RE: Fliteskin Ta-152 H1
1 Attachment(s)
ORIGINAL: pimmnz Vertical, perhaps they do sell plastic kits, but that still does not make the drawings of this 'H-0' right. There is one at Silver Hill and it looks nothing like these drawings. Perhaps the manufacturer used the old Kookaburra drawings and simply embellished them? Whatever, it does not represent any known H-0 from the photographic record. As for using it in scale competition, and this is purely a personal feeling, you understand, it means that provided you can supply a convincing 3 view, and artists impressions for colour, then without the requirement to prove that it actually existed as a full size airplane, any imaginary aircraft could be flown in 'Scale' competition. Personally, I don't think that is the intention of 'Scale Contests' anywhere in the world, but I have been wrong before, and will be again... Evan, WB #12. |
No Vert, it's OK, I have the Harmann book too, though I wouldn't say it 'clearly' shows the rounded tips, but they do, on close inspection, look a little different to the tips on 'KS. Your 5 view looks much more like it, the only 'scale' drawings I have showing round tips is the old Kookaburra set, and they are severley lacking in many respects. I have, in the past, owned a couple of H's, both been sold on, both were exemplary flyers, though one of them did 'disappear' in flight once, most frightening even though it only lasted a couple of seconds. The grey camo really works. If I do another it will likely be 150168 (?), the unmarked hanger queen, I have, through several publications, the required 3 photos for our local and FAI type contests. So far as the gun troughs, again, there is nothing clearly shown for them on 'KT, and again, nothing clearly showing they were not. Since the A, B, and C versions were all schemed to have cowl weapons, it is possible that KT could have inherited an upper cowling originally destined one of them, the fuselages were all roughly the same. But without the certainty of a clear photo, if in doubt, leave it out?
Evan. |
The GH+HT crashed after only 10 hours of testflight because of a enginefire in high altitude. This prototype also had a "Spike" at the top of the fin.
1 Attachment(s)
Well, my scanner keeps giving me black and white, but here is the 3 view of the colors. It has the RLM numbers for reference. When I can I will post a good color photo. I like this plane because it is a little different. Especially the colors. I have a feeling we will be seeing many TA 152 models soon and unfortunately to have scale colors, they will mostly look the same, except for this one. :)
I like the idea Vertical. Take a couple of minutes out one day and read the colour description for GH+KT. I like the bit where it says a 'natural metal' fuselage plug, and plainly shows a painted one in the colour profiles...you just can't trust the proof readers these days...Looking carefully at the KT photos, I don't see a 'double curve' where the tip intersects the aileron trailing edge, as shown in the drawings. I wonder if the tip should match the aileron curve? Perhaps the squared off tip and the rounded one are simply two variations of the one detachable tip...I'll go now, before I end up in more controversy...
Evan. |
I'll put my foot in my mouth again, and counsel caution with 'natural metal fuselage plugs'. The picture of KT on page 77 of the Harmann publication shows what appears to be a very 'light' coloured plug, with the light coming almost nose on. You will see this phenomenon on various photos of both D's and 152's. Often the caption will claim a 'natural metal' plug. The photo of KS on page 78 shows, by comparison, a painted plug. The photo of 150168 on page 118 shows a darker coloured plug. I think that it is most likely that all these plugs are painted the same as the rest of the fuselages and the photos of KT on page 75 tend to bear this out. The culprit is the reflection of light from the different surface angles of the plug and the fuselage sides fore and aft. I tend to be a bit of a sceptic about the claims of the 'expert interpreters' of old B&W photos. I have one 'authoratative' publication here on late war German camo schemes claiming white painted nachtjaeger, when it is quite obviously faded 76 lit by low angle light reflecting off a puddle of water on the hardstand under the airplane. One needs to be careful.
Evan. |
1 Attachment(s)
I have the fuse rough primed and the mock up wing to start with the wing fairings. The wing saddle is set at 2.5 degree incidence per full size. Also I looked at D. Andersons plans and he uses the same setting.
