View Poll Results: A poll
Foam 2 piece wing.
13.85%
Built up 2 piece wing.
23.08%
Foam 3 piece wing.
16.92%
Built up 3 piece wing.
46.15%
Voters: 130. You may not vote on this poll
Fliteskin Ta-152 H1
Reply
Old 04-24-2012, 07:47 AM
  #126
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fliteskin Ta-152 H1
Eran,
I am pushing to have it ready for September.
parts available will be fuselage, cowl, belly pan, canopy, spinner, gun blisters and the laser cut wood kit. There are Fw190 cockpit kits in the market that can be adapted, so I will not spend time on those. The wing was designed with Sierra gear in mind and is also available now.
I am thinking in using the Moki G360 in line engine that fits perfectly inside the nose.
ID:	1754338   Click image for larger version
JGrc is offline
Old 04-24-2012, 07:13 PM
  #127
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So the kit will be available September? Any idea on cost?
vertical grimmace is offline
Old 04-24-2012, 08:28 PM
  #128
erans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jose - Do you think you will be OKwith this much weight in the nose? Almost 2.5Kg...
erans is offline
Old 04-24-2012, 08:44 PM
  #129
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Add me to the list when the kit is available. I'll have a new house in September with a huge basement. I can't think of a better project to break it in with.
Ramstein44 is offline
Old 04-24-2012, 09:22 PM
  #130
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ramstein, I will keep you posted as soon as the maiden gets done and all the wrinkles are ironed.
Eran, nose weight can always be fixed. There is plenty of tail so I don't think that should be much of a problem. The twin Moki is not a definite yet, but I like the idea.
Here a couple of more updates from today. The cowl and fuse are almost ready. A couple af more coats of primer and more 1000 wet sanding should make the surface shiny smooth.
JG
ID:	1754730   Click image for larger version
JGrc is offline
Old 04-25-2012, 06:27 AM
  #131
glazier808
glazier808's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks great Jose...another masterpiece is born!
Casey
glazier808 is offline
Old 04-26-2012, 07:13 PM
  #132
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: glazier808
Casey
Casey, you are too kind[8D]
JG
JGrc is offline
Old 04-26-2012, 07:32 PM
  #133
tdstaf
tdstaf's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great looking Cowl!!!! Looks like the pictures were helpful.
tdstaf is offline
Old 04-26-2012, 08:27 PM
  #134
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: tdstaf
Yes, very helpful, thank you for sending.
JG
JGrc is offline
Old 05-25-2012, 10:19 AM
  #135
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Updates:
the fuse plug is finished and being sanded 800 wet. It will be 4 piece fuse counting the cowl and the bottom of the wing panel. The supercharger will be fiberglass molded as well as the canopy winscreen frame and hood.
The wing is designed for 2 o3 piece option. The 2 piece option is using a center wood box and aircraft ply 10mm thick joiner. If the builder wants a 3 piece wing, the center can be permanent fixed and aluminum tubes can be fitted at the ribs outboard of the landing gear.
Thanks for the patience, it has taken quite a while to make these parts and draw the wing.
For some reason RCU is not uploading the pics. I will post them on http://fliteskin.com/Ta152page.htm
JG
JGrc is offline
Old 05-25-2012, 10:28 AM
  #136
Chris Nicastro
Chris Nicastro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome keep it coming I want one!
Chris Nicastro is offline
Old 05-25-2012, 10:32 AM
  #137
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Chris, you have enough room in the garage??
JG
JGrc is offline
Old 05-25-2012, 11:32 AM
  #138
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jose,
Hard to tell, but does the 152 fuse have all of the rivets already applied? I for one would have no problem paying an extra $100 or $200 to NOT have to rivet the fuse, cowling, hood, vertical fin etc
invertmast is offline
Old 05-25-2012, 11:42 AM
  #139
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No rivets, not because they are time comsuming, but they make the fuse heavier due to gel coat and tend to get lost with few primer coats and what not.
Besides, you need to let the builder do something too!! once you prime the whole airframe, you can burn the rivets (flush) in 3 evening sesions.
Thanks for asking.
JG
PS again I tried to upload pics and would not let me. I'll post them on RCSB
JGrc is offline
Old 05-25-2012, 11:45 AM
  #140
Chris Nicastro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JGrc
JG
I'll make room!
Old 06-07-2012, 08:01 PM
  #141
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuse, cowl and belly plug are finished and it will be about a month or 2 to have molds depending on Vics italian vacation!
The supercharger scoop needs to be made but should take a day or so finish as well. ALl the CAD files for wing and tail feathers are finished as well and cleaned up, sent to the laser cutter already so the wing can be build next.
Things are moving again........
JG
ID:	1770174   Click image for larger version
ID:	1770175   Click image for larger version
JGrc is offline
Old 06-09-2012, 03:24 AM
  #142
erans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great to see some progress
Looking forward to see the wing built.
erans is offline
Old 06-09-2012, 04:31 PM
  #143
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jose,
This is kind of, sort of based off the Dave Anderson 152 correct? If so, could a laser cut kit for that model be used for this one? I just picked one up for the awesome price of free, and the thought of having a fiberglass fuse instead of a built up one sounds awesome.
Old 06-09-2012, 05:04 PM
  #144
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thomas,
The airfoil is a bit different in mine I think. I used NACA 23016 in the root to 23012 at the tips, but I'm sure it can be adapted, it should not be too far off. As soon as I have my plan converted to PDF, I will have it for downloading so you can compare.
JG
JGrc is offline
Old 06-10-2012, 10:10 AM
  #145
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jose,
Thanks for the response. If you could pm me the dimensions of the root and tip chord width, i can print off the airfoil and determine the differences between them.
Thomas
P.s. that cowl looks great!
Old 06-20-2012, 06:23 AM
  #146
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THomas,
I have the plans finished. You will be able to download them this evening.
JG
JGrc is offline
Old 06-20-2012, 11:52 AM
  #147
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JGrc
THomas,
JG
Saweet! Thanks Jose
Old 06-20-2012, 01:51 PM
  #148
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wasn't able to insert the download link. Send me your EMail, so I can send you the plans.
JG
JGrc is offline
Old 06-22-2012, 07:48 PM
  #149
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the interest in the Ta152 plans, remember that I still have to fly the prototype, so there could be changes made. Another part I had to make for molding that I've been putting off, is the supercharger scoop. It seems easy to make, but it actually took a over day to finish, this will save a bunch of time carving and glassing!
The lip is a separate piece to aid in the molding process.
This is how it looks before the last coat of primer.
JG
ID:	1774852   Click image for larger version
JGrc is offline
Old 06-22-2012, 08:32 PM
  #150
Jeremy_D
Jeremy_D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't wait to see this as the finished product - great work!!
Jeremy_D is offline
Reply
Display Modes
