Knowledge Quiz for Warbird wiz
Reply
Old 05-23-2019, 01:13 PM
  #17201
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Afternoon clue. Thanks; Ernie P.
Question: What warbird do I describe?
Clues:
1. It was designed as a fighter, but spent much of its life in another role.
2. Single engine.
3. Single seat.
4. Our subject aircraft was a development of a prior prototype aircraft.
5. A prototype aircraft not noted for being handsome or handy.
6. In fact, the first prototype crashed, killing its pilot, on its first flight.
7. Modifications were made and three more prototypes prepared.
8. The design of the fuselage featured a rather high seating position for the pilot, which was done to allow increased visibility.
9. Fairings were used to reduce resistance around the cockpit wherever possible.
10. The design of the fuselage was also specifically intended to allow construction by relatively unskilled workers.
11. The initial production versions largely followed the design of the prototypes.
12. The parent company of the manufacturer was located in a foreign country; and this was the first aircraft designed by the subsidiary.
13. The initial production run of the fighters were armed with a single machine gun located above the top wing.
14. Later versions were equipped with two machine guns located along the forward fuselage.
15. Although our subject aircraft was reasonably fast, had excellent flying characteristics and was quite maneuverable, most combat pilots preferred an available foreign design.
16. That preference largely related to some initial design flaws and teething problems. Most of these were corrected in later versions.
17. Nevertheless, our subject aircraft was slowly pushed into a role as a reconnaissance escort aircraft.
18. Several engines, of increasing horsepower, were used in our subject aircraft during its production run.
19. Some of these increases in power necessitated changes in the wing structure.
20. Despite the increasing power available, almost all of the production aircraft used a two bladed propeller.
21. Although a four bladed propeller was used for some aircraft.
22. A car type radiator was used.
23. This may explain persistent issues with overheating of the engine.
24. It was not uncommon for ground crew to simply remove the engine covers, to increase the airflow around the engine cylinders. Later aircraft had a reduced engine cover to produce the same effect.
25. Different, elongated radiators, fitted along the leading edge of the wing, were tried.
26. One of the early “teething issues” was the fuselage mounted machine guns being located too far forward, making it impossible to clear jams.
27. Another was caused by the use of several different sub-contractors producing the aircraft, in addition to the local firm which designed it.
28. Some of these contractors tended to use shortcuts when building the aircraft.
29. And those shortcuts caused the wings to fail; which did not induce confidence in the aircraft’s pilots.
Ernie P. is offline
Old 05-24-2019, 08:38 AM
  #17202
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
30. That lack of confidence in the perhaps frail subject aircraft, by the pilots involved, made them prefer a more robust, foreign aircraft which was available.
Ernie P. is offline
Old 05-24-2019, 11:49 AM
  #17203
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm going to be busy later, so I'll post an evening clue now. Thanks; Ernie P.
Clues:
2. Single engine.
3. Single seat.
31. Interestingly enough, a foreign aircraft noted for shedding its wings; particularly in the earlier models.
Ernie P. is offline
Old 05-25-2019, 01:36 AM
  #17204
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Morning clue. Thanks; Ernie P.
Clues:
2. Single engine.
3. Single seat.
32. But such are the vagaries of life; and this and other early design and construction flaws doomed our subject aircraft to a secondary role; escorting aircraft doing recon work.
Ernie P. is offline
Old 05-25-2019, 12:06 PM
  #17205
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
33. Nevertheless, the aircraft remained in production from mid-1917 until the end of the war.
Ernie P. is offline
Old 05-26-2019, 01:24 AM
  #17206
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
34. It featured a rectangular shaped fuselage.
Ernie P. is offline
Old 05-26-2019, 11:15 AM
  #17207
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Afternoon clue. Remember to honor all who died, and remember all who served. Thanks; Ernie P.
Clues:
2. Single engine.
3. Single seat.
35. The wing was of basically orthodox structure; with a scalloped trailing edge, Spruce leading edges and spars, and steel tubes with internal wire bracing.
Ernie P. is offline
Old 05-27-2019, 02:11 AM
  #17208
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
36. Although the curvature of the wing, and the somewhat longer trailing edges, were a bit unusual.
Ernie P. is offline
Old 05-27-2019, 11:44 AM
  #17209
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
37. The wing’s design gave the plane a degree of stability without sacrificing maneuverability.
Ernie P. is offline
Old 05-28-2019, 08:27 AM
  #17210
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Today's clue. Thanks; Ernie P.
Clues:
2. Single engine.
3. Single seat.
38. Only the upper wing was fitted with ailerons.
Ernie P. is offline
Old 05-29-2019, 01:53 AM
  #17211
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
39. Engine power was increased incrementally from 185 HP to 225 HP.
Ernie P. is offline
Old 05-29-2019, 10:50 AM
  #17212
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
40. Which required the wings be strengthened.
Ernie P. is offline
Old 05-29-2019, 05:13 PM
  #17213
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Evening clue. Thanks; Ernie P.
Clues:
2. Single engine.
3. Single seat.
41. The machine gun interrupter mechanism proved to be problematic at certain engine speeds.
Ernie P. is offline
Old 05-30-2019, 06:17 AM
  #17214
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Morning clue. Guys; this is clue 42. The last time anyone even hazarded a guess was after clue 3. Have I put everyone to sleep? Or is everyone on vacation? I know this one isn't that hard. Thanks; Ernie P.
Clues:
2. Single engine.
3. Single seat.
42. Which lead to some issues involving bullets and propellers coming together; which proved troublesome.
Ernie P. is offline
Old 05-30-2019, 02:36 PM
  #17215
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
43. Top speed was better than 115 MPH, for even the lesser powered versions.
Ernie P. is offline
Old 05-31-2019, 01:33 AM
  #17216
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
44. Operational ceiling exceeded 20,000 feet.
Ernie P. is offline
Old 05-31-2019, 01:58 PM
  #17217
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
45. And endurance was around 2-1/2 hours.
Ernie P. is offline
Old 06-01-2019, 05:49 AM
  #17218
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
46. Upper wingspan was just over 26 feet.
Ernie P. is offline
Old 06-01-2019, 12:01 PM
  #17219
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
47. Lower wingspan was just under 26 feet.
Ernie P. is offline
Old 06-02-2019, 02:56 AM
  #17220
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
48. Dry weight was a bit under 1,300 pounds.
Ernie P. is offline
Old 06-02-2019, 12:31 PM
  #17221
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
49. Loaded, a bit under 1,900 pounds.
Ernie P. is offline
Old 06-03-2019, 06:15 AM
  #17222
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
50. A man’s name is normally included in the name of our subject aircraft.
Ernie P. is offline
Old 06-03-2019, 11:08 AM
  #17223
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
51. In order to distinguish it from a fighter produced by the parent company.
Ernie P. is offline
Old 06-03-2019, 04:52 PM
  #17224
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
52. And, to honor the designer.
Ernie P. is offline
Old 06-04-2019, 02:25 AM
  #17225
Ernie P.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clues:
2. Single engine.
3. Single seat.
53. After the war, this aircraft was adopted by the services of at least three other countries.
Ernie P. is offline
