Painting Stits Fabric with Klass Kote Paint
Hey Guys, I have Stits Fabric covered control surfaces. I want to paint my Avenger (being built here in this form) with Klass Kote paints. I talked to Nate, Mr. Klass Kote, he said all I need to do is scuff up the fabric for the Klass Kote primer to bite. I'm concerned about scuffing the fabric, without tearing/ripping it, since I have never done that before. Can you guys give me some guidance how to scuff up the fabric without destroying it? Many thanks.
Chick,
Something mild for the fabric. Maybe a Bright Boy or 200-320 sand paper. Don't press on the fabric. Let the abrasive do the work. You shouldn't need much scuffing as fabric normally has a pretty good "tooth" to it. I'm guessing the fabric won't crack over open structures? |
Thanks Guys both here and on rcscalebuilders. Will follow your suggestions. Was also told to use scotch pads lightly. Good hearing from you both. Chic
