ESM T-28
Reply
Old 01-06-2013, 04:16 PM
  #1276
CHARLES WINTER
CHARLES WINTER's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ESM T-28
Hi James. Have you flown your T-28 yet? I am installing the main gear doors now and am running into problems like I think you did. I'm not happy with my set up and don't think it will be FAIL-SAFE. Are you pleased with the hinging movement of the Long main gear doors with the interaction of the small wheel cover doors. If you are happy with your set up, could you take some Close-up pictures of your hinging of the main long doors and any other pictures of your main gear installation. Thanks for your inputs. Col. Chuck Winter
CHARLES WINTER is offline
Old 01-07-2013, 12:47 AM
  #1277
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just order myself a T-28 and it should be here by the end of the week. I'm think of running the DLE 60 twin in it.
Damo
Damo260 is offline
Old 01-07-2013, 10:38 AM
  #1278
JamesPool
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Charles. Currently fishing. I'll relpy when I return Friday.
Best,
james
JamesPool is offline
Old 01-07-2013, 07:00 PM
  #1279
Doomking
Doomking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Damo
I think a DLE 60 is way too much power.
You might want to reconsider unless you have the engine laying around and you need a plane for it.
Fabio
Doomking is offline
Old 01-14-2013, 01:23 AM
  #1280
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi my T-28 turn up to day what a awesome looking plane. I might reconsider the motor that I want to run in it I am think now the Saito FG-40 petrol?
Damo
ID:	1840249   Click image for larger version
Damo260 is offline
Old 01-14-2013, 03:08 AM
  #1281
Doomking
Doomking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
G45 under my hood for half of the price of a Saito.
Jmo.
Doomking is offline
Old 01-14-2013, 04:46 AM
  #1282
pacoflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim,
If you ever get any video of your T-28,please post it so we can all enjoy the sound of that Saito
paul
pacoflyer is offline
Old 01-14-2013, 04:49 AM
  #1283
affas
affas's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quite different sound as well....
One chainsaw and one engine?
affas is offline
Old 01-14-2013, 11:50 AM
  #1284
CHARLES WINTER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi James, I have my gear doors figured out now. A little different approach to what is on this site now. I'll post and picture the results when I'm satisfied with my results. Pictures Many years ago.. Col. Chuck Winter
ID:	1840427   Click image for larger version
Old 01-14-2013, 12:22 PM
  #1285
JamesPool
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Normal0unctuationkerning>unctuationkerning>falsefalsefalseEN-USX-NONEMicrosoftInternetExplorer4
Hello Charles: Iapologize about the delayed response. I'm generally pretty good about keeping up with these topics, so Ifeel bad about not getting back to you in time.
I've flown her 3x now. On the 3rd flight, the nose wheel linkages bound and nose gear "jammed" in the ¾ position. Imanaged to get her down with minor scraping on the bottom of cowl (and broken prop). Ihighly recommend NOTusing their linkage method for the nose steering. I've since build a custom horn with ball links on the side of the horn I'll send a pic tonight. Regarding the main gear, I haven't had any issues, but they are on the edge of not having enough force to retract. Iwouldn't want to retract with only 40psi. In fact, I'm thinking about retrofitting with Lado (SP) 666 motors. Any comments from anyone one the ease of the retrofit? I have sierra gear with brakes.
Beyond this mishap, the Ilove flying the plane. Itflies and most importantly it lands absolutely beautifully. And, the Saito 57T - W _O_W!!! It has all the power the plane needs without feeling like it’s way over powered. Ihighly recommend it. I fly about 1/3 – 1/2 stick. The sound is unmatched and it just wants to sit an idle about 800 RPM with a very pleasant gurgle and bobble. Assuming you agree a gurgle and bobble can be pleasant soundJ. I'll get a recording and post it.
It’s a fun plane.
Best,
James
Old 01-14-2013, 01:46 PM
  #1286
CHARLES WINTER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi James, Going along with "Doing My Own Thing" I'm surprised no one commented on my Nose Gear steering set-up. I use NyRod and think it's a neat setup. I will take more pictures of the rudder setup for Nyrods if your interested. The cable setup is POOR by my Fail Safe appraisal. All of my flights (4) so far were without any problems. Col. Chuck Winter
ID:	1840464   Click image for larger version
Old 01-14-2013, 01:50 PM
  #1287
JamesPool
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Our approach is almost identical.
Nice work.
James
Old 01-14-2013, 01:59 PM
  #1288
CHARLES WINTER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi James, Also, no one using Sierra Retracts commented on my Helper Spring to insure the nose gear stays STRAIGHT during the retract phase. It's possible for the nose gear to be off center during retraction and hit the bottom of the fuselage and hang up. This SIMPLE low load spring will stop any misalignment during retraction. Darrell (Sierra Retracts) likes the idea. Col. Chuck Winter
ID:	1840468   Click image for larger version
Old 01-15-2013, 11:49 PM
  #1289
CHARLES WINTER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi James, Here are a few pictures of my Nose Gear steering system. It's quite simple to make and I have used it in other aircraft. If you need more pictures or some explanations on operation, let me know.
