RCV120 on a 100" Pilatus Turbo Porter
Hi, I am in the process of building a 100" Pilatus PC6 Turbo Porter, projected weight is around 15 lbs. Due to the thin nose of this aircraft the RCV 120 seems to be ideal. Do you think that it has enough power for this model?
Another question is that the original has a 4 bladed prop. How will the engine cope with such a prop?
Thanks and best regards
Yoram
Yoram
RE: RCV120 on a 100" Pilatus Turbo Porter
Hi Yoram
Thanks for your enquiry. 15lbs is about the heaviest model that an RCV120SP will fly. Any heavier and performance could be marginal.
I would say that the 120SP will certainly have enough power to pull the aircraft around they sky, but aerobatics etc wouldn't be achievable.
With regard to a 4-bladed prop, the RCV120SP will pull a 15.5x12 4-bladed prop easily, however as with the increase in blades does decrease the efficiency, so if you feel the RCV120SP needs more power to pull the PC6 then it would be better to use a 2-bladed prop.
I hope this helps
Best regards
Laurenne
I hope this helps
Best regards
Laurenne
Who is the manufacturer of that pilatus kit? Or is it scratch-built?
Laurenne,
Would aerobatics (with 4-blade) be possible if the aircraft weighed more around 10-12 lbs?
Laurenne,
Hi Windhawk
To be honest, we do not recommend our SP series engine for aerobatics anyway. Aerobatics tend to prefer lots of rpm at the prop, whereas the SP series has a reduction output, therefore it has twice of torque but half the rpm. That isn't to say people can't, but they are not are ideally suited.
The RCV120SP will have more than enough power for a 10-12lb model and will certainly be able to pull it around the sky with ease. 4-bladed props are less efficient than 2-bladed props, but with a lighter model (eg. 10-12lb) this should be a problem.
I hope this helps. Sorry I cannot give a definitive answer
Best regards
Laurenne
Best regards
Laurenne
Sorry, I was meant to say this 'should not be a problem' (not this 'should be a problem').
Regards
Laurenne
Regards
Laurenne
Thank you for the prompt feedback.
The RCV company has great online support.
I'm building a P-51D, so I'm not looking to perform 3D manuevers. I'm more
interested in barrel rolls, loops, and maybe the occasional hammerhead.
Are these the types of "aerobatics" that require high RPM?
Hi windhawk, the kit is very old and from Ikon Nwest, who ceased to exist sometimes in the 90s. Its a very nice plane, but a difficult kit, with a lot of cutting to do and innaccuurates plans. Nothing to do with laser cuts parts and 30 pages manuals wit tons of pictures. Its more of how you interpret the plans ' the manual, and the wooden pieces.
Yoram
Thanks Laurenne for the info. we will try the RCV 12o.
Yoram
Ikonn West has new ownership, here's their e-mail address: [email protected].
Here's part of a message I got when asking about the Turbo Porter:
"At this time I am converting over to laser cut and have the turbo
version almost done cost is 270.00 plus shipping. Aaron"
Hope this helps you. BTW I will be building a Turbo Porter base on Airborne magazine plans.
Rick
Rick
