NEW Top Flight P-40??? 1/5 scale
#1328
My Feedback: (10)
RE: NEW Top Flight P-40??? 1/5 scale
Anybody know were to get small led lights i can mount on my dash? Im going to hide my switches under the cowl and want to be able to solder a couple lights inline so i remember to shut switches off.I looked at radio shak and i dont think theres will work with a 6volt system. Thanks.
#1329
My Feedback: (34)
Guys Im a little worried, I don't see many build issues with this bird except the ones I mentioned earlyer,
But I was putting in my Rudder servo yesterday and the back have of the servo tray came unglued!!!
I put some triangle stock under to keep it strong but I would of hated to lose the tray that holds the rudder and elevator servos.
Did you guys use the supplied Pull Pull Line?
#1330
My Feedback: (8)
This was a great ARF with few issues. That being said, you have provided a great teaching moment. Any ARF (or for that matter any plane that you did not build yourself) should be carefully gone through from one end to the other and tested for the integrity of glue joints etc. I also use judicious reinforcement on areas that i know will have high stress such as firewalls, wing mounting plates and - yes - servo trays. Good luck with your build.
#1335
My Feedback: (34)
ORIGINAL: SWORDSN
I used Krylon. Italian olive for the OD and tan for the tan...both are satin finish. For the gray i used walmart brand primer. Hope this helps!!
thanks it dose. If you find time to post the paint codes on the cans. That way people can order them that would be great
I was able to fit both my main power and ignition switch and my fuel fill and air fill all under the little fiberglass cap that gose on the top connected to the cowl
#1340
My Feedback: (34)
Thanks for the info
Hey guys how are you gettng the cowl on this bird.?
I got the JTec muffler that tower recommended. With DLE55. I cut a hole for just the 2 pipes to stick out but ther so long I can't get the cowl on. I even tried leavening one bolt on and I still can't get it on.
It seems the only way is to leave the muffler off in the cowl then put the muffler on afterwards which will be a pain
#1341
My Feedback: (10)
ORIGINAL: mikes68charger
Thanks for the info
Thanks for the info
#1344
My Feedback: (13)
Well after about 15 flights my J-tec muffler is loose again. I have another muffler that I bought at a swap meet (SL2123). This muffler is much beefier and the pipes are short but I will try it. The muffler chamber touches the cowl. I don't know if the heat will be a problem. Does anyone have any experience with?
#1345
My Feedback: (10)
I have a DLE55 Mounted on this Bird with the P-40 Jtec Wrap around Pitts exhaust with the Exhaust Tubes Shortened, I read about the exhaust bolts vibrating loose, I went ahead and used Wire Lockable Bolts to eliminate this as a problem, I have also read that vibration will bust this style of exhaust, not sure about Jtec, is there any need to make a support strap for the Exhaust? I like to fix any potential problems before they actually happen, and before I mount the cowl.
#1346
My Feedback: (13)
I have cracks in the muffler header,that is why I'm trying a different muffler. I installed the muffler without wires to begin with and when it came loose I installed the wire. I had the same problem on my giant scale TFP47. I finally had to use the stock muffler which has worked fine. The cowl is to narrow on the P40 to use the stock muffler unless you butcher it. I'm not trying to dump on J-tec,but I have not had a good experience.
#1347
My Feedback: (13)
#1348
My Feedback: (10)
Sorry to hear that, do you think a support strap would have helped, or was the cracks caused when the exhaust bolts vibrated loose, before you had a chance to use Wire Lockable Bolts? My plan using 1/2 to 3/4 inch wide aluminum strap which will be secured to round Muffler End plate/Disc, and the other end secured under the Engine/Standoff Mounting bolt.
#1349
My Feedback: (13)
I did that on my last muffler and when I talked to J-tec he said that would void the warranty,but I have seen others do that with success.I did try the strap but the cracks were already showing. I believe what you are doing is the best approach I tried to do piece meal and it didn't work. Others on this thread have used the same muffler/engine combo and don't seem to have this issue. Good luck!
I plan to fly this PM will advise
Nelson
Nelson
#1350
My Feedback: (13)
Well,I flew for about 30 min total flight time and no muffler issues with the Slimline muffler. The only concern is heat where one edge of the muffler touches the cowl. It feels hot to the touch and I think over time it will effect the cowl. May have to cut a slight hole. OH how I hate to cut this one!!!!!
