12th Scale Martin Mariner Build
RE: 12th Scale Martin Mariner Build
Howdy Bryan, I hope to be sheeting those big beautiful wings this week ,and the good news is that the rivet lines are not doubled on the wings.I am working on the leading edges which are made of balsa, the rear will be routed out in the center to fit a carbon fiber tube. the plans didn't call for this but I thought it wouldn't be a bad idea since I added 19" to the wing.
Happy flying NJ
Happy flying NJ
#31
My Feedback: (221)
ORIGINAL: cpt nj
Howdy Bryan, I hope to be sheeting those big beautiful wings this week ,and the good news is that the rivet lines are not doubled on the wings.I am working on the leading edges which are made of balsa, the rear will be routed out in the center to fit a carbon fiber tube. the plans didn't call for this but I thought it wouldn't be a bad idea since I added 19'' to the wing.
Happy flying NJ
Happy flying NJ
#33
Not a problem I would glad to help you there was definitly a learning curve to working with extruded foam. There are some things Iv'e learned about foam ,it Expands and cotracts to heat and cold. The foam will swell if your glass and resin isn't thick enough, and have extreme changes in temperature. You'll end up with a un sightly seams.
#34
Iv'e found two historical refrences on this particular airplane flown by Lt John Drover and crew 14 of VPB-21.The fisrt is PBMMariner in action by squadron/signal publications, the second is a book called The fighting flying boat by Richard A Hoffman. In the later reference there is a detailed account of this bird in the Pacific theater. They would send two lumbering giants on low level bombing runs, from 500' to 50' above the trees tops over the China coast, at the whopping speed of 200 to 230 nots. As the giants flew up the coast line thet saw what appeared to be a soft target, a Japaneese ship sitting idle inthe middle of a lagoon, which turned out to be a decoy to bait the planes into their doom.
Whant happened next ? buy the book. It's really informative from the begining devlopment thru the war and after.
#38
There was a guy who had one of these years ago, he used to fly it at lots of shows, and it had Estes rockets for takeoff assistance, it was impressive.
#40
You're very welcome! Your model is tremendous!
Like many people, over the years I've enjoyed a couple of connections with the PBM.... the privilege of knowing a former WWII-era Mariner pilot ...sadly he died this year []... and of course that old Revell model kit, and also near Boston is the old US Coast Guard Air Station in Salem; extant are some great vintage photos here and there of Mariner ops at Salem.
#42
My Feedback: (18)
O.K., I couldn't risist commenting when I saw the thread. I hate to say it but I started Keith Sparks design about five years ago and have yet to finish it. I'm feeling the urge with the sight of your PBM cpt nj.
I've got both books you mentioned and I even have the Revell kit of the plastic PBM.
The fuse is completed and the wings are cut. I have to finish my Concept Fleet rebuild (ASP 4.00 radial powered) first, then I think it's way past due for the PBM.
Your detail looks great. I like the cable across the bow. Nice touch.
Bob
Bob
#43
Well my sheeting came but it was the wrong size still waiting ........ so in the mean time I needed a new float plane to play with,had some old floats and a wing. Two and a half weeks later this is what I come up with . Please excuse it's not quite a warbird.
#46
Hey Bob ,I don't know if this helps but I feel likeI'll never finish. Iv'e put her away for months just because I was getting burnt out. What I tell my friends who ask when she'll fly ? When shes ready . Be glad to share ideas with you and thanks for posting. NJ
#47
Bryan heres a picture of a negative templet i used to cut my outer wing panels. the templet was mounted on one end and the other end of the hot wire was anchored to a single pivioting point, here check out this you tube video. YouTube - Hotwire demonstration
#48
My Feedback: (21)
Too cool! I'd never thought of cutting foam wings in that manner, but it looks like it works very well indeed! Did you cut your wings from pink foam or white foam? I've got several projects on the bench in front of this one, but I'm chomping at the bit to have a go at building her!
#49
Bryan its pink got it at the home depot store ,the problem is the wing cord is 3 inches at its widest point so I had to laminate two 2 inch pieces together with 3M77 the weighted down over night, From what I understand they can only make extruded foam 2 inches thick. The plans calls for white expanded bead foam but the extruded is rated a 22lbs per square inch .The difference in weight is slight, I'm right on track with a projected weight of 18 to 19 pounds at flight time.
P.S The reason for the 3M77 is that your hot wire wont get snagged like it would on epoxy, but after the cut and before you sheet seperate the two halfs and then apply epoxy drops randomly ,reposition the two halfs together and weight down in their cradle.
#50
My Feedback: (21)
I've never hot wire cut anything but white foam. I bought a sheet here locally from Century Jet Models, 4x8x4" thick, and it made several wings for a buddy and me. That's been a while, but I'm thinking it was somewhat costly through them, maybe I can get the white foam somewhere else, or do like you did and just use the pink from Home Depot, I know they have it! That foam cutting technique is pretty awesome, I would have never thought of doing it that way, but obviously it works well! Keep us posted on your progress!
