NEW Top Flight P-40??? 1/5 scale
Reply
Old 04-13-2012, 08:22 AM
  #1101
warhawk demon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW Top Flight P-40??? 1/5 scale
Yeah .. thats high expansion.. i wouldnt use it . you need the blue with yellow cap. its made for windows so it wont bow them when it expands.
warhawk demon is offline
Old 04-14-2012, 05:16 AM
  #1102
lomcevac540T
lomcevac540T's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: warhawk demon
I'll pick some up this weekend. Thanks!
lomcevac540T is offline
Old 04-14-2012, 06:32 AM
  #1103
dasintex
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Found the Blue Can stuff at Home Depot, in the Insulation Department
dasintex is offline
Old 04-14-2012, 02:26 PM
  #1104
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WBOTX coming up in June...you guys need to check it out!! Should be a great time this year
www.wyliewarbirds.com to get the details
n8622t is online now
Old 04-19-2012, 12:39 PM
  #1105
warhawk demon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey if you havent done yours yet. cover the surface around the holes you make with 2inch wide blue painters tape first and let the tape hang down 4 or 5 inches below the holes and your clean up will only take about 30 seconds. did mine last nighrt it worked great.
Old 04-19-2012, 11:27 PM
  #1106
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't get it on your clothes[:@]
Old 04-20-2012, 05:03 AM
  #1107
ROGER RUSSELL
ROGER RUSSELL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: n8622t
I said it was messy
Yes I used the blue tape....etc and it does help, even put foam in the smaller belly pan part attached to the fuse.
PS:
Hope to maiden mine this weekend!
ROGER RUSSELL is offline
Old 04-22-2012, 11:12 AM
  #1108
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
went out for the maiden of my P40 and BF109...P40 didnt go due to a choke servo going snafu[:@] 109 went very well
ID:	1753634   Click image for larger version
Old 04-25-2012, 07:36 AM
  #1109
CAURIMARE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice looking birds
CAURIMARE is offline
Old 04-26-2012, 11:11 AM
  #1110
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks caurimare....went through the P-40 and replaced the bad choke servo. It may have been vibration that killed it because it was actually glued solid to the floor beneath it. The new servo is shorter so it wont make the contact....should be a go this weekend, will try to get video for it.
Old 05-01-2012, 03:23 AM
  #1111
Dblex
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So the tower hobbies Jtech muffler exhaust tubes are too short????
Has this been corrected or do I need to cancel my order? And order direct?
Dblex is offline
Old 05-01-2012, 05:17 AM
  #1112
dasintex
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dblex;
It looks like the problem has been corrected, they list separatley a Wrap Around Pitts Muffler for the TF Giant P-51-P-47/DA/DLE/50-55 Towers Item# LXZUKO and TF Giant P-40/DA/DLE/50-55 Towers Item#LXBFMY
First Pictue is the one for the P-40
http://www3.towerhobbies.com/cgi-bin...&I=LXZUK0&P=SM
http://www3.towerhobbies.com/cgi-bin...&I=LXBFMY&P=SM
ID:	1757376   Click image for larger version
dasintex is offline
Old 05-01-2012, 05:23 AM
  #1113
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The one for the big P-40 will protrude about 1 inch beyond the bottom of the cowl.
Lifer is online now
Old 05-01-2012, 07:55 PM
  #1114
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dblex you can just send it to Jtec for free fix if it's too short or just add the extension like I did
Old 05-09-2012, 11:51 AM
  #1115
lomcevac540T
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK... so I have five flights on mine and two were dead sticks, two were very rich engine settings, and one was when the retracts didn't go up. I don't have a real good record so far. But anyway, my question in about the DA 60. I went from being so lean that the engine heated up and quit, to being so rich it won't clean out on the top end by turning the HSN 1/4 turn out. I have never had a DA so touchy! Planning to try it again this weekend, but just wondering if anyone else is having this issue?
Old 05-10-2012, 10:43 PM
  #1116
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi lomcevak540t my DA60 ran perfectly with the cowl off but extremely lean with the cowl on...after some discussion with DA I soldered a tube on the diaphragm relief hole and attached fuel tubbing to it and ran it into the fuse area. Then I bored a nickel sized hole thru the firewall behind the carb. This fixed it to run like a dream with the cowl on. Hope this helps
Old 05-10-2012, 10:47 PM
  #1117
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A hair over factory settings on both needles and 32:1 fuel mix....she runs rich in the air
Old 05-18-2012, 12:23 PM
  #1118
warhawk demon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you guys with the dle 55. what prop are you running.
Old 05-23-2012, 07:25 PM
  #1119
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
warhawk you need to run a 20X12 if you want some real speed ...otherwise a 22x10 is perfect for everyday flying
Old 05-24-2012, 02:06 PM
  #1120
warhawk demon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks. been running the 22x10. it is doing fine but the rpm is a little low at 6400. just wondering what every one else was doing. im still running a little rich
though.
Old 06-10-2012, 03:08 PM
  #1121
dasintex
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Manual calls for 85oz/in Torque Servos on all control surfaces; what is everyone using for Flap Servos, are Hitec 5475 Standard Digital with 76oz/in sufficient for Flaps?
dasintex is offline
Old 06-10-2012, 05:56 PM
  #1122
Capt G
Capt G's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The flaps need a good servo. I use HS 645s or 5645s if you want digital.
Capt G is offline
Old 06-18-2012, 04:05 AM
  #1123
dasintex
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My P-40 is getting near completion, ran the DLE 55 for the first time this weekend, next task will be the Cowl, I am using the J-Tec Pitts Muffler with the longer exhaust tubes.
My plan is to shorten the exhaust tubes so they just clear the cowl by 1/2", and I would ideally like to just cut two 1" holes for the Exhaust tubes to extend through; is the opening of the Cowl Flaps at the rear of the cowl sufficent opening for proper cooling, I know the rule the exit has to be larger than the inlet, but if I don't have to make a larger hole other than to allow the exhaust tubes to pass through would be ideal.
If you have pictures showing this, great, or if they are posted and know the post number# would be appreciated, thanking anyone who can help me this.
dasintex is offline
Old 06-18-2012, 04:46 AM
  #1124
warhawk demon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will cool just fine. I just cut two holes in mine for the tubes. i fly 14 minutes at WOT and have no issues with heat at all. i am running the DLE55 as well.
Old 06-18-2012, 04:48 AM
  #1125
lomcevac540T
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had to close in the air intake and add some vents to the bottom of the cowl. I can get some pic tonight and post them. My engine wouldn't run right until I done this. The cowl was building too much pressure inside it and would stop the diaphram pump in the carb to stop working. Runs great now! I'll get pics on here tonight.
Reply
Display Modes
