Caldera 10E aluminum parts???
PA
I'm still fairly new to RC and I wanna replace all plastic parts on my caldera 10e with aluminum parts that are available... Is there any part I should start with first and is there any sort of downfall to switching everything up to aluminum??? I basically just do some pretty hard bashing with some jumps and that sort of thing so I figured aluminum would be the way to go for durability!!!
RE: Caldera 10E aluminum parts???
redcat has alum
rear wheel hub
"C" hub
wheel hex set
knuckle arm set
shock tower
steering linkage.
i personally would start with the rear hub, c hub, knuckle arm set and shock tower.
PM and i can give you pricing if you like.
honestly the caldera is pretty sturdy in stock form.
rear wheel hub
"C" hub
wheel hex set
knuckle arm set
shock tower
steering linkage.
I'm interested in purchasing a Caldera 10E. I found a few online sub $200. I'd also like to upgrade the parts to aluminum. Can I PM you (nitrosportsandrunner) to get a quote?
