ESM T-28
#1251
RE: ESM T-28
I appeciate everyone's feedback - thank you very much.
So per Tomas, they did shorten the gear on the new red and whiteT-28. I really don't know if the yellow one is affected, sorry. If you get the new ESMgear you will be ok, but if you opt for the Sierra Gear, you'll have some work to do see below.
After thinking about this, I opted to keep my gear at their original length (for sake of prop clearance). The fix was very "simple." I simply moved the gear out 0.40 (10mm). The bracing for the gear extends beyound this point, but you have to extend the plywood pad for the landing gear another 0.400 inches. Of course, the new style gear doors are too short now, but they are too are simple to "fix."
Please see the pic below.
Best,
James
Best,
James
#1252
RE: ESM T-28
Evening Every one.....i am trying to figure out what scale cockpit i want to go with...has anyone thought or tryed the one from Magnum RC..it was made for the KMP Sig series two seat T-28...want to see if it will fit witth minimal work and cutting.
willie
willie
#1253
RE: ESM T-28
<xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w:PunctuationKerning /><w:ValidateAgainstSchemas /><w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid><w:IgnoreMixedContent>false</w:IgnoreMixedContent><w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText><w:Compatibility><w:BreakWrappedTables /><w:SnapToGridInCell /><w:WrapTextWithPunct /><w:UseAsianBreakRules /><wontGrowAutofit /><w:UseFELayout /></w:Compatibility><w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel></w:WordDocument></xml><xml><w:LatentStyles DefLockedState="false" LatentStyleCount="156"></w:LatentStyles></xml><style> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin:0in;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman";mso-fareast-font-family:"Times New Roman";mso-ansi-language:#0400;mso-fareast-language:#0400;mso-bidi-language:#0400;}</style>Hi all: I have kind of a sophomoric problem and would like to see what others have done.
Can someone who has the Sierra Gear in your T-28 please send me a couple of good pics of the gear in the up position and the down position. I'm after deal on the interfacing of the gear doors, and how you linked the gear door to the strut.
My issue is that gear door lays down, but I’m afraid the door will be "ripped" off as the mechanism is not keeping the end of the door pulled down. Am Imissing something, or is that "the way it is."
James
James
#1254
RE: ESM T-28
any news of Trojan T-28 ? ... if not , at meantime, see a Film at "You Toube" of our best Warbirdmeeting in Oberhausen ( Bavaria Germany)
go to "Warbirdmeeting Oberhausen 2012 (The Movie)"
I hope you enjoy !
Best, Franz
#1255
My Feedback: (38)
RE: ESM T-28
James
If you go back some pages you will find some good info about the gear doors.
I have Sierra on mine as well and I have a similar set up as yours.
To keep my door nice and tight I had to play with the attachment to the strut up or down until I found the right geometry to keep the door tightly closed.
It needs to be tight otherwise it will interfere with your flight and possibly get ripped off.
Let me know if you find your info in the prior pages, if not I will post some pics of my set up here.
Fabio
Fabio
#1260
KY
RE: ESM T-28
Thanks guys. Ifinally got my engine tuned correctly so Iwas able to fly 4 times that day.
As for the pilots, one is a 12" gi joe and the other is a 12" Dragon pilot.
#1261
RE: ESM T-28
This is the second flight with my ESM T28, unfortunateky without pilots. Also some geardoors to be installed.
DLA 32 is for me more than enough power and this engine have only been running for 5-10 minutes.
I have no lead upfront but a cannister fitted inside the fuselage with own silversoldered adapter. The servoes are all moved upfront
[youtube]http://www.youtube.com/watch?v=whouOXuzslk[/youtube]
Anyone with a good suggestion where to buy jet pilots that fits the original cockpit. This is a everyday plane and I do not intend to install any full cockpit.
#1263
RE: ESM T-28
ebay is good, but I am struggling finding the correct size for this plane with standard cockpit....
And thanks! The model is a smooth flyer. I think mine is on the absolute aft CG so have to adjust the elevator throw and add some more expo.
#1264
#1265
RE: ESM T-28
ORIGINAL: flypilot
Have a look here: http://www.hobbyking.com/hobbyking/s...s_-Pilots.html
I bet you will find one or two that will fit just fine there....
unfortunately, they are all to small :-(
Found this and I thing the 100mm jetpilot will be fine: http://www.ytinternational.co.uk/pil...ard_range.html
When will you be visiting me with the new ESM P40 ??
#1266
KY
RE: ESM T-28
My pilots are 12" pilots that fit in the stock cockpit. They have no legs below the knees. They are the correct representation of a scale size pilot.
#1267
RE: ESM T-28
Hello All:
Thanks to all that helped me along. I've completed my build and will likely madien her Saturday (weather willing).
The plane has the following:
Saito 4-Stroke Twin Cyclinder 57CCgasser
Custom Scale exhaust
Scale cockpit by Ty Planes
Scale Pilots by TwinTurboZ (rcuniverse seller - highly recommended)
Sierra Gear with Brakes (new T-28s have to be modified to fit the Sierra Gear)
Jet-tronics "solid-state" brake valve and gear valve (I'm a big fan - keeps everything clean and simple)
That's about all that notable.
Oh, final weight 23.6lbs
Thanks to all, again.
Best,
James
Best,
James
#1270
RE: ESM T-28
Hi Paul:
Iactually made the headers from 5/8 and 3/8 thin wall stainless in my fab shop. I flaired the ends somewhat so that black flex tubes from Saito would just fit. They were pretty easy to make since I opted for stainless. Stainless is much easier to work with Al.
If you'd like a CAD drawing, please let me know.
Best,
Jamse
Best,
Jamse
#1272
NJ
RE: ESM T-28
Hello Folks, I have been following this forum and it seems to have a wealth of information. I am considering purchasing this bird. My question is the following: Is there a simple way of printing this entire forum without having to print one page at a time?
thanks in advance
Lionel
thanks in advance
Lionel
#1274
FL
RE: ESM T-28
Hi, I am planning to install a Zanoah g 38 engine on my new ESM T 28 Trojan, Would it be enough power???? What about balance ??? the Zenoah engines are heavy.
Will it be necessary to cut the cowl sides?????
Thanks in advance for your help and comments
Alex
Alex
#1275
RE: ESM T-28
See my post a few lines above I would not worry about the motor's weight. Iput a Saito 57CC Twin in mine and through moving the battery pack Iwas able to get theCGperfect. Ididn't have to add ANYweight to the tail (or the nose). Iwill say, that i mounted the air tank just behind the wing mounting wing nuts. This is the only "weight"I have in the plane's tail.
Hope this helps.
James
Hope this helps.
James
