BS936-002 alternative?
QC, CANADA
Hi,
Does any of you knows the thread pattern for the Backdraft 8E wheel nuts?
I'd like to find some alternative in different colors.
I've tried Ofna's nuts but they have different thread
http://www.ebay.ca/itm/OFNA-15073-WH...#ht_1720wt_905
Any idea?
BS936-002
Any idea?
IA
RE: BS936-002 alternative?
They're the same as Traxxas. Probably M4x1.0 or maybe .75. If no one has an answer I'll try to measure tonight.
Editoh, I thought you said Aftershock for some reason. Nevermind what Isaid.
FL
The 17mm hex nuts have different threading than the redcat ones,
I know this because when I was changing my eq8e to backdraft, i bought the traxxas ones and didnt realize it and ended up buying the traxxas 12-17 mm set and used them, I decided to order the redcat adapter set since they had a long offset, longstory short.. they arent threaded the same, i tried it.
