given the designation of a different design that had been abandoned. One of those bureaucratic things. Sorry about that.
Today's clue:
Looking for the name of a very well known aircraft.
1. Originally designed to have four engines, but the production versions didn't.
2. Last flew in combat in the early 1960s.
3. Said to be very easy to fly.
4. The production version had one engine.
5. Used by only two countries.
6. At least two significant firsts: Its manufacturer's first aircraft of its type and its service's first aircraft to achieve a particular sort of success in a war.
Today's clue:
Today's clue:
1. It was officially a single-engine version of what had started out as a design for a plane with four engines, but in fact it was a single-engine airplane from the start, which was given the designation of a different design that had been abandoned. One of those bureaucratic things.
7. Three of the pilots who flew it either were or later became household names.
Top_Gunn; this one is a little different. Seven clues in and no one has taken a shot? Some parts of your clues lead me toward the F4F, with Thatch, O'Hare and all; but others lead me away from that airplane. F6F; the plane that was first able to handle the Zero straight up? But again, some clues actually smother my ideas. Thanks; Ernie P.
Today's clue:
8. Had a major role in two movies, and a minor role in a few others. In one of those others, it was ridiculously anachronistic.
Have I mentioned that this is a very well known plane? In addition, the household names referred to in clue 7 are household names even for millions of people who have no particular interest in aviation and who wouldn't know what plane this was if you showed them a picture.
Today's clue:
9. Used a license-built version of a foreign engine.__________________
Today's clue:
Movies include The Bridges at Toko-Ri, Men of the3 Fighting Lady, and Midway (!).
You're up, Irb75.
All; apparently Irb75 has disappeared. Unless he posts his question by this afternoon, I will declare the floor open and the first person to post will be the lead. Thanks; Ernie P.
All; in the absence of Irb75, the floor is now open. The first person to post a question and first clue has the floor. If no one posts anything by tomorrow am, I will post a question. Thanks; Ernie P.
The Grumman TBF Avenger was another holdover retired in the 60s along with the Douglas A-1 Skyraider which was designed as the replacement for both.
Are you talking about the Curtis SB2C first used in WWII and was still in service with the Air Force and Navy in the Vietnam War?
Sir; the first clue explained the "four engine vs one engine" thing. And again, the floor is now open to anyone who wants to ask the next question and post clues. Thanks; Ernei P.
Seeing no takers, we are off again. Thanks; Ernie P.
Question: What warbird do I describe?
Clues:1.This fighter aircraft was noted as being a very effective dogfighter.
Not a bad guess, Hydro Junkie; but not correct. However, as normal, your participation earns a bonus clue. Please try again. Thanks; Ernie P.
Clues:
2.It was capable of fighting on equal terms with almost any fighter of its day.
Clues:
Afternoon clue. Thanks; Ernie P.
Clues:
3.Much of its success was related to innovative methods and equipment which helped the pilot better control the aircraft in combat situations.
Clues:
Evening clue. Thanks; Ernie P.
Clues:
4.These methods helped the pilot turn the aircraft quickly without losing control; and automatically compensated for quick turns and combat speeds.
Clues:
