View Poll Results: A poll
Foam 2 piece wing.
13.85%
Built up 2 piece wing.
23.08%
Foam 3 piece wing.
16.92%
Built up 3 piece wing.
46.15%
Voters: 130. You may not vote on this poll
Fliteskin Ta-152 H1
Reply
Old 07-31-2012, 10:23 AM
  #176
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fliteskin Ta-152 H1
Yes Casey, getting busier again... I think I will do green 9 probably..
JGrc is offline
Old 07-31-2012, 06:39 PM
  #177
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aileron is built up with bottom skin and ribs laser cut.
After all the ribs are lined up with brass tube and piano wire going through I CA ribs to bottom skin, sand even with long T and glue top and leading edge strips to complete the sequence.
JG
ID:	1788002   Click image for larger version
ID:	1788003   Click image for larger version
ID:	1788004   Click image for larger version
JGrc is offline
Old 07-31-2012, 08:45 PM
  #178
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just wondering, will you be doing the wing washout like the full size? Washed out 3 deg at the aileron inner rib, then maintaining this to the tip? It would give the characteristic 'kinked' trailing edge and make a pretty safe airplane at low speeds/ high AOA's. Just a thought...
Evan, WB #12.
pimmnz is offline
Old 07-31-2012, 09:21 PM
  #179
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Evan,
Yes the wing has 3 degree constant washout root to tip. The pics of the full size that Ive seen show straight trailing edge so I made it constant
JG
JGrc is offline
Old 08-01-2012, 06:11 PM
  #180
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ahh, OK. All my photos of the full size that show the wing T/E ALL show the 'karakteristik kink'. It is just so easily seen, once seen on one and is a part of the whole, like the U/C angle and length etc. I know most the 3 view drawings don't show it, but again, when compared to the photos...
Whatever, you still have a magnificent machine.
Evan, WB #12.
pimmnz is offline
Old 08-01-2012, 06:27 PM
  #181
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: pimmnz
Evan, WB #12.
I never noticed this "kink" but after doing some research, it seems that there in-deed is a bit of a kink in the wing about 1/2 way out... These are the best photo's I could find of the so called "kink"
http://www.warbirdphotographs.com/LCBW5/FW190-V30-3.jpg
http://www.warbirdphotographs.com/LCBW/TA152-2.jpg
http://www.warbirdphotographs.com/LCBW/TA152-1.jpg
Jose... when can we expect to get our hands on some of these parts?
invertmast is offline
Old 08-01-2012, 08:45 PM
  #182
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Evan, Thomas,
I see the little kink in one of the pics indeed. Very good information.
THese parts will be available as soon as I make sure everything builds right, and there are not major faults.
Thnks for heads up!
JoseG.
JGrc is offline
Old 08-02-2012, 01:32 PM
  #183
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some more images, showing that even the Silver Hill 152 has a 'kinky' trailing edge. You can see under the wing of the compass swing airplane, that the 76 colour only covers the front half of the undersurface, and the rear part appears to be natural metal...so many variations...
Evan, WB #12.
File Type: pdf
pimmnz is offline
Old 08-02-2012, 02:20 PM
  #184
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the first glass fuselage and parts I just received.
Evan, do you have anypic with the flaps down?
JG
JGrc is offline
Old 08-02-2012, 03:07 PM
  #185
glazier808
glazier808's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks quite nice! What is the weight of the fuse, as is?
Casey
glazier808 is offline
Old 08-02-2012, 03:16 PM
  #186
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will look, but so far only two, both from the front so you can't see the flap inner construction. I would assume that they would be like the late model 'D' series wooden flaps, there is a report about the 152's wooden flaps being damaged on landing by water thrown up by the tyres. The Smithsonian web site has some photos of the 152 parts they hold, I believe there is a couple of photos of the flaps there. I will keep looking. The half painted wing undersurface does not seem to be uncommon, 152C 'CI+XM' shows the same thing, 152H 'CF+OY' and '150004' all show the same thing. Keep smiling!
Evan, WB #12.
pimmnz is offline
Old 08-02-2012, 08:27 PM
  #187
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Evan, you're right about othe wood flap construction, I just don't know how many ribs is using. Casey, fuse is about 5 to 6 lbs. as now.
JG
JGrc is offline
Old 08-02-2012, 08:31 PM
  #188
t_burley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cant wait for the first in line kit[8D]
t_burley is offline
Old 08-03-2012, 01:11 AM
  #189
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JGrc, images of the Smithsonian flaps.
Evan, WB #12.
ID:	1788439   Click image for larger version
ID:	1788440   Click image for larger version
pimmnz is offline
Old 08-03-2012, 06:19 AM
  #190
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Evan, those photos are very rare. I did a search and I could not find any before. Looks like the flaps are open ribs construction.
JG
JGrc is offline
Old 08-03-2012, 07:45 AM
  #191
F4u5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Edit....Ooops, I voted way back when [&:] Still interested in the product Jose
Jeff
F4u5 is offline
Old 08-03-2012, 09:09 AM
  #192
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whatta mean Jeff?
JGrc is offline
Old 08-03-2012, 10:26 AM
  #193
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am excited about this as well. Looks great and will be awaiting availability.
Gonna have one at the Warbirds over the Rockies this year? I would love to see how it looks in person. Even if not finished.
vertical grimmace is offline
Old 08-03-2012, 10:45 AM
  #194
F4u5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Jose,
Ha, I tried to vote for the 3 piece wing, but poll closed; then I found that I voted way back when and had forgotten. I edited so I didn't look AS dense
I always wanted to build the Andersen TA, but never got around to it. With you, Vic and Jeff Micko making all of these glass fuselages and parts available, it really cuts the build time, and makes it more plausable. I find that pumps the enthusiasm and is great new.
As Vert says, be nice to see one at WOTR.
Now if we could just get a Mossie fuse in 120 inch span[8D]
Jeff
Jeff
F4u5 is offline
Old 08-03-2012, 05:18 PM
  #195
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JGrc, I know I'm a PIA, but shouldn't you ailerons be open frame, fabric covered?
Evan.
pimmnz is offline
Old 08-03-2012, 09:21 PM
  #196
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ye, work permitting I'll be at WOR, with the project.
Jeff, the 3 piece wing is available. I added an additional lite ply rib to the laser file so you can make the split. An aluminum tube does the rest.
Evan, PIA is OK, makes me work harder. Yes the aileros should be open frame but they would be too fragile, so I use a balsa sheet with ribs on top that is fabric (solartex) covered.
JG
JGrc is offline
Old 08-04-2012, 01:52 AM
  #197
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clever.
Evan.
pimmnz is offline
Old 08-05-2012, 09:07 AM
  #198
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: F4u5
Hey Jose,
Jeff
Hello Jeff,
Jeff
Why would you want a Mossie when you can fly the Hornet? Look up the specs http://fliteskin.com/DHHornet.html
JG
JGrc is offline
Old 08-05-2012, 06:36 PM
  #199
F4u5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am a Mossie lover...[8D]
F4u5 is offline
Old 08-16-2012, 08:03 PM
  #200
JGrc
JGrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gun Hood plug is ready for molding, it took much more time that I thought!! worth the effort though....
JG
ID:	1792727   Click image for larger version
JGrc is offline
Reply
Display Modes
