Ziroli Stuka wheel spats mounting question
Reply
Old 06-21-2010, 02:11 AM
dvs1
dvs1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ziroli Stuka wheel spats mounting question
Ok guys I need some more help on my Ziroli stuka. I need to get my wheel spats mounted, and I was wondering how the best way to mount them is?
The Spats from Ziroli come with white ABS mounts but they are much smaller than the inner dimensions of the spats so im a litte apprehensive how to go about doing this.
Im using my own 1/4 inch bent steel wire landing gear as well. So if anyone has some pics and explanation of how they did theirs I would be greatly appreciative.
Dont really know if it matters much either but my wing is a 3 piece like some of you have done before.
Curt
dvs1 is offline
Old 06-21-2010, 08:02 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ziroli Stuka wheel spats mounting question
I suggest that you mount the spats to the landing gear, and not the wing. The LG flexes on landing, sometimes forcing wing mounted spats through the sheeting. Leave 1/4" space between the spat and the wing.
I threw the ABS spat covers away. As you said, they don't fit. They are cosmetic, not intended for mounting the spats.
TomCrump is online now
Old 06-21-2010, 11:03 AM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's what I had to do for a Curtiss A12 I designed. A single piece of 1/4 inch piano wire will not be sturdy enough. I used a Robart 1/2 inch strut with a fork for the wheel. The strut was epoxied into a maple mount and the mount was epoxied to a plywood base. Maple motor mounts were epoxied to plywood ribs in the wing. The wheel pant was screwd to the wing with nylon screws as break away devices. The plane weighs 20 pounds. Maybe this will help. Dan.
ID:	1456356   Click image for larger version
ID:	1456357   Click image for larger version
ID:	1456358   Click image for larger version
All Day Dan is offline
Old 06-21-2010, 11:52 PM
dvs1
dvs1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the tips, ill just plan on attaching them to the wire gear as the plans show then.
dvs1 is offline
Reply
Display Modes