The fillet is pretty challenging so is a good idea to do it once and mold it, also the belly pan is challenging as it has to merge with the wing smoothly. I've used fliteskin extensively to duplicate the panels. JG |
That looks much more than 2.5 deg, and it should be. I think the angle looks, and should be, much closer to 5 deg to the fuselage axis. The FW190 drawings by Bentley show an angle much closer to 5 than 2.5. The airplane in full size flys 'nose down', and there is a 3 degree washout on these long wings, ending at the inboard aileron cutout. The wing continues at -3 to the tip, resulting in the 'kinked' trailing edge that is so visible on the photos of the full size. Since the pilots of the original were very impressed with the wing, then the geometry should be reproduced for modellers to enjoy, too.
Evan, WB #12. |
1 Attachment(s)
My Ta152C have 3 deg angle at the wing, an 2,5 deg at the stabilisator, and flies very well.
1 Attachment(s)
ORIGINAL: pimmnz That looks much more than 2.5 deg, and it should be. I think the angle looks, and should be, much closer to 5 deg to the fuselage axis. The FW190 drawings by Bentley show an angle much closer to 5 than 2.5. The airplane in full size flys 'nose down', and there is a 3 degree washout on these long wings, ending at the inboard aileron cutout. The wing continues at -3 to the tip, resulting in the 'kinked' trailing edge that is so visible on the photos of the full size. Since the pilots of the original were very impressed with the wing, then the geometry should be reproduced for modellers to enjoy, too. Evan, WB #12. Vert I like your choice of colors mine is painted in RLM 74/75/76 JG rc, Nice work looking great and should fly nicely on Your choice of airfoils. |
ORIGINAL: JGrc Casey, you're right the cat's out and there is no turn back ! It's interesting to get views and ideas.... Dash, yes the gear mounting is an issue on the 190. Having built 3 helps figuring out the weak points. The built up wing will be easier to build and re-enforcing the spar and ribs connecting the gear plate will solve the problem. I also built the Holman fw190 in the past with a foam wing and works well if reinforcing the gear plate with 2 semi ribs connected to a ply 1/8'' semi-spar. Dan, 30lbs is not unrealistic, specially if built up. My heavy glass fuse Fw190 weighs 23lbs with 83'' built up wing My DhHornet weighs 36lbs but and 100'' span but 5lbs are lead on the nose. The Ta152 will not need any lead in the nose. I think I will have both options, 2 piece foam and 3 piece balsa and ply with a alu tube. JG |
Yes, it looks like a huge angle of incidence but it's 2.5 angle (wiing cord to longitudinal line)
Everything will be triple checked before the wing fairings are built. Thank s for all the pics guys. Tdstaf, whos 152 is that? looks awesome. JG |
ORIGINAL: JGrc Yes, it looks like a huge angle of incidence but it's 2.5 angle (wiing cord to longitudinal line) Everything will be triple checked before the wing fairings are built. Thank s for all the pics guys. Tdstaf, whos 152 is that? looks awesome. JG Tim |
In that case JGrc, we were both wrong, the Bentley drawings show the root rigging incidence as +3 deg. Which would make sense, as it then puts the tip section at 0 deg. I was working from poor memory, but the drawing never forgets...tdstaf, I have the Monogram 'close-up' of the 152 with several pictures in colour taken 'late 1945'. Is the aircraft as 'grey' as the colour photos show? I know that most of the artists colours show a basically green/brown upper scheme but the photos seem very monochromatic. It might be just the negative fading over time, but the 4 on the fuselage side is definitly green in the photo, as is the grass at Wright Field, but the airplane seems very much grey compared to them.
Evan, WB #12. |
I still think the entire wing center section (belly pan and inner gear doors) would be awesome to mold into the fuselage as well. It would eliminate a couple of extra molds and parts, and with a wing tube through the fuselage, it would make assembly super easy.
