EarthQuake 8e Wheel and tire help
My Feedback: (19)
Hey guys i have question for you all. As we all know the earthquake 8e wheelies a little bit excessive. So my question is, what is a good 17mm hex wheel and tire combo that reduce the wheelie effect? thanks in advance.
IA
RE: EarthQuake 8e Wheel and tire help
The way to prevent wheelies without a wheelie bar is to reduce traction. You could upgrade to 17mm hubs and use buggy wheels and tires, which are narrower. But personally I'd make the change in my index finger.
My Feedback: (19)
yea guys i just received my earthquake 8e today and it does not wheelie as much as i thought it did. but i did purchase the 17mm conversion kit just for a larger selection of wheels. thanks for the advice.
LA
I put HPI Warlock rims and HPI Dirtclaw tires on my Avalanche. They are a bit smaller in overall diameter and make the truck a tad narrower. I would use RPM Stablemax rims if I had to do it over, they would make the truck wider, but Ilike the tires for off road. Just make sure you strap them with duck tape. They are lighter than the stock tires but the downfall is they baloon if you don't strap them, but then again so did the stock tires.
IN
ORIGINAL: chillymostly
