ASM B-17G Flying Fortress ARF (120
#276
FL
RE: ASM B-17G Flying Fortress ARF (120
ORIGINAL: MANFRED
Those are turbos not exhaust
SR
#277
FL
ORIGINAL: Bob309
OK Guys,
Working on the Bomb Bay Doors Next. Here are some pics as I get started
OK Guys,
I noticed your making a mold of the bottom for the bomb bay. Are you going to just make doors or the entire bottoms tray? I was going to make a mold also. I have plans on doing the entire bottom with reinforced edges so that the doors can be mounted to it. There isnt really any need in all of us making a mold. Is anyone going to make a kit?
SR
#278
ORIGINAL: testfly
Hi Edgar,
I have a Airbus 380 with long motor wires on inrunner motors. The C-130 and B-25 have long battery wires on outrunner motors.
I understand there is a risk by using long battery wires.
I have two reasons for using long battery wires.
1) To help balance the model without adding a lot of weight. (By moving the batteries)
2) Leaving the ESCs in the nacelles offers them more and better air flow.
When adding long wire I do the following:
I add no more wire than needed.
I make sure I have a solid solder joint.
I use #8 wire.
Hi Edgar,
I use #8 wire.
I have changed my way of thinking after reading this information. http://www.rcgroups.com/forums/showthread.php?t=952523
If you don't review the info on the above link. Review this one. It is short and to the point http://www.rcgroups.com/forums/showp...2&postcount=32
I plan to go back to the C-130 and the B-25 and re-wire both of them.
I have always mounted ESCs for good air flow so re-mounting them was not hard to do.
Below are a few images on how it was done. The belly pan will cover them and I plan to cut vent holes in the pan when I mount it.
#279
FL
ORIGINAL: testfly
I have a couple questions. First why not just add the capacitors? They would be simple enough.
Next, why are all of the foamie manufacturers running long battery wires? I have a B-25 from Hobby Lobby with long battery wires and as I'm writing this I just remembered that it fried its 20 amp speed controllers on start up. Almost all of them did as I recall from the RCGroups thread. Hobby Lobby replaced them with 30 amp controllers. I havent had any problems since. Quite a few foamie B-17 are about to hit the market also, I bet they will have long wires too. Hummmm.
SR
#281
FL
ORIGINAL: MANFRED
[youtube]http://www.youtube.com/watch?v=KFwwgbj9Bi8[/youtube]
SR
#282
Hi SR,
There are a few reasons not to add the caps.
#1) If I add one for every 4" of wire then 32" would need 8 caps.
That will take up a lot of room in the small outer nacelle.
#2)Adding caps puts another item in the power line that can fail. (8 items on the outboard motors)
#3) At some point I plan to do some testing myself to see the effects on long and short motor wires as well as long and short battery wires.
I plan to take 3 motors and 3 ESCs and wire one as a control. Wire a second with long battery wires and the third with long motor wires.
I plan to run all 3 from the same ch on a radio and at the same time.
BTW Did you read this from the second link I listed?
"blimp 30 feet of wire to speed control and steering motor in the tail.
control voltage rating 60 volts 50amps motor load 12v 20 amps
result instant smoke first run of motor. I replaced control at no
cost . same result instant smoke. then i was told about long wires
ran a test with 3 ft cord result 30 volt swithching spikes on 100 uf input cap.
had customer put control near battery in gondola. 30 ft wire to motor
end of problems."
Also it was noted that by using a larger ESC it will help as the caps can handle more.
At any rate with lots of $$ invested in the B-17 and my plan to fly it often. I could not see taking a chance after a friend had taken the
time to send me the first link I posted and after I spent about 6 hrs going through all the links and related post.
In fact I had the plane ready to maiden Thursday. I got the link that evening and by 6:00 PM on Friday I had all 4 motors and ESC's off the B-17
and was prepping the wing center so they could be mounted there. I was up at 3:00 AM on Saturday to finish the wiring so as to keep the Saturday Maiden plan.
