Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Volcano maintenence help Newb
Reply
Old 11-12-2011, 08:54 PM
hudsonaj36
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Redcat Volcano maintenence help Newb
Hi, just picked up a used himoto eldorada, same as the volcano. This is my first car, normally just into planes and helis. It runs well but does not appear to have been maintained that well. So my question is what kind of maintenence is needed for example.
Does it have differential fluid? If so how do I change it?
What else needs grease/oil?
Does the clutch need anything?
The dogbone cups on the differential are real wobbly/loose, is this normal?
Like I said it seems to run good overall but since this is my first car I am not really sure what normal is. But for 35$ I couldn't pass it up
Thanks for your help
hudsonaj36 is offline
Old 04-23-2012, 05:53 PM
R4YMAN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Volcano maintenence help Newb
well if its a gas job the first thing i would recommend is getting a good fuel that has after run oil in it that way you dont have to add it after every run also keep your eye on the spur gear unless it is already upgraded the plastic ones dont last very long, also the air filter will need to be cleaned the best way i found is to use brake clean and rinse with water and allow to dry then you will need some air filter oil and give the air filter a generious coating of it, as far as the diffs go i believe there is a oil in there im sorry but im not sure what kind or grade im sure your local hobbie shop can help with that, and the dog bones being loose is kinda hit and miss iv had my earthquake3.5 for a week and mine have a lttle play in them as well but they are not super loose if you deside to change diff fluids that would be a good time to check up on the dog bones hope i helped a little bit.
P.S i am new to the rc trucks as well, but being an automotive service tech helps
R4YMAN is offline
Reply
Display Modes
