quieter pipe for rcv120
SK, NEW ZEALAND
Any suggestions out there regarding a quieter exhaust system for the rcv120?
My stock muffler has fallen apart during the run in and while I love the motor so far the noize level is too high for me. I want to replace the stock sith something much quieter.
Is the OS muffler often talked about quieter?
I'm putting it in a brian taylor 70inch MkXIV spitfire.
Cheers
Cheers
RE: quieter pipe for rcv120
The OS muffler is exactly the same, the only difference being that the end is welded on.
A suggestion might be to have the muffler AND some corrugated flex pipe. I currently run a couple of 4 strokes (RCV and ASP) using just the flex pipe, which acts as a muffler, so if you were to use both you should get it much quieter.
