Twin-engine warbird query
Looking for a "smallish" twin-engine warbird. Something in the .40 size or so. Would like to use a couple Saito .72s
Doesn't seem to be a big market.
Any suggestions?
Any suggestions?
RE: Twin-engine warbird query
Ijust saw the B26 on the Easy Tiger website, it looks good, but Idon't want that size of plane these days.
The Hangar 9 B25 is an excellent model, you can't go wrong.
I saw a ASMP-61 at a meet last weekend, it flew good.
Ihad a VQ models A-26, run away from that, it was a disaster.
I think that's about the only twins in that size, but maybe others know more.
The TopFlite B-25 would be better off with .82 to 91 4 strokes.
For .72 4 strokes, the H9 B-25 is the best bet......BUT...there is also the CMP Mosquito.
http://www.nitroplanes.com/mosquito.html
Easytigermodels has an ME-110 at 72" wingspan that could take two .72s also
http://easytigermodels.com/index.php...2497660f892d07
Messerschmitt Me-110 Twin With Retracts seems the best so far. Damn, it looks pretty nice. I wish it cost 350 dollars and not 500.
VA
I have the 96" KMP Bf-110 and it is a sweet flying plane with two Saito 100's at 22 pounds. I have seed the Don Smith Bf-110 at 118" fly on rails.
I also have the ESM 95" ME-110. Two saito 72's are too small for it, but two 91's would fly it decent enough. It costs $419 ...less then the smaller 72" Easytiger...but not with retracts...thats another $199.
http://www.troybuiltmodels.com/items/ESMBF110C-95.html
Specs list two 91 4 strokes.
I also forgot about the 83" ESM Tigercat. Spec's list 91 size 4 strokes, but with an 83" wingspan, im not sure thats required since the much larger ME-110 specs list the same motors. You'd want to read threads about it first to see what others have used successfully.
http://www.troybuiltmodels.com/items/ESMTIGERCAT83.html
In any case...if your using two glow motors, they both MUST have onboard glow. Id also recommend either having the onboard glow on ALL the time to prevent a motor quitting in flight or use a twinsynce device. Some ppl use a gyro on the rudder instead of a twinsync, but the gyro only effects the rudder in case an engine dies, the twinsync monitors both engines and if one dies, it'll automatically dial the running engine back to idle to prevent the plane from being pulled into a spin due to asymetric thrust
CA
How bout a Royal B-25 kit ...oh gosh i said the "K" word didn't I?
It's a great for your application as it was designed around .40 2 strokes with a 76" wingspan.
Very scale and you would get serious props from the scale guys at your field. They don't make them anymore, but there are lots to be found on RCU or Ebay. You can get plans, cowls and canopy on Ebay as well.
BH Models B-25 Mitchell EP/G Twin is a possibility. Smallish. Light.
http://www.hobbypeople.net/gallery/159552.asp
I imagine 2 Saito .40's would give it scale performance.
BH also makes a Mossie
http://www.hobbypeople.net/gallery/159550.asp
Says EP but I've converted Electric-to-Glow on a couple planes already.
Now that I am re-visting this topic, most of the links are dead. It's a shame that there's not a P-38 available anymore. That's closer to my definition of a warbird than a bomber...
My Feedback: (10)
ORIGINAL: mike early
P38's dont fly well with one engine out. I would go electric if i wanted a p38. Gas maybe, glow no way...
Im surprised no one mentioned the CMP mosquito. Its perfect for two saito .72s. I have this plane and installed two saito 91s and the plane is a rocket ship. Nitreoplanes still has them. However, they arent as cheap as they usedw to be. When I got mine from them last year, the plane only costed $199.
http://www.nitroplanes.com/demotw2573en.html
With .91's as seen in this pic of mine next to a friends with .46 2 strokes...theres a decent space between the spinner backplate and firewalls, but a 72 should work nicely.
ORIGINAL: kahloq
I was following your build on the 60-page long DeHavilland Mosquito thread. You stopped posting over there...it saddened me!
400 bucks at Nitroplanes, but still $210 at Raidentech with coupon code pickle1088
One problem I might run across is the nacelle-to-fuselage distance needs to be to at least accommodate a 12" prop. Will probably use 12x8 three blades for the Saito 72.
Was going to dip my toes into twin-engine with the Hobbico Twinstar but I do not think the 72's will fit.
The DC-3 would be lovely.
ORIGINAL: kahloq
Yeah. Ive flown it 3 times. Did a nice formation type flight with Chris's esm B-25. Like scale, my cmp mossie was quite a bit faster then his b-25, but together in close formation...they really looked good.
One problem I might run across is the nacelle-to-fuselage distance needs to be to at least accommodate a 12'' prop. Will probably use 12x8 three blades for the Saito 72.
I have the Twinstar and am flying on 2 os .25's. The 72's may be a bit much power imho. But then my cousin would say put some 91's on that bad boy lol.
If you're going to do a twin...come on man, you gotta do a military plane.
To be quite honest...the hangar 9 b-25 would be absolutely perfect for twin .72's. A nice 80" wingspan with pretty scale looks. Also, the BH A-26 is a nice looking plane and designed for .52 4-strokes. 72.s would also work quite well, though Id paint the plane black.
http://www.hobbypeople.net/index.php...ip-tanks.html#
An nice old man at my club has had the TF B-25 for 3 years and all he's done is hinge the surfaces so far. He also bought the Robart retract set for it. He probably has 1000 or more dollars in those two items alone. He wants to sell it to me, but we'll see what he'll take for it.
If it's too much, I will buy the CMP Mosquito and try to fit some HK electric retracts with some robo struts I have.
