NEW Top Flight P-40??? 1/5 scale
#1052
RE: NEW Top Flight P-40??? 1/5 scale
ORIGINAL: dasintex
Any suggestions for a Scale looking 3 Bladed Red Spinner to replace the 2 Bladed Spinner that came with this Plane?
#1056
My Feedback: (8)
Hey lomcevak...I have not installed the 3B yet. Shes all painted and ready to go but Im going to run a gallon on the 2B first then switch before the first fly-in comes up. Sorry I cant help ya dude. Your plane looked great in the air...3B spinning...sweeeeeeet!!!!!
#1057
My Feedback: (10)
ORIGINAL: n8622t
Dasintex you really need to speed read this entire thread before you start asking questions...
ORIGINAL: dasintex
#1060
My Feedback: (10)
Yes, I got one as well for my TF P-40; its from http://www.hobby-pak.com/ I got model# WBS04 24" X 88" its huge, looks like a sleeping bag, more than enough room $79.99.
#1061
ORIGINAL: dasintex
Yes, I got one as well for my TF P-40; its from http://www.hobby-pak.com/ I got model# WBS04 24'' X 88'' its huge, looks like a sleeping bag, more than enough room $79.99.
#1064
ORIGINAL: n8622t
definitely a full day...did the engine get too warm?
#1066
My Feedback: (8)
When you twist those quick disconnects together, be sure you hear two simultaneous clicks...I have put those together before and they werent locked into place. You can always just replace the connector if you arent sure about it...may be the thing to do. I did a DA50 the same way....overleaned the low end and she just wouldnt run without fuel...cant understand that Sounds like you had some issues with no incidents....perfect.
#1069
ORIGINAL: warhawk demon
Hey Lomcevac how did she do on the dead stick? What kind of RPM's are you getting out of your set up?
My tach battery was dead, so I don't know what it tachs yet. I am running the DA 60 and a 22/12/3 prop. I will try to get a new battery and let you know next time I fly it.
#1070
Lomcevak,
I had my gear stay down on the maiden flight last year. I was surprised they would not retract, Ihad done extensive leak testing.
On removing the wing, I found I had a quick disconnect apart. My theory is that the retract servo knocked it apart. I rerouted
the couplings to the other side and have not had it happen since.
#1071
ORIGINAL: 92ARed1
Lomcevak,
I had my gear stay down on the maiden flight last year. I was surprised they would not retract, I had done extensive leak testing.
Lomcevak,
#1072
My Feedback: (8)
just a quick note to you fellow warbird freaks (like me[&:]) WBOTX is in May and you might look up the details by going to www.wyliewarbirds.com gonna be good
#1073
FL
been working slowly on mine but I am getting there, got my da-50 on it and figured outa better way in my opinion of course to install the choke and throttle servos. I happend to have this digital micro servos laying around.
#1074
ORIGINAL: ROGER RUSSELL
I took a tip from Sam Parrifit on here and used spray foam and put into my belly pan to stiffen up.
He also did his wheel wells and carved out for his landing gear, I probably wont do that.
I have to tell you it really stiffend up the belly pan with little weight.
I can now pick the whole plane up with one hand on the BELLY and prop and no worries of denting in the pan.
I drilled three holes in the pan (two in front and one in rear) for the foam to expand out.
IT DOES GET MESSY, but worth it.
To get the dried (8 hours later) foam off I used a sharp chisel.
#1075
My Feedback: (10)
ORIGINAL: n8622t
