Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Rockslide RS10 XT
Reply
Old 12-02-2011, 10:31 AM
32_d3gr33s
32_d3gr33s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Redcat Rockslide RS10 XT
I just purchased one of these online. Im just curious if i would be able to run a lipo with it? I have a couple extra 40c 5000mah 2s lipo batteries and thought that if possible, i would like to use them. i assume that the ESC doesnt have lipo cutoff, so i would have to pick up a low voltage alarm, or cutoff, but before i buy something like that, just want to make sure it would run with a lipo without burning anything up. Thanks for any help!
32_d3gr33s is offline
Old 12-02-2011, 09:14 PM
32_d3gr33s
32_d3gr33s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Rockslide RS10 XT
really? nobody has a clue if i can run a 2s lipo?
Old 12-07-2011, 06:00 AM
ShredderGuy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would guess that they can not run off lipo's at all. I read the specs on them and it looks like they come with brushed motors and a small ESC.
ShredderGuy is offline
Old 12-07-2011, 06:11 AM
nitrosportsandrunner
nitrosportsandrunner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ShredderGuy
that esc can actually handle upto 14v. its the same ESC that comes in the 1/8 scale crawler.....of which you can buy a adapter to run 2 6cell batteries in series.
i have run this esc on a 3s lipo. the ESC runs fine, but you do need an externa LVC....or at least an LVA
nitrosportsandrunner is offline
Old 12-07-2011, 08:01 AM
32_d3gr33s
32_d3gr33s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info! I just wanted to make sure. You positive that it will handle 14 volts? I won't put that much through it, but it would be nice to know for sure! Thanks!
Old 12-07-2011, 08:15 AM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 32_d3gr33s
yes it will. the 1/8 scale uses the same version ESC. And redcat sells a series adapter so you can run a pair of 7.2v batteries(total 14.4v)
they did that on the larger truck because it has 100t motors and is even slower than the rs10.
i wouldnt run 14.4 myself, but 3s or 11.1v will be fine.
i do reccomend a heatsink on the rear motor tho. the increased voltage will cause more heat, especially on the rear motor. It wont be enough to burn up the motor, but over time will wear down the brushes quicker.
I know cause that is what happened to mine. When crawling up steep inclines, the rear motor has more load on it. Thus it heats up more. And on 3s lipo that extra heat will wear out the brushes sooner than on the front....thus making the rear weaker.
A simple heat sink on the rear motor will help.
either way, those motors dont cost much, and the extra torque and wheel speed on a 3s lipo is well worth it IMO.
Old 12-07-2011, 09:12 AM
32_d3gr33s
32_d3gr33s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome! Thanks a ton!
Old 12-17-2011, 04:21 PM
XtrmTJ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I run a 1300 mAh 2s lipo in my XT10 with no problems, you will need a cutoff or a buzzer for low voltage warning.
XtrmTJ is offline
Reply
Display Modes
