ESM 50cc Corsair
Reply
Old 06-29-2010, 12:57 PM
  #51
sahill
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ESM 50cc Corsair
I am considering the ESM 50cc Corsair ARF...any comments - good, bad or indifferent?
sahill is offline
Old 06-29-2010, 01:14 PM
  #52
Shaun Evans
Shaun Evans's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone know of anyone currently building one of these who also has a camera?
Shaun Evans is offline
Old 06-29-2010, 02:32 PM
  #53
kwik
kwik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paps, when I enter that address in google, I end up in Birmingham, not in London.
kwik is offline
Old 06-29-2010, 04:08 PM
  #54
Paps
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
kwik does it matter really? I mean YT are the only ones in England that sell these anyway.
Paps is offline
Old 06-29-2010, 04:56 PM
  #55
kwik
kwik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I see. Yes, it matters to me. I will visit London for the Duxford show.
Will be there a couple of days.
Dont think I can go all the way to Birmingham, though.
kwik is offline
Old 06-29-2010, 10:56 PM
  #56
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
kwik, keep an eye on Lindinder. They show "out of stock" for now. They ship free in Europe
http://shop.lindinger.at/product_inf...ducts_id=85064
vasek is offline
Old 06-30-2010, 02:43 AM
  #57
Paps
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: kwik
Well in that case you should just contact them.
You will also find them on this forum: http://www.rcmf.co.uk/4um/
Paps is offline
Old 06-30-2010, 12:40 PM
  #58
Growler84
My Feedback: (8)
Growler84's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the gear and I am happy to report they are very well done. Definately a cut above the usual Chinatracks. I checked them under 100 psi pressure and the down locks work well however, there is no up lock mechanism. With 100psi on the cylinder it doesn't take a lot of pressure on the strut to force it down. So, the gear will likely sag under typical model g-loadings. One solution I'm entertaining is going with the lightest wheels possible. The other solution is retrofitting a Robart-style spring-loaded latch that will have to be disengaged with a seperate servo cable pull. Obviously the second choice is more complex and drives a 2 switch hit requirement to get the gear down. I looked at using movement from the cylinder itself ala Robart and this won't work because the Robart set up uses a floating cylinder mount and the ESM mechanism doesn't.
This is certainly a minor issue and I maintain these are still very nice gear.
No, I don't have time to muck around with pictures.
Growler84 is offline
Old 06-30-2010, 01:17 PM
  #59
fockewulf37
My Feedback: (102)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does the gear move the 110 degrees or 90 degrees. I talked Sierra and there's is going to be greater then 90 degrees to stop the nose over problem the the 90 degree gear may cause....
fockewulf37 is offline
Old 07-01-2010, 08:43 AM
  #60
Growler84
My Feedback: (8)
Growler84's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They are 90 degree units. It should not be a problem because we fly off of pavement. The increased rake is a good idea however.
Old 07-07-2010, 03:12 AM
  #61
GotSky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I'm still waiting on UPS for my claims to be settled or even better inspected - they told me there is a 3 to 5 week back log of claims. (tells you something about the amount of stuff they smash up) I really wanted to get this build under way but here I sit and wait. On top of everything else my TopFlite Giant Scale Mustang went in this weekend and is a total write off. Nothing like a dead stick right on climb out, pushed the nose down but she wasn't having it. Rolled over and went straight in.
GotSky is offline
Old 07-07-2010, 01:19 PM
  #62
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ouch.
Sorry to hear that. What happened? I'm surprised to hear that nosing it over wasn't enough to keep it flying....
Old 07-07-2010, 01:29 PM
  #63
fly4mation
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone flown this aircraft yet? I am very near completion on mine and was hoping to hear some feedback on flight characteristics, and if recomended cg and throws etc were a good starting. point. I have flown the 74in version and like how it handles .
fly4mation is offline
Old 07-07-2010, 08:03 PM
  #64
GotSky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My climb out was at a pretty good angle but the engine sputtered I feathered the stick and it came back on but just as soon as it did that it went dead. In that short amount of time and altitude I lost some forward momentum and just didn't have the space (air) for it to recover. I was able to hit high rates about 10 feet off the deck and pulled a hard flare but it still went in at about 30deg took the entire nose back to the wing with it. The engine after it broke lose then decided it wanted to join the wing - which it did . And I must say it made nice work of the left side gear / mid section.
Here are a couple picture of my ESM gear for the Corsair. Each one had screws that were backed out or very, very lose. I will be pulling each one out and putting on some lock tight. In all they look very nice and very strong.