FWIW- I fly a airbus 380 that has long motor wires and have had no problems with it. (see image below that was taken from my A380 project page)
Next time I have the B-17 out I want to check the amps and watts to see if there is any difference in long battery wires and long motor wires.
With long battery wires I was pulling 46.84 amps and 719.7 watts turning a 12X8 3 blade MA prop on the ground.
end of problems."
#283
I wrote something about this a couple of pages back that long DC cables are a big NO-NO..
This is why both Ivve with his B17 and me with my Lancaster has the batteries and speedcontrollers up front next to the lipo:s..
I have the A380 from hobbyking and the ESC are next to the Lipos in that one too...
Edgar,with the setup we use we havent experienced any problems with heat so far..
//Bokis
//Bokis
#284
FL
Remember at about pages 3-5 we were having troubles with oversized photos and upload failures? None of the pictures work for larger photos and the oversized photos are deleted.[:@]
SR[&o]
SR[&o]
#285
FL
I was asked how I weathered my plane on another thread. I thought I would post it here also.
I used an airbrush. The panels were made using a double "Frog Tape" and "Friskets" technique. They are a green low tack tape and a vinyl mask off repectively. Put the Frog tape on your arm first to make it extra low tack then lay it down on the line. The Frisket mask is ready to use out of the bag.
Using the airbrush, spray down the tape line with the color of your choice. Pull it up in about 30 seconds and lay it back down on the paint line you just sprayed but on the other side. Im using Testors Model Masters Enamel. It dries almost immediately. Place the tape so it leaves the panel line the size you want. Tape off the side panels from overspray. Respray it. Pull up the tape and you have a weathered panel line. Make the "upwind" side lighter and the "down wind" heavier or "pulled" out. (Sorry about all the "xxx"s.) If you dont want a line, just respray with out the tape over the painted line to fade it in a little.
The entire top side of the wing only too 2 hours to paint all of the weathered lines on the 10' wing. After I placed the lines, I chipped the paint with Floquil Stainless Steel and then faded the entire wing with Floquil Earth . I really over did it with the chipping and will be removing some of it. I dont know if other people use this technique to place the panel lines, I just thought it would work and it does. Call it the SpeedRacer Technique. This is actually my first weathering attempt. Another guy (Thanks again David)gave me the colors he uses and I used them and then experimented after I gained a little confidence. I started with Floquil Weathered Black and Floquil Earth. Soon I was blending in Faded Olive Drab.
Where it was oversprayed or too dark I just resprayed with another color to dull it out or pull the color back out.
The streaks of oil and smoke were the most fun and really allows you to go nuts adding different colors. If you dont like it just spray over it until you do.
After I was happy I cleared the whole wing in Flat Fuel Proof.
Harbor Frieght has airbrushes of great quality for $20 everyday and $10 on sale. They are Dual Action, Internal Mix, Siphon Feed and work very well. The 10' air hose is $7 and has the fitting to attach to a compessor hose.
Get the airbrush and play around with Acryl black and a piece of cardboard to gain confidence. Then find a crashed plane part, clean it up and just go at it. It will come to you with time.
GO FOR IT!!
SR
GO FOR IT!!
SR
#286
FL
This weekend I took her back out to the field. Everyone was more interested in the stand. They had me take the plane off so they could take pictures of the stand.[sm=confused.gif]
I did manage to take off about 75% of the aluminum chipping to a much better level and finished the weathering on the bottom of the fusalage after I brought her home. Bad weather prohibited photos.
SR
SR
#287
OK here we go! Yes I am building a frame for my bomb bay doors. As you can see (also listed in pervious post) I am using 3/16" hard wood for the bay. This will strengthen the wing when installed. (Please cut ALL parts and trial fit first. I also ran my wiring before gluing in the formers with (V-Poxy) instead of epoxy. I am going to cover the doors with ABS plastic and paint. I will post more pictures in a day or so.
