NEW Top Flight P-40??? 1/5 scale
#276
RE: NEW Top Flight P-40??? 1/5 scale
quote:
ORIGINAL: kochj
Top Flite P-47D Thunderbolt Giant Scale RTC due July/August
If this trend continues, there will be a P-40 RTC version Jan/Feb 2011...
JMHO....
Where did you see that?
Read more: http://www.rcuniverse.com/forum/m_96...#ixzz0uKlOKxEH
ORIGINAL: kochj
JMHO....
http://www3.towerhobbies.com/cgi-bin...?&I=LNZHK0&P=G
#281
My Feedback: (37)
From looking at the pictures, the control surfaces do not use scale hinging?? Means that the control surfaces leading edges are angled cut for deflection instead of a half circle that rolled inside a faring, you can literally see right through the hinges. Reminds me of the big P47 ARF. The only fix to that is an ARC. IMHO the ESM was done better in that department.
#282
The leading edge of the control surfaces do indeed, look beveled. If u want to hollow out the trailing edge of the flying surfaces, I reckon you could.
#283
My Feedback: (54)
CT
Thanks for the link, I'm sure others will appreciate it also. Mine arrived today according to UPS tracking, can't wait to get home to check it out!! We should have known LDM would be all over this one.[&:]
#284
My Feedback: (54)
CT
Ok guys, once again Top Flite has come through. Did a quick once over to check for any shipping damage, none very well packaged. From what I saw it looks to be very cool. LDM you have got to get one of these. Now I can't wait to see the giant scale P-40, guess this will have to hold me over until the big one comes. In my opinion it out does the VQ P-40 in the looks department. I'm HAPPY
#285
Guys this thread was started about the large scale new P-40 which is the reason us people that are interested in the larger one check back on here ...lets not hi-jack this subject for the smaller P-40.
If you want to talk about "it" start a different one.
#286
My Feedback: (15)
ok sorry , we wont talk about the littel fun good looking P40 any longer , lets sit around , be depressed as we wait endlessly on the delay of the large P40 .
Promise , last post of the little guy , but I want one !!!
Handyman thanks for the link and posting the pics
#287
ORIGINAL: MX240
If you want to talk about ''it'' start a different one.
Actually, I think there is already another thread on it. http://www.rcuniverse.com/forum/m_98...tm.htm#9826796
#288
My Feedback: (43)
fyi,
just checked tower and it says 'IN STOCK':
the web page is incorrect by listing the P-47 for the main gear.
I'm guessing these is the gear needed:
http://www3.towerhobbies.com/cgi-bin...?&I=LXZMU3&P=7
#289
My Feedback: (43)
I'm guessing that tower mislabeled 'in stock' as now it says 'late August'.
http://www3.towerhobbies.com/cgi-bin...&I=LXZKD0&P=ML
#291
ORIGINAL: samparfitt
no...
u snooze and then u lose.
Dang.
#292
My Feedback: (54)
CT
LDM Looking at the manufacturers web site it looks like the gear pods and belly pan are the only fiberglass on the wings. Wing looks to be balsa, plywood, and an aluminum reinforcement spar for the landing gear. I have everything I need to put this plane in the air except the airframe itself. []
#294
My Feedback: (54)
CT
I bought six HS 645MG servos,should have plenty of torque. I have four other HS 475 karbonite gear also, rated & 61 .oz at 4.8 volts hoping these will be alright, if not I will have to get more 645's. Like you this will be all new to me so I need some education also, especially with the DLE 55. [&:]
#295
I would suggest not to use servo's with karbonite gears in a plane with a gas engine. I have heard that the vibration will kill those gears. Go with metal gear servo's.
#296
My Feedback: (102)
Be leary of any Kabonite geared servos.. Alot of people lost airplanes due to them..there is a long thread somewhere on RCU...Here is the warning directly off the Hitec site:
Applications: Heli's and Aircraft up to 72” or up to 12lbs when using just one servo per control surface.
Note: Be aware that high vibration gas (not glow) engines combined with large contol surfaces and large thows (3D models) can put undue strain on the gears. Metal geared servos are recommended for these applications even if under 12lbs.
Warning: Do not use thread lockers on Karbonite geared servo as it will cause the output shaft to fail.
#297
My Feedback: (54)
CT
Thanks for the info, that's what is so great about these forums. I had heard about not using nylon gear servos with gas, looks like karbonite is no good also. I'll have to get a few more HS 645's. Thanks
#298
My Feedback: (102)
Ya'll may call me crazy. but i use standard servos ($9.95 each) on all my planes. Even when i did large gas planes. Like my 102" Fw 190. I use standard on all surfaces except for the elevators and rudder.One per surface. On the elevators and rudder i use the Futaba 3010 which is about a 90oz servo on 6v. I have yet to loose a plane due to a servo or feel like i have a lack of control..These are all nylon gear. I also have this same setup in my 146" Halifax...
Ty
Ty
#299
My Feedback: (27)
ORIGINAL: mike early
no...
Dang.
no...
Dang.
