Knowledge Quiz for Warbird wiz
Afternoon clue. Thanks; Ernie P.
What warbird do I describe?
Clues:
1. This aircraft was primarily utilized as a trainer.
2. It was often referred to by a particular name; although that name properly belonged to an earlier model of the plane.
3. The first aircraft of this type was actually purchased by the navy.
4. Used by both the army and navy.
5. A high scoring ace was trained on, among others, this aircraft.
6. He was in the navy.
7. More than 100 were produced; quite a number for the time.
8. Tandem seating.
9. Early experiments with firing a machine gun utilized this aircraft.
10. In earlier models of this aircraft, seating was a bit Spartan.
11. This model provided a nacelle, where the instructor and student still sat side by side.
12. Earlier models had wings of equal span; though later models had extensions to the top wing.
13. Main landing gear had four wheels.
14. Twin rudders.
15. Four parallel beams.
16. Two from each wing.
17. Pusher engine.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
Morning clue. Thanks; Ernie P.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
18. The main landing gear also had skids.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
No, Sir; I am not. However, you aren't all that far off the mark and I encourage you to refine your search criteria. And this next clue may help. Thanks; Ernie P.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
19. No tailwheel; just a skid.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
Evening clue. Thanks; Ernie P.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
20. As was common practice at the time.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
21. A small handful of this type survived WWI; and were among the first to be registered when civil aviation was again allowed.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
Not the Dh-2, elmshoot. This was a trainer, not a fighter; and the Dh-2 didn't have skids. But you are in the right time zone. Maybe this bonus clue will help you in your search. Thanks; Ernie P.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
22. The “high scoring ace” mentioned in (5) was a Canadian.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
24. His name was Collishaw.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
25. And he was the famed leader of “The Black Flight”.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
26. In earlier models, two seats were mounted on the front edge of the lower wing.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
27. Only two countries used this trainer.
Hydro Junkie; that's an obvious answer and I was expecting someone to try it, but it isn't the plane for which we seek. Maybe this clue will give you an idea. Thanks; Ernie P.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
28. Those countries were The United Kingdom and Australia.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
29. Engine was a Gnome et Rhome.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
30. An 80 HP Gnome et Rhome.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
31. The machine gun tested (9) was a Lewis type.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
Ernie P,
I appreciate the research that you do on these obscure airplanes I learn quite a bit in doing the looking around mostly from Wiki.
Sadly I usually forget it all within short order. I have CRS
Sparky
Sparky
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
30. An 80 HP Gnome et Rhome. 31. The machine gun tested (9) was a Lewis type.
32. And the tests were conducted in 1913.
BTW, guys; I do hope some one has simply looked up Raymond Collishaw and read about his initial flight training in the RNAS. It would probably prove to be enlightening. Thanks; Ernie P.
You're looking in the right place, Sir; you just need to look closer. Maybe this will help. Thanks; Ernie P.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
33. They were the first tests of that type by the British.
Clues:
8. Tandem seating.
14. Twin rudders.
17. Pusher engine.
23. He was RNAS.
