RCV 91CD Cylinder Bearing removal
Hi
I have a RCV 91CD that I need to remove the Cylinder bearing to re-work the exhaust port due to crash damage where the muffler was pulled off.
I have the rotating cylinder out and was looking at the best way to remove the bearing without damaging the cylinder walls. I have the circlip removed and heated up the body but there is not much to catch on to pop out the bearing from the top side. Tried using a wood dowel with an edge without success
Appreciate any suggestions on how to best do this as I very much like the engine.
ray
ray
