Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Wobbly Wheels!
Reply
Old 10-10-2011, 05:25 PM
Meafordguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wobbly Wheels!
Over time and use the wheels have become quite "wobbly" in the back. It is loose between the stub axle (http://www.redcatracing.com/RC-Cars/Redcat-Parts/02033)
and the rear hub carrier (http://www.redcatracing.com/RC-Cars/Redcat-Parts/02013). I have upgraded the rear hub carrier to aluminum, the hex wheel nuts are aluminum as well
and the two axle sleeves do not appear to be worn or damaged. So what is causing the wheels to get so wobbly the truck looks like a beginner skater on ice?
Meafordguy is offline
Old 10-16-2011, 12:59 PM
invalidjunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Wobbly Wheels!
I'm guessing it's slack between the stub axle and where the dogbone slides into the back of the cup. Mine do the same thing, but if you put pressure on the suspension it doesn't wobble as bad. I think it's normal as I have been to the local hs here and all their cars/trucks do it as well.
invalidjunk is offline
Old 10-16-2011, 03:13 PM
soutthpaw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you get a CV joint instead to replace the dogbone setups
soutthpaw is offline
Old 10-16-2011, 05:38 PM
rchobbyunlimited
rchobbyunlimited's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you check the bearings they can wear out and will make the wheels whobble.
rchobbyunlimited is offline
Old 10-16-2011, 07:08 PM
Meafordguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dont think they have bearings in a volcano or Caldera 10E, just a metal sleeve that goes inside the axle holder which does not appear worn, but that is where it is loose.
Reply
Display Modes