#288
Bombs for the plane? Well I would like to thank my brother who is working on the bombs and the bomb drop system. Can't wait to see them finished and painted.Don’t know how he does it, but he does. I think he used Easter eggs and pill boxes. I will ask
Maybe I can fir M-80's in them! (Just Kidding)
The Easter Bunny better watch out! I just might return some eggs.
#289
FL
ORIGINAL: testfly
As I recall your not to far down the road from me.
Humm Want to weather another B-17????? hint hint
I'm off work from the 19th -27th. Bring her by. It wont take long with two of us. Pick out a scheme. BTW, it doesnt have to be war torn like mine. Just lining her out makes a world of difference! I bought a new airbrush that can paint a hair line. I cant wait to use it.
SR
#291
VA
ORIGINAL: Edgar Perez
Hi Bob,
Any updates on your side? I also intent to do mine electric with the sound system (Benedini or ModelSolutions). Thinking Scorpion 4020 with MAS 13X8.As per ScorpionCalc it should have about 676W of output power with a thrust of 8.5 Lb per motor (using Prop kp =.76).
Anyway, i'm a newbie on Electric and want to make sure I'm doing it right.
PD: Do you thin the 4 inch speakers will fit? Fuselage or wing?
ORIGINAL: NUMB LOCK
I'll be setting mine up with a Benedini Sound System. I've already tested this set up in my ESM/KMP 80'' Stuka
With the speakers mounted in the wings...it is a natural sound box making it a bit louder.
http://www.youtube.com/watch?v=pxzAQGZEam4
I've also cut out part of the root rib on the center wing to see how big a Lipo I can fit in it to power an outer motor.
6S was tight and right up against the balsa sheeting. 5S will do fine...this one is a Hyperion 5S 35C 5000mAh.
I was thinking of the Scorpion 4025-10s for power.
Bob I.
Bob I.
Needless to say, this new winter hobby took over...but I'm getting the bug to get back to this.
This is honestly the first day I've even glanced at this forum...seeing where you guys are...all are incredible.
I'll have to read this thread from the beginning again.
Bob I.
#292
My Feedback: (30)
GA
Hey Guys, I been reading this thread everyday! Could not stand it any longer I ordered my B-17 today it should be here monday or tuesday. I am going with 46 thunder tiger pro engines and 3 blade props.I had a 102in B-17 a few years ago and hated selling ever since.Will count on you guys for some pointers on building it,Thanks Randy
#296
I need the parts.
I have the paint.
long story short....While working on the bomb bay build I had put the front half of the fuselage on a stool to take a few measurements. The problem is that I left it there and walked back over to the bench to make a cut in the wing.
Just after the cut I hear a CRASH and when I turned around the fuselage had hit the floor. Talk about a sick feeling. I had just added the nose art and ball turret just a few hours before the fall.
Well, after looking over the damage I need a few parts.
I need the nose turret (gray) bottom turret (gray) gun set (black)
Not sure what it might cost but I may want a front fuselage to replace this one as there is a 3" crack on the top of this one now.
The crack has just been repaired. but, I may end up replacing it just because I know it is there.
I need the turret parts right away. We have an event the second weekend in March and I need this one ready to fly.
I have the paint.
#299
My Feedback: (30)
GA
I picked up my plane from fedex this morning,I had a few little things damaged but nothing that took just a few minutes to fix.I have got all my control surfaces glued in.I am calling it a nite for now and will install tail retract and vert.stab and rudder tommorow.Later Randy
#300
Bomb Bay Project has been completed.
I wanted to use the B-17 for the candy drop at our club events.
I also wanted to load the plane from the top.
I have used my B-25 for the last few years and I have to load it by turning the model on it's back.
I have updated the following video link with the latest information.
http://www.seabreezeparachutes.com/b...7-bomb-bay.wmv
You can also view more information on page 13 of the B-17 project page.
http://www.seabreezeparachutes.com/b...w-page-13.html