ID:	1464758   Click image for larger version
ID:	1464759   Click image for larger version
GotSky is offline
Old 07-07-2010, 08:11 PM
  #65
GotSky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know if it helps but this plane is almost identical to the Top Flight Corsair in size and wing. I'm going with the Top flight recommendations on mine for throws. My buddy's wing mounts up perfect to the ESM fuselage and the length and weight are so close. Hope that helps a little. You can get the Topflight instructions right off of Tower Hobbies or Top Flights web sight. . The ESM fuselage is about 1/8" wider at the saddle but that's about it!
http://www3.towerhobbies.com/cgi-bin...&I=LXHU95&P=ML
Here is the video I shot of his first flight.
http://www.youtube.com/watch?v=HnNVSSB0nH4
GotSky is offline
Old 07-07-2010, 11:50 PM
  #66
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gotsky,
Geez. How can you be so naive and belligerent? You posted PICS to this thread?!?!?!? Oh! And don't even get me started on VIDEO. Haven't you been reading this thread? Didn't you notice that folks seemed to decide that there would be no pics posted to this thread in order to spite the couple of guys that had the nerve to ask for them?? Get with it, dude.....
BTW, your buddy made that Corsair look reeeeaaaallll good.
Old 07-08-2010, 02:46 AM
  #67
GotSky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, I am a rebel!! That is for sure! LOL.. The Top Flite kit took him about a year to build, glass and weather. It turned out very nice and fly's great with the Zenoha G62 and I think a 22x10 Carbon prop. I will be posting a bunch more pictures once I get started on my build. I will try to do a couple here and there as I finish steps along the way. I'm still not sure I like the cylinder engine mount set up. After it is glued in there is no access past the second bulkhead in the front. Meaning build your batteries in the front for weight but never be able to get to them again once you do. I think I may mill the bottom of the cylinder part out so I have (all be it small) some access to the front fire wall from behind. Also if you get the plane or plan on building it get rid of the cheap pin hinges that come with the kit!. They are for a 25 size glow plane or smaller and are of poor quality. You will see what I mean after some pressure is applied laterally. They stretch and are just plane weak and way to small.
GotSky is offline
Old 07-08-2010, 02:52 AM
  #68
GotSky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh and just let me know what you want to see and i will take a picture of it it might take a day or 2 but I will get it done for ya.
GotSky is offline
Old 07-08-2010, 05:19 AM
  #69
hippo-1216
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
GotSky If you could post some pic. of the flap hinge line and the angle you put them on that would be great thanks
hippo-1216 is offline
Old 07-08-2010, 09:30 AM
  #70
Paps
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
GotSky maybe if you could just post the pictures of the build along the way. That would be nice
Paps is offline
Old 07-08-2010, 10:08 AM
  #71
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gotsky,
And you'll ever be known as the man who rehabilitated this thread!
Old 07-08-2010, 06:36 PM
  #72
GotSky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am the healer. Please help support my cause and send your money too......The more you give the more I buy...!
GotSky is offline
Old 07-08-2010, 06:44 PM
  #73
GotSky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hippo. no problem. The set up looks pretty straight forward, Once I get everything lined up and set up I will put a few pictures up for ya. The slider boards in between each flap will take the most time. As it is only one side of each flap is slotted. I will probably just use some water base paint apply that to the side that has the pre cut slot ( the area of the cut out will be with out paint) lay it down flat on my work bench and press the side with the paint up against the side that needs to be cut. That will leave a perfect line where the slot line will line up. Then mark it, wipe away the paint and cut the new slot. Hope that makes sense.
As for the hinges. I'm going to do my best to get them as flush as possible. I think I might go with Hysol glue as that is what I use on my Composite planes but Gorilla might do as well. But I am speaking before I have really had a chance to look it all over I will keep you posted
Pulled it out of the box to kick things off. I still can not start building as I am waiting on UPS.
GotSky is offline
Old 07-09-2010, 12:33 AM
  #74
nemesis4u
My Feedback: (77)
nemesis4u's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
GENTS (and LADIES)
Just an FYI.. SOME or most of you will note in your retracts you are missing the TILLER ARM and tailwheel
If you ordered from us @ VQWARBIRDS please let us know if this infact is the case...
If you ordered from TBM let them know as well
CHINA/ESM is sending the parts asap to TBM DISTRIBUTION
we will get everyone taken care of...
JUST WANTED TO COME FORWARD and let you know..
WE always try our best to provide best communication as possible...
BTW... YES we are excited about pushing on with SIERRA FOR THE SIERRA ESM 50cc RETRACTS!!
WE HAVE THE SIERRA ESM 50cc SPITFIRE RETRACTS INSTOCK READY TO SHIP NOW!
http://www.vqwarbirds.com/product_in...2c000ea5a4764c
we do have the 50cc CORSAIR COCKPIT KITS INSTOCK TOO (thanks TYS PLANES)
LOVE YOU GUYS!!
-TOMAS
VQ WARBIRDS
"KEEP 'EM FLYING"
www.vqwarbirds.com
info@vqwarbirds.com
nemesis4u is offline
Old 07-09-2010, 02:28 AM
  #75
kwik
kwik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: GotSky
Good Grief what a beauteful airplane!!!
MUST RESIST BUYING ONE! MUST RESIST! MUST RESIST! Arrrghhh.
kwik is offline
