Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
aftershock 8e wheel? do i need different gears or motor setup
Reply
Old 12-09-2011, 12:19 PM
chevyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default aftershock 8e wheel? do i need different gears or motor setup
i have the aftershock 8e and wanted to put bigger wheels on it the stock size is aprox. 4.5" tall x 1.75" wide the ones i have are aprox 5.75" tall x 3.5" wide i had to change axles and hexes not a big deal as i have the stuff i ran the truck with them on and noticed shorter run times and it seemed to get hot and cutoff so i switched back to normal size tires my question is what will i need to change i.e. motor, gears or whatever to run these tires without any issues
chevyb is offline
Old 12-11-2011, 08:36 AM
chevyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: aftershock 8e wheel? do i need different gears or motor setup
this is what im going for if this helps......someone has to know something
chevyb is offline
Old 12-11-2011, 09:04 AM
fahaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: aftershock 8e wheel question
Do you have the heat sink or cooling fan option for system? I've taken my Aftershock and run it with Avalanche/Monsoon tires with no problems. I do run the fan and heat sink on my setup.
ID:	1698535   Click image for larger version
fahaka is offline
Old 12-11-2011, 09:08 AM
fahaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've done the reverse as well.
ID:	1698541   Click image for larger version
fahaka is offline
Old 12-11-2011, 09:12 AM
chevyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
esc has fan as far as motor no fan or heatsink
chevyb is offline
Old 12-11-2011, 09:14 AM
chevyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what are the size of your tires compared to mine
chevyb is offline
Old 12-11-2011, 09:22 AM
fahaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Avalanche tires not pictured are over 6" tall and 3.8" wide.
fahaka is offline
Old 12-11-2011, 09:24 AM
chevyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok did you run axle extensions
chevyb is offline
Old 12-11-2011, 09:31 AM
fahaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah I put the Redcat extensions, / 17mm conversion, on and they were enough to run the larger tires. At top speed that tire is probably more like 9" tall and 0.5" wide. The Earthquake flies on that lager size.
fahaka is offline
Old 12-11-2011, 09:38 AM
chevyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok yea my wheels ar 14mm so i have 1.5" extensionswith 14mm hexesthat slide over axles but i also have redcats 17mm conversion kit just no 17mm wheels....my wheels are from a tamiya
chevyb is offline
Reply
Display Modes
