Tires.
RE: Tires.
Igot the Proline badlands for my eq 8e, and they are awsome. tottaly different truck now. Idid use the old wheel and it was kind of a nightmare to get the old tires off but well worth it
RE: Tires.
yes they do they badlands offer good grip on the ground im using imax pin dawgs on my EQ 3.5 they offer just the right amount grip but not to much
RE: Tires.
No they don't put to much stress on anything, in fact they are about a 10th of an inch smaller then the stock tires, an dnow that Irun them I've noticed my motor stays a bit cooler... another good thing to do is put some super heavy duty grease in the center diff, I've noticed a much better power distibution to the front and rear diffs, just keeping it from popping wheelies every second has improved the temp as well. I've waterproofed all my electronics on my Eq 8e so it naturaly runns slightly hotter, but at the same time I run at my local track as hard as that thing will go and it does great
RE: Tires.
Nope :} Like I said in the top post, It is Horrible Trying to get the Tires off but they work perfect on the stock EQ wheels
http://prolineracing.com/tires/badla...terrain-tires/
THESE ARE THE ONES
THESE ARE THE ONES
