NEW Top Flight P-40??? 1/5 scale
#1280
RE: NEW Top Flight P-40??? 1/5 scale
You might try balancing the spinner. I drill holes in the backplate to achieve the balance. Best of luck. Also, you could fashion a support strap on the back of the muffler and attach to the firewall area. Slimline mufflers have this feature.
Hope you can get this sorted out!
#1287
I hope it is the spinner thats out of ballance. That's the easiest thing to fix after the prop. Yes its possible to have a bent shaft even on a new engine. Rare but possible. When you dont know what is causing the vibration you also don't know what isn't causing the vibration.
#1288
MI
Well X Mass. day will be D Day plan on starting my build !!!!
last box from Tower Hobby today !!!!
Have every thing I need to do the Job !!! I think !!!!
added up all the parts CRIST I am glade I was one who got the great diel on the ARF
The cost was a little scray !!!
when it went over $ 2.307.00 I quit counting !!!
O Well the maidan should be intresting in the spring !!!
Mite have a fuewQT as I get in to it
read all 52 pagesOf the postand reread should help a little I HOPE R/L
#1292
I don't know what to tell you? You really need to mount the spinner somehow to see if its out of balance. If you know that the prop is in in balance can you mount the prop and spinner and balance them both at the same time? Just thinking out loud here.
#1295
My Feedback: (13)
Bob. I drilled and wired the muffler bolt, re-loctited the mounting bolts and removed the spinner. I then ran the engine for about 10 minutes on the ground with and without and with the spinner. I re-mounted the spinner an flew for about 5 minutes. All is tight so far. I will balance the spinner when I find a way.
Nelson
Nelson
#1298
My Feedback: (34)
Hey guys I picked one of thes up dureing the tower discount, so now I have
This P40 anda Gaint P47 sitting in the box wateing on me.
My qestion is why is the build threads on this bird so much smaller than the P47. Are there isssues with the P40 that make most peaple afraid to fly them?
Except the cost of the folding reatracts, i cant see why Theres not more P40's out there.
I have been to 2 war birds shows and saw 5 P51's and 3 P47 but no P40's? WhY
#1300
I've seen full scale P-40's fly more than once. But they are a pre-wwII plane and not as popular as the Mustangs and Jugs. They do fly fine though. In the modeling world I suppose it's not as popular for what ever reasons? Lots of famous pilots flew them though..