ORIGINAL: pimmnz In that case JGrc, we were both wrong, the Bentley drawings show the root rigging incidence as +3 deg. Which would make sense, as it then puts the tip section at 0 deg. I was working from poor memory, but the drawing never forgets...tdstaf, I have the Monogram 'close-up' of the 152 with several pictures in colour taken 'late 1945'. Is the aircraft as 'grey' as the colour photos show? I know that most of the artists colours show a basically green/brown upper scheme but the photos seem very monochromatic. It might be just the negative fading over time, but the 4 on the fuselage side is definitly green in the photo, as is the grass at Wright Field, but the airplane seems very much grey compared to them. Evan, WB #12. Got off topic; Yes they look gray but there respective shades of violet brown and green are in them. Also remember that your impression of gray is probably different then my impression of gray. |
1 Attachment(s)
Here is an example, My plane same color taken with same camera 3 times, different day, different time, different location.
Yes, I get that. The Monogram colour photo was taken on a bright day, the shadow under the plane is dark, and sharp. I was more after your impression of the thing 'up close', as it were. You did take the 200 odd photos at Silver Hill? I realise that time will have taken its toll on the original colours, but it has been in storage for most of its life so there should still be enough of the original paint to form a reasonable impression...
The Monogram book also reproduces VG's set of photos of 'KT per the Harmann publication, but larger, with the full negative and much sharper. It is obvious that the tips fitted to KT do not look like his drawing, either from the front or from the back. Also, the photos of 'KS are reproduced. There is no visible evidence for gun troughs on 'KT, but guess what? 'KS has what appears to be a cover plate fitted over the gun troughs. It is also evident that the top cowling has been profiled to fit guns, it is not a smooth curve and it is seen on all the 152 photos, H-0 and H-1. I can only go by the photos I have, again, if you were up close enough, can you confirm the photographic evidence? (Yes, I'm trying to gather enough info to do a drawing) Evan, WB #12. |
ORIGINAL: pimmnz Yes, I get that. The Monogram colour photo was taken on a bright day, the shadow under the plane is dark, and sharp. I was more after your impression of the thing 'up close', as it were. You did take the 200 odd photos at Silver Hill? I realise that time will have taken its toll on the original colours, but it has been in storage for most of its life so there should still be enough of the original paint to form a reasonable impression... The Monogram book also reproduces VG's set of photos of 'KT per the Harmann publication, but larger, with the full negative and much sharper. It is obvious that the tips fitted to KT do not look like his drawing, either from the front or from the back. Also, the photos of 'KS are reproduced. There is no visible evidence for gun troughs on 'KT, but guess what? 'KS has what appears to be a cover plate fitted over the gun troughs. It is also evident that the top cowling has been profiled to fit guns, it is not a smooth curve and it is seen on all the 152 photos, H-0 and H-1. I can only go by the photos I have, again, if you were up close enough, can you confirm the photographic evidence? (Yes, I'm trying to gather enough info to do a drawing) Evan, WB #12. |
VG kindly posted the pics and drawing at the beginning of this page...The Monogram profile has them on pages 2, 3 and 4. I can try to upload them at work tomorrow...
Evan |
1 Attachment(s)
Here is a colour-photo of a Ta152H "kraftei"
ORIGINAL: invertmast I still think the entire wing center section (belly pan and inner gear doors) would be awesome to mold into the fuselage as well. It would eliminate a couple of extra molds and parts, and with a wing tube through the fuselage, it would make assembly super easy. |
How interesting a warbird thread is really a scale thread now! Fine by me, you go where the info is.
ORIGINAL: deatonbt ORIGINAL: invertmast I still think the entire wing center section (belly pan and inner gear doors) would be awesome to mold into the fuselage as well. It would eliminate a couple of extra molds and parts, and with a wing tube through the fuselage, it would make assembly super easy. I am just curious. Wouldn't the line between the wing panels be very noticeable as compared to the wing sitting against the saddle? |
ORIGINAL: invertmast ORIGINAL: deatonbt ORIGINAL: invertmast I still think the entire wing center section (belly pan and inner gear doors) would be awesome to mold into the fuselage as well. It would eliminate a couple of extra molds and parts, and with a wing tube through the fuselage, it would make assembly super easy. |