Col. Chuck Winter
ID:	1841022   Click image for larger version
ID:	1841023   Click image for larger version
ID:	1841024   Click image for larger version
Old 01-16-2013, 01:34 AM
  #1290
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How far dose the DA or DLE 50 stick out of the cowl ??
Damo
Damo260 is offline
Old 01-17-2013, 02:56 AM
  #1291
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did they end up doing the scale exhausts system for the T-28 because its not on there site.
Damo
Quote:
ORIGINAL: rk212
Hi chaps,
I maidened my Trojan weekend just gone (DLE55) and it flew like a beauty! Still need a little more nose weight 5/6oz but it seems really nicely balanced out - dont need to full throttle it around all the time
**NEWS**
Thought I would make you guys aware that I'm speaking directly with Kelvin at Keleo Creations and after a few weeks of discussion and (begging!) he has decided that due to the popularity of the ESM T28 he will fully design and start producing scale exhausts systems for the ESM T28 - very very good news [img][/img]
http://www.keleo-creations.com/index...index&cPath=70 - watch this space! I think the product should be released fully by Feb/Mar 2012
Damo260 is offline
Old 01-17-2013, 09:51 AM
  #1292
JamesPool
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Charles:
Please find my modification... As Isaid, it looks almost identical to what you've done. Nice work!
BTW: I like to use Heli parts for items like this. I find the heli guys have far sexier parts than us simple airplane guys.
Ihope all is well,
James
ID:	1841484   Click image for larger version
ID:	1841485   Click image for larger version
Old 01-18-2013, 01:36 AM
  #1293
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well the first lot of parts arrived today so let the fun begin
Damo
Damo260 is offline
Old 01-18-2013, 12:14 PM
  #1294
CHARLES WINTER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi James, Looks like you went through a lot more effort to make your Rotating Ball holders than I did. I used old stuff I had around. My friends call me CHEAP CHARLIE, I think I'm Frugal. I flew helicopters for many years. I was the CD (Contest Director) for helicopters at the 1983 AMA Nationals held in Reno NV. I also designed and CD the "Merced Helicopter Fun Fly" from 1982 to 1992. This Fun Fly was considered the largest in the country. During the 7th year we had oner 225 helicopters on the ramp. I'll take some more pictures of my T-28 Rudder/Nose gear setup if you want. Picture "Article in Magizine about the Merced Heli Fun Fly. Chuck Winter
Old 01-19-2013, 03:52 PM
  #1295
CHARLES WINTER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Sid - My F-86D (Byron Ducted Fan) and the front of my Hobby Shop "Hobby Castle" I had my store for 20 years after retirement. I retired in 1975. Chuck Winter
ID:	1842238   Click image for larger version
ID:	1842239   Click image for larger version
ID:	1842240   Click image for larger version
Old 01-19-2013, 04:50 PM
  #1296
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chuck,
While you were running your hobby shop I was building RC radios in Denver, Royal Electronics. I ran that company from 1969-1983. All US companies but Ace Radio gave up production in 1983. Also my college room mate, Sam Snyder, had a hobby shop about that time, I think he was in Fresno but not sure now, might have been Modesto.
Was your ducted fan F-86D a Byron?
Picture is my first production radio, 1969.
Sid
sidgates is online now
Old 01-20-2013, 02:23 AM
  #1297
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I made a start on the wings today with the upgrade parts lot better than what come with the kit. I am planing on using the DA 50 with the Keleo Creations scale exhausts systems.
Damo
ID:	1842428   Click image for larger version
Damo260 is offline
Old 01-25-2013, 11:33 AM
  #1298
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Tomas, I sent you a couple emails now with no response I understand your busy but we need to fix my shipping price up
Damo
Damo260 is offline
Old 01-25-2013, 11:02 PM
  #1299
CHARLES WINTER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Thomas, This seems like the best way to GET TO YOU. I need a T-28 Center Wing section that has the cutouts for the landing gear doors. The center section I got was VERY Warped and no cutouts for the center doors. I will pay for the center section if you can get one for me. If you remember I was Shorted the aileron and flap covers. I made my own and painted them and you said in a PERSONAL phone call that you would give me a discount on my next purchase. The center section with Landing door cutouts is my next purchase. Col. Chuck Winter
ID:	1844378   Click image for larger version
ID:	1844379   Click image for larger version
ID:	1844380   Click image for larger version
Old 01-26-2013, 02:22 AM
  #1300
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I order one these today TBM 20x12 Carbon Fiber 3-Blade Scale Adjustable Pitch Propeller for the T-28.
I got the wings almost done post pics soon
Damo
Damo260 is offline
Reply
Display Modes
