If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Join Date
    Nov 2004
    , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Which RCV for VQ P51-D Warbird
    VQ Warbirds are selling RCV engines as well now and I'm going for one.
    The model I'm getting is the P51-D Mustang.
    The specs are
    Wingspan: 58.2 "
    Fuselage: 46.8 "
    Weight: ~ 5.9 - 6.4 lbs
    Engine req: .40 - .46 (2 stroke), .70 (4 stroke)
    I used to have a similar model with an OS 70 Surpass. I think the 58 size engine will be ok however I don't want it to be gutless in this model.
    Please advise on what you think will be best
    Raj
    UK
  2. #2
    Join Date
    Apr 2002
    WimborneDorset, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Which RCV for VQ P51-D Warbird
    Hi Raj
    Thanks for your enquiry. It's a tricky one as you definately don't want a gutless Mustang.
    The RCV58CD will certainly power a 6lb model and I am sure this would be suitable. Check out our user gallery and there is a couple of 6 - 6.4lb mustangs flying successfully.
    http://www.rcvengines.com/gallery/rcv_gallery_58cd.htm
    http://www.rcvengines.com/gallery/rc...p51mustang.htm
    The RCV58CD is not as an OS70 though, so if you like to have even more power then you could always consider the RCV91CD which is the height of a 52 4-stroke (so still smaller than a conventional .70) and will have masses of power.
    I hope this helps
    Best regards
    Laurenne
    Technical Support
    RCV Engines - UK
    www.rcvengines.com
  3. #3
    Join Date
    Nov 2004
    , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thank you - would you know what the best prop is for this combination (or where I should start !)
    Regards
    Raj
  4. #4
    Join Date
    Apr 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi
    A good starting point for props sizes are:
    58CD - 12x6
    91CD - 14x6
    I hope this helps
    Best regards
    Laurenne
    Technical Support
    RCV Engines - UK
    www.rcvengines.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
